Synology installation
I installed duplicati on synology DS218Play latest everything.
  1. install mono (its a beta package)
  2. install the duplicati package manually
  3. Make sure your user is part of the http group
  4. Don’t access duplicati using the connect.to service, but login using the local IP:5000 for some reason it crashes then.
Hi, thanks for that.
I habe a few questions:
Where do i get the Mono Package? Which package source?
Where am i able to download the duplicati package?
I do have a DS213+
Hi @ziguri, welcome to the forum!
This isn’t much, but it’s a start - please flesh it out as you get yours working!
