TrayIcon disappears but its server does not stop on right-click Quit. Discussion before, but this time there is either a new or newly noticed symptom in the server log which is giving errors like
2025-01-11 07:39:33 -05 - [Information-Duplicati.Library.Main.Controller-CompletedOperation]: The operation Backup has completed
2025-01-11 12:34:01 -05 - [Error-Duplicati.Server.Program-UnobservedTaskException]: A Task's exception(s) were not observed either by Waiting on the Task or accessing its Exception property. As a result, the unobserved exception was rethrown by the finalizer thread. (The channel "UI Action" is retired)
System.AggregateException: A Task's exception(s) were not observed either by Waiting on the Task or accessing its Exception property. As a result, the unobserved exception was rethrown by the finalizer thread. (The channel "UI Action" is retired)
---> CoCoL.RetiredException: The channel "UI Action" is retired
at CoCoL.Channel`1.WriteAsync(T value, ITwoPhaseOffer offer)
2025-01-11 12:41:41 -05 - [Error-Duplicati.Server.Program-UnobservedTaskException]: A Task's exception(s) were not observed either by Waiting on the Task or accessing its Exception property. As a result, the unobserved exception was rethrown by the finalizer thread. (The channel "UI Action" is retired)
2025-01-11 12:49:29 -05 - [Error-Duplicati.Server.Program-UnobservedTaskException]: A Task's exception(s) were not observed either by Waiting on the Task or accessing its Exception property. As a result, the unobserved exception was rethrown by the finalizer thread. (The channel "UI Action" is retired)
2025-01-11 12:57:00 -05 - [Error-Duplicati.Server.Program-UnobservedTaskException]: A Task's exception(s) were not observed either by Waiting on the Task or accessing its Exception property. As a result, the unobserved exception was rethrown by the finalizer thread. (The channel "UI Action" is retired)
2025-01-11 13:04:48 -05 - [Error-Duplicati.Server.Program-UnobservedTaskException]: A Task's exception(s) were not observed either by Waiting on the Task or accessing its Exception property. As a result, the unobserved exception was rethrown by the finalizer thread. (The channel "UI Action" is retired)
2025-01-11 13:12:14 -05 - [Error-Duplicati.Server.Program-UnobservedTaskException]: A Task's exception(s) were not observed either by Waiting on the Task or accessing its Exception property. As a result, the unobserved exception was rethrown by the finalizer thread. (The channel "UI Action" is retired)
2025-01-11 13:20:04 -05 - [Error-Duplicati.Server.Program-UnobservedTaskException]: A Task's exception(s) were not observed either by Waiting on the Task or accessing its Exception property. As a result, the unobserved exception was rethrown by the finalizer thread. (The channel "UI Action" is retired)
2025-01-11 13:27:44 -05 - [Error-Duplicati.Server.Program-UnobservedTaskException]: A Task's exception(s) were not observed either by Waiting on the Task or accessing its Exception property. As a result, the unobserved exception was rethrown by the finalizer thread. (The channel "UI Action" is retired)
2025-01-11 13:35:10 -05 - [Error-Duplicati.Server.Program-UnobservedTaskException]: A Task's exception(s) were not observed either by Waiting on the Task or accessing its Exception property. As a result, the unobserved exception was rethrown by the finalizer thread. (The channel "UI Action" is retired)
2025-01-11 13:42:53 -05 - [Error-Duplicati.Server.Program-UnobservedTaskException]: A Task's exception(s) were not observed either by Waiting on the Task or accessing its Exception property. As a result, the unobserved exception was rethrown by the finalizer thread. (The channel "UI Action" is retired)
2025-01-11 13:50:14 -05 - [Error-Duplicati.Server.Program-UnobservedTaskException]: A Task's exception(s) were not observed either by Waiting on the Task or accessing its Exception property. As a result, the unobserved exception was rethrown by the finalizer thread. (The channel "UI Action" is retired)
2025-01-11 13:58:01 -05 - [Error-Duplicati.Server.Program-UnobservedTaskException]: A Task's exception(s) were not observed either by Waiting on the Task or accessing its Exception property. As a result, the unobserved exception was rethrown by the finalizer thread. (The channel "UI Action" is retired)
Posting a large sample in order to better see the timing (if it matters). These don’t seem to align with any TCP exchanges or console writes. The console did get messages, but I can’t see when:
C:\Duplicati\duplicati-2.1.0.105_canary_2025-01-07-win-x64-gui\RUN>pause
Press any key to continue . . . Server has started and is listening on port 8201
[WebSocket] Client closed connection prematurely.
I thought maybe having it in Pause (to Quit the right icon) mattered, but it doesn’t in 2.1.0.106 (which is the reason I did Quit on 2.1.0.105). Moving to 106, and will leave 105 up a bit more.
