Release: 2.0.3.8 (canary) 2018-06-28
2.0.3.8-2.0.3.8_canary_2018-06-28
  • Fixed MSI version number
  • Un-hid the Google GCS backend
  • Fixed file sizes reported as zero
  • Fixed a wrong display of sizes less than 1kb, thanks @fyndecano
  • Improvements to the build process, thanks @verhoek
  • Fixed a problem with the Amazon Cloud Drive delay, thanks @snamds
  • Fixed a potential deadlock/performance issue, thanks @warwickmm
  • Improved metadata reporting and UI, thanks @verhoek
  • Improved Hyper-V detection, thanks @mnaiman
  • Improved ways to handle the temporary folder, thanks @verhoek
  • Added logic to remove privileges from the database files, thanks @verhoek
  • Fixed a problem with USN support, thanks @dgehri
  • Fixed temporary files not being removed
  • Fixed no output from commandline on Windows
  • Enabled password input from console again
I think a bug was introduced into the progress bar - more than 2 files were being backed up (at least according to the job details) and the bytes calculation seems off… :slight_smile:
