I found the bug report. It’s 2.6 Gb. Do you want me to upload it somehwere ? I also installed an SQL client so I can open the tables.
Here is what I have in About > Show log > Stored:
31 oct. 2023 13:04: Failed while executing “Verify” with id: 2
Duplicati.Library.Interface.UserInformationException: Unexpected difference in fileset version 8: 29.09.2023 13:00:00 (database id: 5), found 317826 entries, but expected 317891
at Duplicati.Library.Main.Database.LocalDatabase.VerifyConsistency (System.Int64 blocksize, System.Int64 hashsize, System.Boolean verifyfilelists, System.Data.IDbTransaction transaction) [0x0036e] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Operation.TestHandler.Run (System.Int64 samples) [0x0009f] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Controller+<>c__DisplayClass30_0.b__0 (Duplicati.Library.Main.TestResults result) [0x0001c] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String& paths, Duplicati.Library.Utility.IFilter& filter, System.Action1[T] method) [0x0026f] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.Action1[T] method) [0x00009] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Controller.Test (System.Int64 samples) [0x0004b] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Server.Runner.Run (Duplicati.Server.Runner+IRunnerData data, System.Boolean fromQueue) [0x00423] in <30a34d71126b48248d040dda634ddad9>:0
31 oct. 2023 12:00: Failed while executing “Backup” with id: 2
at Duplicati.Library.Main.Operation.Backup.BackupDatabase+<>c__DisplayClass34_0.b__0 () [0x00000] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Operation.Common.SingleRunner+<>c__DisplayClass3_0.b__0 () [0x00000] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Operation.Common.SingleRunner.DoRunOnMain[T] (System.Func1[TResult] method) [0x000b0] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x01048] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at CoCoL.ChannelExtensions.WaitForTaskOrThrow (System.Threading.Tasks.Task task) [0x00050] in <9a758ff4db6c48d6b3d4d0e5c2adf6d1>:0 at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00009] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Controller+<>c__DisplayClass14_0.<Backup>b__0 (Duplicati.Library.Main.BackupResults result) [0x0004b] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action1[T] method) [0x0026f] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Controller.Backup (System.String inputsources, Duplicati.Library.Utility.IFilter filter) [0x00074] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Server.Runner.Run (Duplicati.Server.Runner+IRunnerData data, System.Boolean fromQueue) [0x00349] in <30a34d71126b48248d040dda634ddad9>:0
31 oct. 2023 11:05: Failed while executing “Backup” with id: 2
23 oct. 2023 13:01: Failed while executing “Backup” with id: 2
21 oct. 2023 23:05: Failed while executing “Backup” with id: 2
System.AggregateException: One or more errors occurred. (Error: NameResolutionFailure (Error: NameResolutionFailure) (One or more errors occurred. (Error: NameResolutionFailure))) —> System.AggregateException: Error: NameResolutionFailure (Error: NameResolutionFailure) (One or more errors occurred. (Error: NameResolutionFailure)) —> System.Net.WebException: Error: NameResolutionFailure
at System.Net.WebConnection.Connect (System.Net.WebOperation operation, System.Threading.CancellationToken cancellationToken) [0x00079] in :0
at System.Net.WebConnection.InitConnection (System.Net.WebOperation operation, System.Threading.CancellationToken cancellationToken) [0x000f7] in :0
at System.Net.WebOperation.Run () [0x000b7] in :0
at System.Net.WebCompletionSource1[T].WaitForCompletion () [0x000b1] in <a85c1a570f9a4f9f9c3d2cfa5504e34f>:0 at System.Net.HttpWebRequest.GetRequestStream () [0x00019] in <a85c1a570f9a4f9f9c3d2cfa5504e34f>:0 at Duplicati.Library.Backend.OpenStack.OpenStackStorage.GetKeystone3AuthResponse () [0x00075] in <8ed6d878db2a461590a428d1b94243cf>:0 at Duplicati.Library.Backend.OpenStack.OpenStackStorage.GetAuthResponse () [0x00023] in <8ed6d878db2a461590a428d1b94243cf>:0 at Duplicati.Library.Backend.OpenStack.OpenStackStorage.get_SimpleStorageEndPoint () [0x00008] in <8ed6d878db2a461590a428d1b94243cf>:0 at Duplicati.Library.Backend.OpenStack.OpenStackStorage.PutAsync (System.String remotename, System.IO.Stream stream, System.Threading.CancellationToken cancelToken) [0x00011] in <8ed6d878db2a461590a428d1b94243cf>:0 at Duplicati.Library.Main.Operation.Backup.BackendUploader.DoPut (Duplicati.Library.Main.Operation.Common.BackendHandler+FileEntryItem item, Duplicati.Library.Interface.IBackend backend, System.Threading.CancellationToken cancelToken) [0x00426] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Operation.Backup.BackendUploader+<>c__DisplayClass20_0.<UploadFileAsync>b__0 () [0x0010a] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Operation.Backup.BackendUploader.DoWithRetry (System.Func1[TResult] method, Duplicati.Library.Main.Operation.Common.BackendHandler+FileEntryItem item, Duplicati.Library.Main.Operation.Backup.BackendUploader+Worker worker, System.Threading.CancellationToken cancelToken) [0x00198] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Operation.Backup.BackendUploader.DoWithRetry (System.Func1[TResult] method, Duplicati.Library.Main.Operation.Common.BackendHandler+FileEntryItem item, Duplicati.Library.Main.Operation.Backup.BackendUploader+Worker worker, System.Threading.CancellationToken cancelToken) [0x003c1] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Operation.Backup.BackendUploader.UploadFileAsync (Duplicati.Library.Main.Operation.Common.BackendHandler+FileEntryItem item, Duplicati.Library.Main.Operation.Backup.BackendUploader+Worker worker, System.Threading.CancellationToken cancelToken) [0x000da] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Operation.Backup.BackendUploader.UploadBlockAndIndexAsync (Duplicati.Library.Main.Operation.Backup.VolumeUploadRequest upload, Duplicati.Library.Main.Operation.Backup.BackendUploader+Worker worker, System.Threading.CancellationToken cancelToken) [0x00098] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Operation.Backup.BackendUploader.<Run>b__13_0 (<>f__AnonymousType121[j__TPar] self) [0x00780] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Operation.Backup.BackendUploader.b__13_0 (<>f__AnonymousType121[<Input>j__TPar] self) [0x007d7] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at CoCoL.AutomationExtensions.RunTask[T] (T channels, System.Func2[T,TResult] method, System.Boolean catchRetiredExceptions) [0x000d5] in <9a758ff4db6c48d6b3d4d0e5c2adf6d1>:0
at Duplicati.Library.Main.Operation.BackupHandler.FlushBackend (Duplicati.Library.Main.BackupResults result, CoCoL.IWriteChannel1[T] uploadtarget, System.Threading.Tasks.Task uploader) [0x000f2] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00cb2] in <9cab5b8f1b4f49ec980acae8e278968b>:0 --- End of inner exception stack trace --- at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x01048] in <9cab5b8f1b4f49ec980acae8e278968b>:0 --- End of inner exception stack trace --- at CoCoL.ChannelExtensions.WaitForTaskOrThrow (System.Threading.Tasks.Task task) [0x0005d] in <9a758ff4db6c48d6b3d4d0e5c2adf6d1>:0 at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00009] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Controller+<>c__DisplayClass14_0.<Backup>b__0 (Duplicati.Library.Main.BackupResults result) [0x0004b] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action1[T] method) [0x0026f] in <9cab5b8f1b4f49ec980acae8e278968b>:0
—> (Inner Exception #0) System.AggregateException: Error: NameResolutionFailure (Error: NameResolutionFailure) (One or more errors occurred. (Error: NameResolutionFailure)) —> System.Net.WebException: Error: NameResolutionFailure
at Duplicati.Library.Main.Operation.BackupHandler.FlushBackend (Duplicati.Library.Main.BackupResults result, CoCoL.IWriteChannel1[T] uploadtarget, System.Threading.Tasks.Task uploader) [0x000f2] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00cb2] in <9cab5b8f1b4f49ec980acae8e278968b>:0 --- End of inner exception stack trace --- at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x01048] in <9cab5b8f1b4f49ec980acae8e278968b>:0 ---> (Inner Exception #0) System.Net.WebException: Error: NameResolutionFailure at System.Net.WebConnection.Connect (System.Net.WebOperation operation, System.Threading.CancellationToken cancellationToken) [0x00079] in <a85c1a570f9a4f9f9c3d2cfa5504e34f>:0 at System.Net.WebConnection.InitConnection (System.Net.WebOperation operation, System.Threading.CancellationToken cancellationToken) [0x000f7] in <a85c1a570f9a4f9f9c3d2cfa5504e34f>:0 at System.Net.WebOperation.Run () [0x000b7] in <a85c1a570f9a4f9f9c3d2cfa5504e34f>:0 at System.Net.WebCompletionSource1[T].WaitForCompletion () [0x000b1] in :0
at System.Net.HttpWebRequest.GetRequestStream () [0x00019] in :0
at Duplicati.Library.Main.Operation.Backup.BackendUploader+<>c__DisplayClass20_0.b__0 () [0x0010a] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Operation.Backup.BackendUploader.DoWithRetry (System.Func1[TResult] method, Duplicati.Library.Main.Operation.Common.BackendHandler+FileEntryItem item, Duplicati.Library.Main.Operation.Backup.BackendUploader+Worker worker, System.Threading.CancellationToken cancelToken) [0x00198] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Operation.Backup.BackendUploader.DoWithRetry (System.Func1[TResult] method, Duplicati.Library.Main.Operation.Common.BackendHandler+FileEntryItem item, Duplicati.Library.Main.Operation.Backup.BackendUploader+Worker worker, System.Threading.CancellationToken cancelToken) [0x003c1] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Operation.Backup.BackendUploader.b__13_0 (<>f__AnonymousType121[<Input>j__TPar] self) [0x00780] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Operation.Backup.BackendUploader.<Run>b__13_0 (<>f__AnonymousType121[j__TPar] self) [0x007d7] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at CoCoL.AutomationExtensions.RunTask[T] (T channels, System.Func2[T,TResult] method, System.Boolean catchRetiredExceptions) [0x000d5] in <9a758ff4db6c48d6b3d4d0e5c2adf6d1>:0 at Duplicati.Library.Main.Operation.BackupHandler.FlushBackend (Duplicati.Library.Main.BackupResults result, CoCoL.IWriteChannel1[T] uploadtarget, System.Threading.Tasks.Task uploader) [0x000f2] in <9cab5b8f1b4f49ec980acae8e278968b>:0
at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00cb2] in <9cab5b8f1b4f49ec980acae8e278968b>:0 <—
—> (Inner Exception #1) System.AggregateException: One or more errors occurred. (Error: NameResolutionFailure) —> System.Net.WebException: Error: NameResolutionFailure
at Duplicati.Library.Main.Operation.BackupHandler.FlushBackend (Duplicati.Library.Main.BackupResults result, CoCoL.IWriteChannel1[T] uploadtarget, System.Threading.Tasks.Task uploader) [0x000f2] in <9cab5b8f1b4f49ec980acae8e278968b>:0 at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00cb2] in <9cab5b8f1b4f49ec980acae8e278968b>:0 --- End of inner exception stack trace --- ---> (Inner Exception #0) System.Net.WebException: Error: NameResolutionFailure at System.Net.WebConnection.Connect (System.Net.WebOperation operation, System.Threading.CancellationToken cancellationToken) [0x00079] in <a85c1a570f9a4f9f9c3d2cfa5504e34f>:0 at System.Net.WebConnection.InitConnection (System.Net.WebOperation operation, System.Threading.CancellationToken cancellationToken) [0x000f7] in <a85c1a570f9a4f9f9c3d2cfa5504e34f>:0 at System.Net.WebOperation.Run () [0x000b7] in <a85c1a570f9a4f9f9c3d2cfa5504e34f>:0 at System.Net.WebCompletionSource1[T].WaitForCompletion () [0x000b1] in :0
21 oct. 2023 13:02: Failed while executing “Backup” with id: 2
21 oct. 2023 10:58: Error in updater
System.Net.WebException: The operation has timed out.
at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x00118] in :0
at System.Net.HttpWebRequest.GetResponse () [0x00019] in :0
at System.Net.WebClient.GetWebResponse (System.Net.WebRequest request) [0x00000] in :0
at System.Net.WebClient.DownloadBits (System.Net.WebRequest request, System.IO.Stream writeStream) [0x0011c] in :0
at System.Net.WebClient.DownloadFile (System.Uri address, System.String fileName) [0x00091] in :0
at System.Net.WebClient.DownloadFile (System.String address, System.String fileName) [0x00008] in :0
at (wrapper remoting-invoke-with-check) System.Net.WebClient.DownloadFile(string,string)
at Duplicati.Library.AutoUpdater.UpdaterManager.CheckForUpdate (Duplicati.Library.AutoUpdater.ReleaseType channel) [0x000ee] in <9efd42ee8b654a7fb96bd8662c263dad>:0
