I have 4!!! corrupt backups (out of 9 tested until now). AGAIN. It is the third time. The first 2 backups were on hubiC. Now it is a small backup on Dropbox, one on hubiC, one on box and one on a local USB-Drive I loose my confidence in Duplicati.
First: Dropbox
I downloaded the remote backup and made a restore of version 1 and got this:
Operation Get with file duplicati-b8903ffb010ac41c79fdb5eebff19b4f8.dblock.zip.aes attempt 1 of 5 failed with message: Invalid header marker => Invalid header marker
Downloading file (9,95 MB) ...
Operation Get with file duplicati-b8903ffb010ac41c79fdb5eebff19b4f8.dblock.zip.aes attempt 2 of 5 failed with message: Invalid header marker => Invalid header marker
Operation Get with file duplicati-b8903ffb010ac41c79fdb5eebff19b4f8.dblock.zip.aes attempt 3 of 5 failed with message: Invalid header marker => Invalid header marker
Operation Get with file duplicati-b8903ffb010ac41c79fdb5eebff19b4f8.dblock.zip.aes attempt 4 of 5 failed with message: Invalid header marker => Invalid header marker
Operation Get with file duplicati-b8903ffb010ac41c79fdb5eebff19b4f8.dblock.zip.aes attempt 5 of 5 failed with message: Invalid header marker => Invalid header marker
Downloading file (4,39 MB) ...
Failed to patch with remote file: "duplicati-b8903ffb010ac41c79fdb5eebff19b4f8.dblock.zip.aes", message: Invalid header marker => Invalid header marker
Downloading file (3,39 MB) ...
I made a binary compare of the local copy with the one on dropbox. The whole backup is binary identical.
The end of the restore shows
Downloading file (204,31 KB) ...
Downloading file (5,10 MB) ...
Downloading file (3,45 MB) ...
0 files need to be restored (0 Bytes)
Verifying restored files ...
Restored 616 (180,87 MB) files to z:\temp\restoreV2
Duration of restore: 00:01:59
So I have 616 files restored. One backup file has an invalid header marker but there is no information what this means for the restore process. Are some files not restored? Are some files restored in an older version?
Seconds conspicuity: If I list version 1 I get the information that the version has 615! not 616 files like restored:
Z:\temp\dropbox-01_HASHTEST>"c:\Program Files\Duplicati 2\Duplicati.CommandLine.exe" list .\ --version=1 --dbpath=C:\Us
Listing filesets:
1 : 23.02.2018 07:58:48 (615 files, 180,87 MB)
If I list version 1 with * for all files I get also 615 and not 616 files. So one file was restored but is not shown in the list? How is that possible?
list-broken-files shows everything is ok:
Z:\temp\dropbox-01_HASHTEST>"c:\Program Files\Duplicati 2\Duplicati.CommandLine.exe" list-broken-files .\ --dbpath=C:
No broken filesets found in database, checking for missing remote files
Listing remote folder ...
Skipping operation because no files were found to be missing, and no filesets were recorded as broken.
Second a hubiC backup with 28 GB (15 MB data files), checked with verify and parameter “all”:
Downloading file (22,03 KB) ...
Operation Get with file duplicati-i68ec60a4bc9e4893860028dd0fb898ae.dindex.zip.aes attempt 1 of 5 failed with message: Die angefragte Datei existiert nicht => Die angefragte Datei existiert nicht
Operation Get with file duplicati-i68ec60a4bc9e4893860028dd0fb898ae.dindex.zip.aes attempt 2 of 5 failed with message: Die angefragte Datei existiert nicht => Die angefragte Datei existiert nicht
Operation Get with file duplicati-i68ec60a4bc9e4893860028dd0fb898ae.dindex.zip.aes attempt 3 of 5 failed with message: Die angefragte Datei existiert nicht => Die angefragte Datei existiert nicht
Operation Get with file duplicati-i68ec60a4bc9e4893860028dd0fb898ae.dindex.zip.aes attempt 4 of 5 failed with message: Die angefragte Datei existiert nicht => Die angefragte Datei existiert nicht
Operation Get with file duplicati-i68ec60a4bc9e4893860028dd0fb898ae.dindex.zip.aes attempt 5 of 5 failed with message: Die angefragte Datei existiert nicht => Die angefragte Datei existiert nicht
Failed to process file duplicati-i68ec60a4bc9e4893860028dd0fb898ae.dindex.zip.aes => Die angefragte Datei existiert nicht
Downloading file (877 Bytes) ...
Downloading file (9,04 KB) ...
Downloading file (12,58 KB) ...
Downloading file (9,45 KB) ...
Downloading file (8,11 KB) ...
Downloading file (14,95 MB) ...
Operation Get with file duplicati-b475693647b054408a162c6542fe2ec80.dblock.zip.aes attempt 1 of 5 failed with message: Die angefragte Datei existiert nicht => Die angefragte Datei existiert nicht
Operation Get with file duplicati-b475693647b054408a162c6542fe2ec80.dblock.zip.aes attempt 2 of 5 failed with message: Die angefragte Datei existiert nicht => Die angefragte Datei existiert nicht
Operation Get with file duplicati-b475693647b054408a162c6542fe2ec80.dblock.zip.aes attempt 3 of 5 failed with message: Die angefragte Datei existiert nicht => Die angefragte Datei existiert nicht
Operation Get with file duplicati-b475693647b054408a162c6542fe2ec80.dblock.zip.aes attempt 4 of 5 failed with message: Die angefragte Datei existiert nicht => Die angefragte Datei existiert nicht
Operation Get with file duplicati-b475693647b054408a162c6542fe2ec80.dblock.zip.aes attempt 5 of 5 failed with message: Die angefragte Datei existiert nicht => Die angefragte Datei existiert nicht
Failed to process file duplicati-b475693647b054408a162c6542fe2ec80.dblock.zip.aes => Die angefragte Datei existiert nicht
Downloading file (14,97 MB) ...
Downloading file (14,94 MB) ...
Downloading file (14,93 MB) ...
Operation Get with file duplicati-ba707c45d4ec5460ba53682c4d0de2edf.dblock.zip.aes attempt 1 of 5 failed with message: Die angefragte Datei existiert nicht => Die angefragte Datei existiert nicht
Downloading file (14,90 MB) ...
Operation Get with file duplicati-ba707c45d4ec5460ba53682c4d0de2edf.dblock.zip.aes attempt 2 of 5 failed with message: Die angefragte Datei existiert nicht => Die angefragte Datei existiert nicht
Operation Get with file duplicati-ba707c45d4ec5460ba53682c4d0de2edf.dblock.zip.aes attempt 3 of 5 failed with message: Die angefragte Datei existiert nicht => Die angefragte Datei existiert nicht
Operation Get with file duplicati-ba707c45d4ec5460ba53682c4d0de2edf.dblock.zip.aes attempt 4 of 5 failed with message: Die angefragte Datei existiert nicht => Die angefragte Datei existiert nicht
Operation Get with file duplicati-ba707c45d4ec5460ba53682c4d0de2edf.dblock.zip.aes attempt 5 of 5 failed with message: Die angefragte Datei existiert nicht => Die angefragte Datei existiert nicht
Failed to process file duplicati-ba707c45d4ec5460ba53682c4d0de2edf.dblock.zip.aes => Die angefragte Datei existiert nicht
Downloading file (14,96 MB) ...
Downloading file (14,99 MB) ...
still running but index files are missing and data files are missing.
The hubiC space is only used by Duplicati. No other programm has access and also do not access it by web access.
Third the local USB-Backup I have this verification error
Downloading file (499,98 MB) ...
Downloading file (499,99 MB) ...
Operation Get with file duplicati-b6320983bc03b40188d8dbcfb8283daec.dblock.zip.aes attempt 1 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-b6320983bc03b40188d8dbcfb8283daec.dblock.zip.aes attempt 2 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-b6320983bc03b40188d8dbcfb8283daec.dblock.zip.aes attempt 3 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-b6320983bc03b40188d8dbcfb8283daec.dblock.zip.aes attempt 4 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-b6320983bc03b40188d8dbcfb8283daec.dblock.zip.aes attempt 5 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Failed to process file duplicati-b6320983bc03b40188d8dbcfb8283daec.dblock.zip.aes => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
There was no password change. This filed was backuped up continous as you can see on the timestamps:
Fourth: box cloud. Also error with password in about 40!!! Files and Header error in some other files??? Downloaded so of the files again and compared them. No download problem. Files matched:
Downloading file (14,92 MB) ...
Downloading file (14,91 MB) ...
Operation Get with file duplicati-bab7462f605304ad8bf29f59a16607471.dblock.zip.aes attempt 1 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-bab7462f605304ad8bf29f59a16607471.dblock.zip.aes attempt 2 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-bab7462f605304ad8bf29f59a16607471.dblock.zip.aes attempt 3 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-bab7462f605304ad8bf29f59a16607471.dblock.zip.aes attempt 4 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-bab7462f605304ad8bf29f59a16607471.dblock.zip.aes attempt 5 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Failed to process file duplicati-bab7462f605304ad8bf29f59a16607471.dblock.zip.aes => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-bac4b1e25b48d4cb0a430cde90e5032b8.dblock.zip.aes attempt 1 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-bac4b1e25b48d4cb0a430cde90e5032b8.dblock.zip.aes attempt 2 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-bac4b1e25b48d4cb0a430cde90e5032b8.dblock.zip.aes attempt 3 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-bac4b1e25b48d4cb0a430cde90e5032b8.dblock.zip.aes attempt 4 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-bac4b1e25b48d4cb0a430cde90e5032b8.dblock.zip.aes attempt 5 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Failed to process file duplicati-bac4b1e25b48d4cb0a430cde90e5032b8.dblock.zip.aes => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-babfa94f297584ea8b41481f7cdc2c687.dblock.zip.aes attempt 1 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-babfa94f297584ea8b41481f7cdc2c687.dblock.zip.aes attempt 2 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-babfa94f297584ea8b41481f7cdc2c687.dblock.zip.aes attempt 3 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-babfa94f297584ea8b41481f7cdc2c687.dblock.zip.aes attempt 4 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-babfa94f297584ea8b41481f7cdc2c687.dblock.zip.aes attempt 5 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Failed to process file duplicati-babfa94f297584ea8b41481f7cdc2c687.dblock.zip.aes => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-bac94aac9a639408686a76b3e17611bb3.dblock.zip.aes attempt 1 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-bac94aac9a639408686a76b3e17611bb3.dblock.zip.aes attempt 2 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-bac94aac9a639408686a76b3e17611bb3.dblock.zip.aes attempt 3 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-bac94aac9a639408686a76b3e17611bb3.dblock.zip.aes attempt 4 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-bac94aac9a639408686a76b3e17611bb3.dblock.zip.aes attempt 5 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Failed to process file duplicati-bac94aac9a639408686a76b3e17611bb3.dblock.zip.aes => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-bad48a8c0df5340b3b23451db813243ac.dblock.zip.aes attempt 1 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-bad48a8c0df5340b3b23451db813243ac.dblock.zip.aes attempt 2 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-bad48a8c0df5340b3b23451db813243ac.dblock.zip.aes attempt 3 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-bad48a8c0df5340b3b23451db813243ac.dblock.zip.aes attempt 4 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-bad48a8c0df5340b3b23451db813243ac.dblock.zip.aes attempt 5 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Failed to process file duplicati-bad48a8c0df5340b3b23451db813243ac.dblock.zip.aes => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Downloading file (14,98 MB) ...
Operation Get with file duplicati-baeb3779e25564d58b1dd9bf27b296c08.dblock.zip.aes attempt 1 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-baeb3779e25564d58b1dd9bf27b296c08.dblock.zip.aes attempt 2 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-baeb3779e25564d58b1dd9bf27b296c08.dblock.zip.aes attempt 3 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-baeb3779e25564d58b1dd9bf27b296c08.dblock.zip.aes attempt 4 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Operation Get with file duplicati-baeb3779e25564d58b1dd9bf27b296c08.dblock.zip.aes attempt 5 of 5 failed with message: Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Failed to process file duplicati-baeb3779e25564d58b1dd9bf27b296c08.dblock.zip.aes => Fehler beim Entschlüsseln der Daten (ungültige Passphrase?): Message has been altered, do not trust content
Downloading file (15,00 MB) ...
Failed to process file duplicati-bd3160fb5ec674ca29151626dfcd85c5a.dblock.zip.aes => Invalid header marker
Operation Get with file duplicati-bd335faf5aed0436ea9c593e2fc443ea2.dblock.zip.aes attempt 1 of 5 failed with message: Invalid header marker => Invalid header marker
Operation Get with file duplicati-bd335faf5aed0436ea9c593e2fc443ea2.dblock.zip.aes attempt 2 of 5 failed with message: Invalid header marker => Invalid header marker
Operation Get with file duplicati-bd335faf5aed0436ea9c593e2fc443ea2.dblock.zip.aes attempt 3 of 5 failed with message: Invalid header marker => Invalid header marker
Operation Get with file duplicati-bd335faf5aed0436ea9c593e2fc443ea2.dblock.zip.aes attempt 4 of 5 failed with message: Invalid header marker => Invalid header marker
Operation Get with file duplicati-bd335faf5aed0436ea9c593e2fc443ea2.dblock.zip.aes attempt 5 of 5 failed with message: Invalid header marker => Invalid header marker
Failed to process file duplicati-bd335faf5aed0436ea9c593e2fc443ea2.dblock.zip.aes => Invalid header marker
I tested 9 backups (4 local, 2 dropbox, 1 google, 1 hubic, 1 box) and 1 local, 1 dropbox, 1 box and 1 hubic are not VALID and I have 3 DIFFERENT ERRORS.
And an update. Through the night a verify was running with a fourth type of error after I tried to repair the local copy (purged missing files and compacted, lost about 3 GB of backup data) and after that I got this in the next verify run:
duplicati-i09b06d5f94c9499b951ef3efee17dee9.dindex.zip.aes: 231 errors
Extra: ++wm+4zckBAdHA7CmTlIQryZCiARWNWQJ8uV1AI15a4=
Extra: +1rxoqQHHGGnaLoXeIPNizkJwdTBQG0D+bPrRiddw6k=
Extra: +88ktIZ7Rg+Q9ZcD2yKh7MZebvdS8qX13a5oP3/FcNo=
Extra: +M+kApPYv6Dn825WoeI5LmYbps/5lDs5DctsJ0Sk08Q=
Extra: +Ta1Pbe+OllErqqjGeklDKkDFayYaLW928q9diajB5Y=
Extra: +UDT87KLfYo3qLw4gzBPqyPX90FyhA70M5s8ehaQgD4=
Extra: +Z2l0yfRqAlwPhTNyGX+Cr1z8JxkgoU6+ieuGPcal+U=
Extra: +ygUSu21/+IMlD02fKdP3TIaJzWd07WA3bR0BtYjlvw=
Extra: /D+GBeIYpP/oWJ52SWQ24DnLrE+kKq4mZl+yNSPrRxY=
Extra: 0PzoO8YpHtY2ezp1RQoHfYmqoBngiu2v5EHPPcoDB6M=
... and 221 more
duplicati-i1a80950bbe894bada039e09de83c406e.dindex.zip.aes: 366 errors
Extra: +DInLAcULQ0vl6THYJx9P/qs76jUnRoT93ohxleCn7A=
Extra: +GT/LtND4iOBF0TeVployBw2wy1aeknFBKMJQPFHPGU=
Extra: +WToBY5GHcDqLmwlcKg+384gfa8eH76ZaXdJqgqcEoY=
Extra: +ZsPLlnq9XsGS9QElZ2snzwkOojkojXxIGX5xbT4TJo=
Extra: +dDXLdWa/G8Dw9gFV9tE987KkP/UduROqxNUSu/Oktw=
Extra: +gUmtcfnW+IJuN1PtcCkZ7+OmbN5iG9QyxKUBeCVyYw=
Extra: /2Inq3ughHFYo3BA3o8a5rXj4Yz8Jlr2FyqacuUBLIY=
Extra: /EOcj50yQOy/cK0vm6YAqioE7DN66b7frs2zOxH9X+Y=
Extra: /PY/D6CZ+qEnMBx8AvsWbhVpzK6Eroj4hnIuY2O5FnI=
Extra: /aHnN9lKZU+uHjjNSVOROOh2TP+Q0wAAndnzuzCQaWs=
... and 356 more
duplicati-ia99a5b7f77164687a10f507e208af137.dindex.zip.aes: 529 errors
Extra: +/OV0qexHY3UyGoyLHCLAvdfy5LxJ7utaBjTPjvH55A=
Extra: +55/6jyLbjYApFperxGIxBNvCEWLR0mLt9wKwKzBYU8=
Extra: +AwUO7fEgRDEYJmUeyn8pQtBnbiqZJCFv3xpUcmSvIw=
Extra: +IRt/guNtrmL+UOWonetuv+x+xUOR/WqwwOB+lBFsZI=
Extra: +Lb4aYZdp3Y2TE9bUpxrfjXtOOZ4Mj4KDdoi+92ic4c=
Extra: +P6RlB3JukC6GkFaQVrTBACJ3U3yi8hW3y7UtaTNjpc=
Extra: +T1sgiHLGZ0ylUR1TQ7G99m8Gt6vBvXr3M3Dv9m87/A=
Extra: +nuuDZsmJ3g6diXiTML+/gPxAPLlEOFRL0S1r3lDnU0=
Extra: +tAGOsxOHUlD2+wwyN2IvI33jvpMlUqxzz2uo8CzaqI=
Extra: +wj+GaR3KbEO8QfxuJEa4IhDBtZb5I3DyNK9otYtRxM=
... and 519 more
duplicati-if9b1d8c6c3b24ec4af6b5c672e5eb357.dindex.zip.aes: 154 errors
Extra: +0KbR2e1vqXjPuf+FBwTQJDtK4AqcepBUn12NCUUxw8=
Extra: +8dSVkffU9K3lDfv08cEjCj4ZEVVvn64h5sXpZoFUTg=
Extra: +QR3FSvTeaM6iAo7j/fOsc8ZWXG7gBfMg36B6l554NU=
Extra: +dobI5wZFyQIBOe0iz3AF0CHD9hRMmNL/BIjjQv4DNQ=
Extra: +v+4PBjjFc7qLiACa0DgBeEzmSqwITyCwGk+BBjk9M8=
Extra: /yRbilOTFR0cSdF6pwMRpHn0Lkx8eG1AabYqSE5bgLY=
Extra: 1T7dEKbDW9Lw9o/0KNdEoXh0ZeO63Z4V5g+jt3ztM64=
Extra: 1Zv928pjaVicvILKNtxx9eHjN6Va0PqnFPweCHTmUOo=
Extra: 27YnI4+L4MtmCzmZjvu4k4k6YGLmqck3XcVHtTlRM7E=
Extra: 2wZlL0F/7ZkZ1nITj5qtVuEM/ycOiWS8+GC020CUec0=
... and 144 more
duplicati-i8595a0e76ecd49aa90f605fd225eb48c.dindex.zip.aes: 404 errors
Extra: +5k/1c+PhguTG9ujdfOPQuJ02NoaJ5t84KXfQqcGIZE=
Extra: +UBpqTPn/IzascwXAcq575isyjaFita3SYVcN/7EGy8=
Extra: +hOpwIAV66a2Wybt1VqY7p3mjt5MHJx3SmtXYB3BZ7I=
Extra: /K9GlU2THNynacS633gfAt8eM4PyHRMOt+HRVr6KiEc=
Extra: /L6KreKQQK8U2bqiIdq2Ven42Z6qZBvQFtnA6rzD6Dk=
Extra: /LvGBIdS4pwlVuoRxMELZjVY0WvXniY3ioYICK3VH/4=
Extra: /fr5Y7awGrcR2U623YOBHnZieQ4EWpUmxqKoHCGuQa0=
Extra: /pTftSBPfQgxPhSl3VDYhC7Sogk6+53Qe971fBPzhfE=
Extra: /yvRcp0NRFtpIVjEVidje/FtJ3j3+Aj8La/m0+NvaKQ=
Extra: 0GcriFMcYHilIUPXt+ZhjNIXoFJFpDtoHtnd79+pPeo=
... and 394 more
duplicati-i026a644b5c504f5ebd23740bb6aecaa1.dindex.zip.aes: 184 errors
Extra: /hnedK2RJUjhozBpP7n/0hOe0OuREAK6X7zXUzJfc64=
Extra: /kQc2WQbCFTb8LiQ/rT1VJhsLiq/vN8ALH4EKujjBeQ=
Extra: /kysCO4JR6Wla0JvRS+sbv48RKIa/RfGsR6YuCxEfkU=
Extra: /tJUVCyNvI6Hobtc09y7sqYSwHEHrjq5u984Kp4EMVk=
Extra: /wRxGauYssnmrjT4W9YeBFY+KZ9p+x5h+5j/0kz4qRs=
Extra: 0BIosy7WKSlesSFQCxspPkVkDFvHCS+sZXS/+gshcWk=
Extra: 11ufw2VQ2ryQS4iPlBoXmtcWKJBry9HMTAoybFcgE5k=
Extra: 195XkfH+W5mEINWe2hnJUt13r780KNQzsUBwv/di1og=
Extra: 2+vlbDj3/XKdLE5fHDWXvaqXP3udi2JYVT08QhSD2lM=
Extra: 2jGrt1Cerrbbuiw4ju/2B9X7FcsR9cXXM99XRlOKK5M=
... and 174 more
How can this happen? First I thought is can be a problem of hubiC but now I have also a corrupt header in the Dropbox and a invalid file in a local backup.
How can I fix this errors?
