I’ve been running duplicati-2.0.6.3-2.0.6.3_beta_20210617.noarch on Fedora 35 for at least a month now. It’s been backup up on schedule to a host on my LAN using SFTP. Then about a week ago, the jobs stopped completing. Duplicati itself would crash a little way into the job running. I don’t know what’s useful, so I’ll paste entries from /var/log/messages.
Any help in fixing this will be greatly appreciated.
Aug 9 20:35:42 fedora systemd[1]: Started duplicati.service - Duplicati web-server.
Aug 9 20:35:42 fedora audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=duplicati comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 9 20:59:29 fedora duplicati-server[259594]: mono-sgen: pthread_mutex_lock.c:94: ___pthread_mutex_lock: Assertion `mutex->__data.__owner == 0' failed.
Aug 9 20:59:29 fedora duplicati-server[259594]: =================================================================
Aug 9 20:59:29 fedora duplicati-server[259594]: #011Native Crash Reporting
Aug 9 20:59:29 fedora duplicati-server[259594]: Got a SIGABRT while executing native code. This usually indicates
Aug 9 20:59:29 fedora duplicati-server[259594]: a fatal error in the mono runtime or one of the native libraries
Aug 9 20:59:29 fedora duplicati-server[259594]: used by your application.
Aug 9 20:59:29 fedora duplicati-server[259594]: #011Native stacktrace:
Aug 9 20:59:29 fedora duplicati-server[259594]: #0110x55a74d099028 - /usr/bin/mono-sgen :
Aug 9 20:59:29 fedora duplicati-server[259594]: #0110x55a74d04451e - /usr/bin/mono-sgen :
Aug 9 20:59:29 fedora duplicati-server[259594]: #0110x55a74d09121c - /usr/bin/mono-sgen :
Aug 9 20:59:29 fedora duplicati-server[259594]: #0110x7f93c6e3ea70 - /lib64/libc.so.6 :
Aug 9 20:59:29 fedora duplicati-server[259594]: #0110x7f93c6e8ec4c - /lib64/libc.so.6 :
Aug 9 20:59:29 fedora duplicati-server[259594]: #0110x7f93c6e3e9c6 - /lib64/libc.so.6 : raise
Aug 9 20:59:29 fedora duplicati-server[259594]: #0110x7f93c6e287f4 - /lib64/libc.so.6 : abort
Aug 9 20:59:29 fedora duplicati-server[259594]: #0110x7f93c6e2871b - /lib64/libc.so.6 :
Aug 9 20:59:29 fedora duplicati-server[259594]: #0110x7f93c6e37576 - /lib64/libc.so.6 :
Aug 9 20:59:29 fedora duplicati-server[259594]: #0110x7f93c6e902b0 - /lib64/libc.so.6 : pthread_mutex_lock
Aug 9 20:59:29 fedora duplicati-server[259594]: #0110x7f93c71c6736 - /lib64/libnss_sss.so.2 :
Aug 9 20:59:29 fedora duplicati-server[259594]: #0110x7f93c71c71fe - /lib64/libnss_sss.so.2 :
Aug 9 20:59:29 fedora duplicati-server[259594]: #0110x7f93c71c9036 - /lib64/libnss_sss.so.2 : _nss_sss_getpwuid_r
Aug 9 20:59:29 fedora duplicati-server[259594]: #0110x7f93c6edc631 - /lib64/libc.so.6 : getpwuid_r
Aug 9 20:59:29 fedora duplicati-server[259594]: #0110x7f93bd79b035 - /lib64/libMonoPosixHelper.so : Mono_Posix_Syscall_getpwuid_r
Aug 9 20:59:29 fedora duplicati-server[259594]: #0110x4246a939 - Unknown
Aug 9 20:59:29 fedora duplicati-server[259594]: #011Telemetry Dumper:
Aug 9 20:59:29 fedora duplicati-server[259594]: Pkilling 0x140272281318976x from 0x140271233791552x
[ deleting a whole pile of these ]
Aug 9 20:59:29 fedora duplicati-server[259594]: Pkilling 0x140272495220288x from 0x140271233791552x
Aug 9 20:59:29 fedora duplicati-server[259594]: Entering thread summarizer pause from 0x140271233791552x
Aug 9 20:59:29 fedora duplicati-server[259594]: Finished thread summarizer pause from 0x140271233791552x.
Aug 9 20:59:29 fedora duplicati-server[259594]: Failed to create breadcrumb file (null)/crash_hash_0xfffda88dc3ecd76f
Aug 9 20:59:29 fedora duplicati-server[259594]: Waiting for dumping threads to resume
Aug 9 20:59:30 fedora duplicati-server[265988]: =================================================================
Aug 9 20:59:30 fedora duplicati-server[265988]: #011External Debugger Dump:
Aug 9 20:59:30 fedora duplicati-server[265988]: /usr/bin/gdb: warning: Couldn't determine a path for the index cache directory.
Aug 9 20:59:31 fedora duplicati-server[265988]: [New LWP 259595]
[ Delete another pile ]
Aug 9 20:59:31 fedora duplicati-server[265988]: [New LWP 265927]
Aug 9 20:59:31 fedora duplicati-server[265988]: warning: File "/usr/bin/mono-sgen-gdb.py" auto-loading has been declined by your `auto-load safe-path' set to "$debugdir:$datadir/auto-load".
Aug 9 20:59:31 fedora duplicati-server[265988]: To enable execution of this file add
Aug 9 20:59:31 fedora duplicati-server[265988]: #011add-auto-load-safe-path /usr/bin/mono-sgen-gdb.py
Aug 9 20:59:31 fedora duplicati-server[265988]: line to your configuration file "$HOME/.gdbinit".
Aug 9 20:59:31 fedora duplicati-server[265988]: To completely disable this security protection add
Aug 9 20:59:31 fedora duplicati-server[265988]: #011set auto-load safe-path /
Aug 9 20:59:31 fedora duplicati-server[265988]: For more information about this security protection see the
Aug 9 20:59:31 fedora duplicati-server[265988]: "Auto-loading safe path" section in the GDB manual. E.g., run from the shell:
Aug 9 20:59:31 fedora duplicati-server[265988]: #011info "(gdb)Auto-loading safe path"
Aug 9 20:59:31 fedora duplicati-server[265988]: [Thread debugging using libthread_db enabled]
Aug 9 20:59:31 fedora duplicati-server[265988]: Using host libthread_db library "/lib64/libthread_db.so.1".
Aug 9 20:59:31 fedora duplicati-server[265988]: 0x00007f93c6e89a19 in __futex_abstimed_wait_common () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: Id Target Id Frame
Aug 9 20:59:31 fedora duplicati-server[265988]: * 1 Thread 0x7f93c7089040 (LWP 259594) "mono-sgen" 0x00007f93c6e89a19 in __futex_abstimed_wait_common () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: 2 Thread 0x7f93bfbff640 (LWP 259595) "SGen worker" 0x00007f93c6e89a19 in __futex_abstimed_wait_common () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: 3 Thread 0x7f93bddff640 (LWP 259596) "Finalizer" 0x00007f93c6e89a19 in __futex_abstimed_wait_common () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: 4 Thread 0x7f93bc5fe640 (LWP 259599) "Timer-Scheduler" 0x00007f93c6e89a19 in __futex_abstimed_wait_common () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: 5 Thread 0x7f93bc3fd640 (LWP 259600) "UpdatePollThrea" 0x00007f93c6e89a19 in __futex_abstimed_wait_common () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: 6 Thread 0x7f93affff640 (LWP 259601) "WorkerThread<IR" 0x00007f93c6e89a19 in __futex_abstimed_wait_common () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: 7 Thread 0x7f93afdfe640 (LWP 259602) "TaskScheduler" 0x00007f93c6e89a19 in __futex_abstimed_wait_common () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: 8 Thread 0x7f93af7ff640 (LWP 259603) "mono-sgen" 0x00007f93c6e89a19 in __futex_abstimed_wait_common () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: 9 Thread 0x7f93af3ff640 (LWP 259604) "Thread Pool I/O" 0x00007f93c6f0588f in poll () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: 10 Thread 0x7f93ae9fa640 (LWP 259648) "Thread Pool Wor" 0x00007f93c6f0588f in poll () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: 11 Thread 0x7f93ae3f7640 (LWP 259651) "Thread Pool Wor" 0x00007f93c6e89a19 in __futex_abstimed_wait_common () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: 12 Thread 0x7f93ae1f6640 (LWP 259795) "Backend Async W" 0x00007f93c6e89a19 in __futex_abstimed_wait_common () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: 13 Thread 0x7f9372a5d640 (LWP 259819) "Thread Pool Wor" 0x00007f93c6e89a19 in __futex_abstimed_wait_common () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: 14 Thread 0x7f937265b640 (LWP 259846) "Thread Pool Wor" 0x00007f93c6e89a19 in __futex_abstimed_wait_common () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: 15 Thread 0x7f934bbff640 (LWP 259884) "Thread Pool Wor" 0x00007f93c6e89a19 in __futex_abstimed_wait_common () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: 16 Thread 0x7f9371a55640 (LWP 259898) "Thread Pool Wor" 0x00007f93c6e89a19 in __futex_abstimed_wait_common () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: 17 Thread 0x7f934b7fd640 (LWP 261945) "Thread Pool Wor" 0x00007f93c6e89a19 in __futex_abstimed_wait_common () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: 18 Thread 0x7f93710ff640 (LWP 261946) "Thread Pool Wor" 0x00007f93c6edcbdf in wait4 () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: 19 Thread 0x7f9372259640 (LWP 262747) "Thread Pool Wor" 0x00007f93c6e89a19 in __futex_abstimed_wait_common () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: 20 Thread 0x7f937285c640 (LWP 263261) "Thread Pool Wor" 0x00007f93c6e89a19 in __futex_abstimed_wait_common () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: 21 Thread 0x7f93aedfc640 (LWP 263643) "Thread Pool Wor" 0x00007f93c6e89a19 in __futex_abstimed_wait_common () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: 22 Thread 0x7f93ae5f8640 (LWP 263645) "Thread Pool Wor" 0x00007f93c6e89a19 in __futex_abstimed_wait_common () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: 23 Thread 0x7f9371854640 (LWP 264105) "Thread Pool Wor" 0x00007f93c6e89a19 in __futex_abstimed_wait_common () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: 24 Thread 0x7f93aeffd640 (LWP 264210) "Thread Pool Wor" 0x00007f93c6e89a19 in __futex_abstimed_wait_common () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: 25 Thread 0x7f93af1fe640 (LWP 265927) "Thread Pool I/O" 0x00007f93c6e89a19 in __futex_abstimed_wait_common () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: Thread 25 (Thread 0x7f93af1fe640 (LWP 265927) "Thread Pool I/O"):
Aug 9 20:59:31 fedora duplicati-server[265988]: #0 0x00007f93c6e89a19 in __futex_abstimed_wait_common () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: #1 0x00007f93c6e8c504 in pthread_cond_timedwait@@GLIBC_2.3.2 () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: #2 0x000055a74d302dfe in mono_os_cond_timedwait ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #3 0x000055a74d30c6c4 in sleep_interruptable.lto_priv ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #4 0x000055a74d29f7b7 in monitor_thread ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #5 0x000055a74d24b5a8 in start_wrapper ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #6 0x00007f93c6e8ce2d in start_thread () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: #7 0x00007f93c6f121b0 in clone3 () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: Thread 24 (Thread 0x7f93aeffd640 (LWP 264210) "Thread Pool Wor"):
Aug 9 20:59:31 fedora duplicati-server[265988]: #1 0x00007f93c6e94a3b in __new_sem_wait_slow64.constprop.0 () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: #2 0x000055a74d29e973 in worker_thread ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #3 0x000055a74d24b5a8 in start_wrapper ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #4 0x00007f93c6e8ce2d in start_thread () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: #5 0x00007f93c6f121b0 in clone3 () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: Thread 23 (Thread 0x7f9371854640 (LWP 264105) "Thread Pool Wor"):
Aug 9 20:59:31 fedora duplicati-server[265988]: Thread 22 (Thread 0x7f93ae5f8640 (LWP 263645) "Thread Pool Wor"):
Aug 9 20:59:31 fedora duplicati-server[265988]: Thread 21 (Thread 0x7f93aedfc640 (LWP 263643) "Thread Pool Wor"):
Aug 9 20:59:31 fedora duplicati-server[265988]: #3 0x000055a74d32cfc5 in mono_w32handle_timedwait_signal_handle.constprop ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #4 0x000055a74d260ccb in mono_w32handle_wait_one ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #5 0x000055a74d324482 in mono_w32handle_wait_multiple.constprop ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #6 0x000055a74d1d2c4f in ves_icall_System_Threading_WaitHandle_Wait_internal_raw ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #7 0x0000000041ffad42 in ?? ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #8 0x00007f93bfe030d8 in ?? ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #9 0x00007f93bfe323c0 in ?? ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #10 0x0000000000000000 in ?? ()
Aug 9 20:59:31 fedora duplicati-server[265988]: Thread 20 (Thread 0x7f937285c640 (LWP 263261) "Thread Pool Wor"):
Aug 9 20:59:31 fedora duplicati-server[265988]: Thread 19 (Thread 0x7f9372259640 (LWP 262747) "Thread Pool Wor"):
Aug 9 20:59:31 fedora duplicati-server[265988]: Thread 18 (Thread 0x7f93710ff640 (LWP 261946) "Thread Pool Wor"):
Aug 9 20:59:31 fedora duplicati-server[265988]: #0 0x00007f93c6edcbdf in wait4 () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: #1 0x000055a74d0992ab in dump_native_stacktrace.lto_priv ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #2 0x000055a74d04451e in mono_handle_native_crash ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #3 0x000055a74d09121c in sigabrt_signal_handler ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #4 <signal handler called>
Aug 9 20:59:31 fedora duplicati-server[265988]: #5 0x00007f93c6e8ec4c in __pthread_kill_implementation () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: #6 0x00007f93c6e3e9c6 in raise () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: #7 0x00007f93c6e287f4 in abort () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: #8 0x00007f93c6e2871b in __assert_fail_base.cold () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: #9 0x00007f93c6e37576 in __assert_fail () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: #10 0x00007f93c6e902b0 in pthread_mutex_lock@@GLIBC_2.2.5 () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: #11 0x00007f93c71c6736 in sss_nss_mc_get_ctx () from /lib64/libnss_sss.so.2
Aug 9 20:59:31 fedora duplicati-server[265988]: #12 0x00007f93c71c71fe in sss_nss_mc_getpwuid () from /lib64/libnss_sss.so.2
Aug 9 20:59:31 fedora duplicati-server[265988]: #13 0x00007f93c71c9036 in _nss_sss_getpwuid_r () from /lib64/libnss_sss.so.2
Aug 9 20:59:31 fedora duplicati-server[265988]: #14 0x00007f93c6edc631 in getpwuid_r@@GLIBC_2.2.5 () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: #15 0x00007f93bd79b035 in Mono_Posix_Syscall_getpwuid_r () from /lib64/libMonoPosixHelper.so
Aug 9 20:59:31 fedora duplicati-server[265988]: #16 0x000000004246a939 in ?? ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #17 0x00007f93c6de8310 in ?? ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #18 0x00007f93bfd71358 in ?? ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #19 0x00000000000003e8 in ?? ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #20 0x00007f93bfd75008 in ?? ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #21 0x00007f93710fd0f8 in ?? ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #22 0x00007f93bfd71690 in ?? ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #23 0x00007f93bfd71440 in ?? ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #24 0x00007f93710fe7f8 in ?? ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #25 0x00007f93710fd1c0 in ?? ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #26 0x00007f93710fd020 in ?? ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #27 0x0000000000000000 in ?? ()
Aug 9 20:59:31 fedora duplicati-server[265988]: Thread 17 (Thread 0x7f934b7fd640 (LWP 261945) "Thread Pool Wor"):
Aug 9 20:59:31 fedora duplicati-server[265988]: Thread 16 (Thread 0x7f9371a55640 (LWP 259898) "Thread Pool Wor"):
Aug 9 20:59:31 fedora duplicati-server[265988]: Thread 15 (Thread 0x7f934bbff640 (LWP 259884) "Thread Pool Wor"):
Aug 9 20:59:31 fedora duplicati-server[265988]: Thread 14 (Thread 0x7f937265b640 (LWP 259846) "Thread Pool Wor"):
Aug 9 20:59:31 fedora duplicati-server[265988]: Thread 13 (Thread 0x7f9372a5d640 (LWP 259819) "Thread Pool Wor"):
Aug 9 20:59:31 fedora duplicati-server[265988]: Thread 12 (Thread 0x7f93ae1f6640 (LWP 259795) "Backend Async W"):
Aug 9 20:59:31 fedora duplicati-server[265988]: #1 0x00007f93c6e8c210 in pthread_cond_wait@@GLIBC_2.3.2 () from /lib64/libc.so.6
Aug 9 20:59:31 fedora duplicati-server[265988]: #2 0x000055a74d302e5d in mono_os_cond_timedwait ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #4 0x000055a74d260af7 in mono_w32handle_wait_one ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #8 0x00007f93bfffb620 in ?? ()
Aug 9 20:59:31 fedora duplicati-server[265988]: #9 0x00007f93ac7ab950 in ?? ()
Aug 9 20:59:31 fedora duplicati-server[265988]: Thread 11 (Thread 0x7f93ae3f7640 (LWP 259651) "Thread Pool Wor"):
[ Deleting many lines of logs because my post is too large ]
Aug 9 20:59:31 fedora duplicati-server[259594]: #011Basic Fault Address Reporting
Aug 9 20:59:31 fedora duplicati-server[259594]: =================================================================
Aug 9 20:59:31 fedora duplicati-server[259594]: Memory around native instruction pointer (0x7f93c6e8ec4c):0x7f93c6e8ec3c 04 00 44 89 e2 89 de 89 c7 b8 ea 00 00 00 0f 05 ..D.............
Aug 9 20:59:31 fedora duplicati-server[259594]: 0x7f93c6e8ec4c 89 c5 f7 dd 3d 00 f0 ff ff b8 00 00 00 00 0f 47 ....=..........G
Aug 9 20:59:31 fedora duplicati-server[259594]: 0x7f93c6e8ec5c c5 e9 70 ff ff ff 66 0f 1f 44 00 00 4c 89 ef e8 ..p...f..D..L...
Aug 9 20:59:31 fedora duplicati-server[259594]: 0x7f93c6e8ec6c 10 b0 ff ff e9 44 ff ff ff 0f 1f 00 4c 89 ef e8 .....D......L...
Aug 9 20:59:31 fedora duplicati-server[259594]: #011Managed Stacktrace:
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at <unknown> <0xffffffff>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at Mono.Unix.Native.Syscall:sys_getpwuid_r <0x000a8>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at Mono.Unix.Native.Syscall:getpwuid_r <0x00077>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at Mono.Unix.UnixUserInfo:.ctor <0x00087>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at Mono.Unix.UnixFileSystemInfo:get_OwnerUser <0x0006b>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at FileInfo:.ctor <0x000b3>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at UnixSupport.File:GetUserGroupAndPermissions <0x00057>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at Duplicati.Library.Common.IO.SystemIOLinux:GetMetadata <0x001eb>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at Duplicati.Library.Snapshots.NoSnapshotLinux:GetMetadata <0x0005a>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at Duplicati.Library.Main.Operation.Backup.MetadataGenerator:GenerateMetadata <0x00121>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at <<Run>b__0>d:MoveNext <0x01803>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at MoveNextRunner:InvokeMoveNext <0x0009e>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at System.Threading.ExecutionContext:RunInternal <0x001f9>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at System.Threading.ExecutionContext:Run <0x00047>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at MoveNextRunner:Run <0x00103>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at System.Threading.Tasks.AwaitTaskContinuation:RunOrScheduleAction <0x00086>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at System.Threading.Tasks.Task:FinishContinuations <0x0017b>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at System.Threading.Tasks.Task:FinishStageThree <0x00087>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at System.Threading.Tasks.Task`1:TrySetResult <0x000f3>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at System.Runtime.CompilerServices.AsyncTaskMethodBuilder`1:SetResult <0x000c7>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at <ReadAsync>d__30:MoveNext <0x018cf>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at System.Threading.Tasks.TaskCompletionSource`1:TrySetResult <0x0003f>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at System.Threading.Tasks.TaskCompletionSource`1:SetResult <0x00033>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at <>c__DisplayClass49_0:<SetResult>b__0 <0x00047>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at <>c__DisplayClass0_0:<QueueItem>b__0 <0x00032>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at System.Threading.QueueUserWorkItemCallback:WaitCallback_Context <0x00063>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at System.Threading.QueueUserWorkItemCallback:System.Threading.IThreadPoolWorkItem.ExecuteWorkItem <0x00067>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at System.Threading.ThreadPoolWorkQueue:Dispatch <0x002f8>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at System.Threading._ThreadPoolWaitCallback:PerformWaitCallback <0x00063>
Aug 9 20:59:31 fedora duplicati-server[259594]: #011 at <Module>:runtime_invoke_bool <0x00086>
Aug 9 20:59:33 fedora systemd[1]: duplicati.service: Main process exited, code=exited, status=134/n/a
Aug 9 20:59:33 fedora systemd[1]: duplicati.service: Failed with result 'exit-code'.
Aug 9 20:59:33 fedora audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=duplicati comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Aug 9 20:59:33 fedora systemd[1]: duplicati.service: Consumed 2min 36.460s CPU time.
