Release: 2.0.4.6 (canary) 2018-12-11
2.0.4.6-2.0.4.6_canary_2018-12-11
  • Improved code quality and documentation, thanks @warwickmm
  • Don’t ask for password for an unencrypted backup, thanks @verhoek
  • SFTP can now create missing folder tree, thanks @warwickmm
  • Removed duplicati http options, thanks @warwickmm
  • Fixed an issue with exporting passwords, thanks @Pectojin
  • Added notificaiton button for warnings, thanks @LacunaSoftware
  • Added cache-buster for all local static files, thanks @LacunaSoftware
  • Improved code quality, thanks @verhoek
  • Fixed an issue where the GUI would not delete the local database, even on request, thanks @warwickmm
  • Fixed a misleading path error message, thanks @mikaelmello
  • Fixed scheduler checking allowed days in local timezone, thanks @LacunaSoftware
  • Reworked the log UI, thanks @LacunaSoftware
  • Fixed an issue where local times were reported as clashing if times overlapped due to DST
Updated one Windows server, looking good so far and the new log UI does improve things, thanks.
However, I can’t get my Fedora box to upgrade from 2.0.4.5_beta, the log shows:
System.IO.InvalidDataException: Unable to verify signature at Duplicati.Library.AutoUpdater.SignatureReadingStream..ctor (System.IO.Stream stream, System.Security.Cryptography.RSACryptoServiceProvider key) [0x00019] in <3227b98b904042faac2116282e7fbdfd>:0 at (wrapper remoting-invoke-with-check) Duplicati.Library.AutoUpdater.SignatureReadingStream:.ctor (System.IO.Stream,System.Security.Cryptography.RSACryptoServiceProvider) at Duplicati.Library.AutoUpdater.UpdaterManager.CheckForUpdate (Duplicati.Library.AutoUpdater.ReleaseType channel) [0x00101] in <3227b98b904042faac2116282e7fbdfd>:0
Any ideas? I did restart the service.
Thanks!
I have 2 issues with this release:
  1. New version is not detected. Clicking Check for updates now in the About page doesn’t show a popup that a new version is found.
  2. After copying the contents from the Zip version over the current install, the Log files are not shown. Instead, this is displayed and doesn’t change afterwards:
Same issue here on official Docker container - even after I remembered to change my Update Channel from beta to canary. :blush:
But I’m assuming it’s a caching issue - gonna restart the container & see what happens… No change. I’ll try again in a few hours. :slight_smile:
I assume it’s still there even in a fresh incognito / private window?
Can you check the server log and see if you’re seeing the same signature error that I get?
Good thought - and yep!
 at Duplicati.Library.AutoUpdater.SignatureReadingStream..ctor (System.IO.Stream stream, System.Security.Cryptography.RSACryptoServiceProvider key) [0x00019] in &lt;3227b98b904042faac2116282e7fbdfd&gt;:0
 at (wrapper remoting-invoke-with-check) Duplicati.Library.AutoUpdater.SignatureReadingStream..ctor(System.IO.Stream,System.Security.Cryptography.RSACryptoServiceProvider)
 at Duplicati.Library.AutoUpdater.UpdaterManager.CheckForUpdate (Duplicati.Library.AutoUpdater.ReleaseType channel) [0x00101] in &lt;3227b98b904042faac2116282e7fbdfd&gt;:0
It looks like I also get some of these:
System.Net.WebException: Error: NameResolutionFailure at System.Net.WebClient.DownloadFile (System.Uri address, System.String fileName) [0x000ad] in &lt;1a0168907d2042858c12ff7b2c118a26&gt;:0
 at System.Net.WebClient.DownloadFile (System.String address, System.String fileName) [0x00016] in &lt;1a0168907d2042858c12ff7b2c118a26&gt;:0
 at (wrapper remoting-invoke-with-check) System.Net.WebClient.DownloadFile(string,string) at Duplicati.Library.AutoUpdater.UpdaterManager.CheckForUpdate (Duplicati.Library.AutoUpdater.ReleaseType channel) [0x000ee] in &lt;3227b98b904042faac2116282e7fbdfd&gt;:0
The screenshot is what I see in Microsoft Edge. I upgraded from 2.0.4.4 to 2.0.4.6 by overwriting with the contents of the Zip file on 2 systems. Both installs have the same problem in Edge, see screenshot above.
In IE, Duplicati Web UI doesn’t load at all, it only shows this popup on both upgraded systems:
I’m not at a machine I can do that sort of test with, but it almost looks like the server starts enough to provide the basic UI but then stops responding when specific requests are made.
Does reloading the page give the same message or 404 / 500 error?
No, whatever I do (start normal/inprivate, F5/Ctrl+F5, restart computer), the symptoms stay exactly the same: malformed log page in Edge, “Not loaded” popup in IE.
+1
Vanilla Windows 10 install, canary channel.
Are you also getting NameResolutionFailure followed by Unable to verify signature errors in the global log?
I haven’t done any sort of manual update - would I be expecting to see any log errors?
I don’t necessarily have time to futz around (at the moment) with forcing a manual update, so I figured I’d wait and be a canary to try out whatever fix they come up with to address the update check issue. If you want me to try anything in particular though (as long as it’s relatively quick) then i’d be happy to.
Thanks!
Can you open the Dev Console and see which errors are displayed there?
I’m afraid I may have used some features that are not available in IE. Can you also open the Dev Console and send me the errors?
I’ll also try to reproduce these behaviors myself over this week
Sure, this is what I see in Edge:
4HTML1300: Er heeft navigatie plaatsgevonden.
localhost:8200 (1,1)
SCRIPT1005: SCRIPT1005: Expected '('
BackupLogController.js (34,27)
Error: [ng:areq] http://errors.angularjs.org/1.4.3/ng/areq?p0=BackupLogController&p1=not%20a%20function%2C%20got%20undefined
   at Sb (http://localhost:8200/ngax/scripts/angular/angular.min.js:22:12)
   at Qa (http://localhost:8200/ngax/scripts/angular/angular.min.js:22:105)
   at Anonymous function (http://localhost:8200/ngax/scripts/angular/angular.min.js:79:497)
   at x (http://localhost:8200/ngax/scripts/angular/angular.min.js:59:499)
   at S (http://localhost:8200/ngax/scripts/angular/angular.min.js:60:335)
   at g (http://localhost:8200/ngax/scripts/angular/angular.min.js:54:384)
   at Anonymous function (http://localhost:8200/ngax/scripts/angular/angular.min.js:53:441)
   at link (http://localhost:8200/ngax/scripts/angular/angular-route.min.js:7:408)
   at Y (http://localhost:8200/ngax/scripts/angular/angular.min.js:73:89)
   at S (http://localhost:8200/ngax/scripts/angular/angular.min.js:62:52) <div class="content ng-scope" style="width: 100%" ng-view="">
In IE, I can’t see any errors. When accessing the web page, the login window shows up instantly. Alter entering the password, for about half a second, the page name in the IE tab is Backup and changes back to localhost. After 2-4 seconds I get the The page is not loaded message. Clicking the Reload page button of refreshing the page (F5/Ctrl+F5) doesn’t help.
Not entirely sure why this would happen suddenly.
The build failed half-way through so I restarted the build. It could have uploaded some broken files, but the signature should be valid.
Assuming the network is otherwise working fine, it seems to indicate that the updater URL is broken. I hope this is not a broken beta build …
Could you try running Duplicati.Library.AutoUpdater.exe and see what URLs it reports using?
That does indicate some problems with IE not supporting the JS features. Unfortunately we only have automated testing with FF (which is currently failed for other reasons).
It seems Edge does not support catch blocks without parentheses (?)
I remember checking Edge support for some of the things I wrote, not all though. I’d guess that fixing the catch block would be the only thing needed.
Yes - I suspect an automatic check-for-updates happens when you connect to the UI (or in my case log in) and that would likely show the same errors.
Is this what you need?
# mono /source/appdata/Duplicati/updates/2.0.4.5/Duplicati.Library.AutoUpdater.exe
Usage:
        mono Duplicati.Library.AutoUpdater.exe [LIST|VERIFY|CHECK|INSTALL|HELP]
Environment variables:
AUTOUPDATER_Duplicati_SKIP_UPDATE - Disables updates completely
AUTOUPDATER_Duplicati_POLICY - Choose how to handle updates, valid settings: CheckBefore, CheckDuring, CheckAfter, InstallBefore, InstallDuring, InstallAfter, Never
AUTOUPDATER_Duplicati_URLS - Use alternate updates urls
AUTOUPDATER_Duplicati_CHANNEL - Choose different channel than the default Beta, valid settings: Stable,Beta,Experimental,Canary,Nightly,Debug
Updates are downloaded from: https://updates.duplicati.com/beta/latest.manifest;https://alt.updates.duplicati.com/beta/latest.manifest
Updates are installed in: /data/Duplicati/updates
The base version is "2.0.4.5_beta_2018-11-28" (2.0.4.5) and is installed in: /source/appdata/Duplicati/updates/2.0.4.5
This version is "2.0.4.5_beta_2018-11-28" (2.0.4.5) and is installed in: /source/appdata/Duplicati/updates/2.0.4.5
I guess I should’ve taken your word for it originally.
That is fine, I have not set up the alt.updates.duplicati.com DNS, so at least that part is not a problem.
Yes, it shows the correct url’s so at least that is good.
@kees-z and @kenkendk
I’ve fixed the problem with Edge (along with other stuff in backup-log-view, a PR will come soon).
I’ve also done a large refactoring to support old IE
