Onedrive vs Object reference not set to an instanc
Dear,
A bit fighting with backup from OpenMediaVault NAS to Onedrive.
I have several tasks /for several NAS users/ for backup to Onedrive, task are working normally. On Onedrive side it is one account with several folder for separate tasks.
With one task /about 16GB of data / i still have problems. Logs is below.
Also tried to start with empty folder / that task works/, later copy part of data to folder and initated backup tasks again. After several backups it stops with error
System.NullReferenceException: Object reference not set to an instance of an object
at Duplicati.Library.Main.Volumes.BlockVolumeWriter.AddBlock (System.String hash, System.Byte data, System.Int32 offset, System.Int32 size, Duplicati.Library.Interface.CompressionHint hint) [0x00032] in :0
at Duplicati.Library.Main.Operation.Backup.SpillCollectorProcess+<>c__DisplayClass0_0+<b__0>d.MoveNext () [0x003df] in :0
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0
at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0
at System.Runtime.CompilerServices.TaskAwaiter.GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0
at CoCoL.AutomationExtensions+d__101[T].MoveNext () [0x0007a] in <6973ce2780de4b28aaa2c5ffc59993b1>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at Duplicati.Library.Main.Operation.BackupHandler+<RunMainOperation>d__12.MoveNext () [0x00349] in <e2da9713f0974e76879d9f9aa7ce0e36>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at Duplicati.Library.Main.Operation.BackupHandler+<RunAsync>d__19.MoveNext () [0x00a43] in <e2da9713f0974e76879d9f9aa7ce0e36>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at CoCoL.ChannelExtensions.WaitForTaskOrThrow (System.Threading.Tasks.Task task) [0x00050] in <6973ce2780de4b28aaa2c5ffc59993b1>:0 at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String[] sources, Duplicati.Library.Utility.IFilter filter) [0x00008] in <e2da9713f0974e76879d9f9aa7ce0e36>:0 at Duplicati.Library.Main.Controller+<>c__DisplayClass13_0.<Backup>b__0 (Duplicati.Library.Main.BackupResults result) [0x00035] in <e2da9713f0974e76879d9f9aa7ce0e36>:0 at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action1[T] method) [0x0011d] in :0
System Properties
  • APIVersion : 1
  • PasswordPlaceholder : **********
  • ServerVersion : 2.0.4.23
  • ServerVersionName : - 2.0.4.23_beta_2019-07-14
  • ServerVersionType : Beta
  • StartedBy : Server
  • BaseVersionName : 2.0.3.3_beta_2018-04-02
  • DefaultUpdateChannel : Beta
  • DefaultUsageReportLevel : Information
  • ServerTime : 2019-09-29T19:21:05.658497+02:00
  • OSType : Linux
  • DirectorySeparator : /
  • PathSeparator : :
  • CaseSensitiveFilesystem : true
  • MonoVersion : 4.6.2
  • MachineName : odroidxu4
  • UserName : root
  • NewLine :
  • CLRVersion : 4.0.30319.42000
  • CLROSInfo : {“Platform”:“Unix”,“ServicePack”:"",“Version”:“4.14.144.4”,“VersionString”:“Unix 4.14.144.4”}
  • ServerModules :
  • UsingAlternateUpdateURLs : false
  • LogLevels : [“ExplicitOnly”,“Profiling”,“Verbose”,“Retry”,“Information”,“DryRun”,“Warning”,“Error”]
  • SuppressDonationMessages : false
  • SpecialFolders : [{“ID”:"%MY_DOCUMENTS%",“Path”:"/root"},{“ID”:"%DESKTOP%",“Path”:"/root/Desktop"},{“ID”:"%HOME%",“Path”:"/root"}]
  • BrowserLocale : {“Code”:“sk-SK”,“EnglishName”:“Slovak (Slovakia)”,“DisplayName”:“slovenčina (Slovensko)”}
  • SupportedLocales : [{“Code”:“bn”,“EnglishName”:“Bengali”,“DisplayName”:“বাংলা”},{“Code”:“ca”,“EnglishName”:“Catalan”,“DisplayName”:“català”},{“Code”:“cs”,“EnglishName”:“Czech”,“DisplayName”:“čeština”},{“Code”:“da”,“EnglishName”:“Danish”,“DisplayName”:“dansk”},{“Code”:“de”,“EnglishName”:“German”,“DisplayName”:“Deutsch”},{“Code”:“en”,“EnglishName”:“English”,“DisplayName”:“English”},{“Code”:“es”,“EnglishName”:“Spanish”,“DisplayName”:“español”},{“Code”:“fi”,“EnglishName”:“Finnish”,“DisplayName”:“suomi”},{“Code”:“fr”,“EnglishName”:“French”,“DisplayName”:“français”},{“Code”:“hu”,“EnglishName”:“Hungarian”,“DisplayName”:“magyar”},{“Code”:“it”,“EnglishName”:“Italian”,“DisplayName”:“italiano”},{“Code”:“ja-JP”,“EnglishName”:“Japanese (Japan)”,“DisplayName”:“日本語 (日本)”},{“Code”:“ko”,“EnglishName”:“Korean”,“DisplayName”:“한국어”},{“Code”:“lt”,“EnglishName”:“Lithuanian”,“DisplayName”:“lietuvių”},{“Code”:“lv”,“EnglishName”:“Latvian”,“DisplayName”:“latviešu”},{“Code”:“nl-NL”,“EnglishName”:“Dutch (Netherlands)”,“DisplayName”:“Nederlands (Nederland)”},{“Code”:“pl”,“EnglishName”:“Polish”,“DisplayName”:“polski”},{“Code”:“pt”,“EnglishName”:“Portuguese”,“DisplayName”:“português”},{“Code”:“pt-BR”,“EnglishName”:“Portuguese (Brazil)”,“DisplayName”:“português (Brasil)”},{“Code”:“ro”,“EnglishName”:“Romanian”,“DisplayName”:“română”},{“Code”:“ru”,“EnglishName”:“Russian”,“DisplayName”:“русский”},{“Code”:“sk”,“EnglishName”:“Slovak”,“DisplayName”:“slovenčina”},{“Code”:“sk-SK”,“EnglishName”:“Slovak (Slovakia)”,“DisplayName”:“slovenčina (Slovensko)”},{“Code”:“sv-SE”,“EnglishName”:“Swedish (Sweden)”,“DisplayName”:“svenska (Sverige)”},{“Code”:“th”,“EnglishName”:“Thai”,“DisplayName”:“ไทย”},{“Code”:“zh-CN”,“EnglishName”:“Chinese (Simplified)”,“DisplayName”:“中文 (中国)”},{“Code”:“zh-HK”,“EnglishName”:“Chinese (Traditional, Hong Kong SAR China)”,“DisplayName”:“中文 (中国香港特别行政区)”},{“Code”:“zh-TW”,“EnglishName”:“Chinese (Traditional)”,“DisplayName”:“中文 (台湾)”}]
  • BrowserLocaleSupported : true
  • backendgroups : {“std”:{“ftp”:null,“ssh”:null,“webdav”:null,“openstack”:“OpenStack Object Storage / Swift”,“s3”:“S3 Compatible”,“aftp”:“FTP (Alternative)”},“local”:{“file”:null},“prop”:{“s3”:null,“azure”:null,“googledrive”:null,“onedrive”:null,“onedrivev2”:null,“sharepoint”:null,“msgroup”:null,“cloudfiles”:null,“gcs”:null,“openstack”:null,“hubic”:null,“amzcd”:null,“b2”:null,“mega”:null,“box”:null,“od4b”:null,“mssp”:null,“dropbox”:null,“sia”:null,“jottacloud”:null,“rclone”:null}}
  • GroupTypes : [“Local storage”,“Standard protocols”,“Proprietary”,“Others”]
  • Backend modules: aftp amzcd azure b2 box cloudfiles dropbox ftp file googledrive gcs hubic jottacloud mega msgroup onedrive onedrivev2 sharepoint openstack rclone s3 ssh od4b mssp sia tahoe webdav
  • Compression modules: zip 7z
  • Encryption modules: aes gpg
Thanks for advice
I’m having a very similar issue with OneDrive. i’ve created a new backup job using Duplicati running in a docker. In total I have 2 backup jobs, with identical configuration apart from the fact the one used ssh to back up to a local server, the other uses OneDriveV2 as the destination. There’s plenty of space in Onedrive for my 200GB of data, and I started with a new folder, but still get the same error message, then the backup fails and on the next attempt I get messages about different numbers of files etc…
Logs:
at Duplicati.Library.Main.Operation.Backup.SpillCollectorProcess+<>c__DisplayClass0_0.b__0 (<>f__AnonymousType92[<Input>j__TPar,<Output>j__TPar] self) [0x003df] in <e2da9713f0974e76879d9f9aa7ce0e36>:0 at CoCoL.AutomationExtensions.RunTask[T] (T channels, System.Func2[T,TResult] method, System.Boolean catchRetiredExceptions) [0x000cc] in <6973ce2780de4b28aaa2c5ffc59993b1>:0
at Duplicati.Library.Main.Operation.BackupHandler.RunMainOperation (System.Collections.Generic.IEnumerable1[T] sources, Duplicati.Library.Snapshots.ISnapshotService snapshot, Duplicati.Library.Snapshots.UsnJournalService journalService, Duplicati.Library.Main.Operation.Backup.BackupDatabase database, Duplicati.Library.Main.Operation.Backup.BackupStatsCollector stats, Duplicati.Library.Main.Options options, Duplicati.Library.Utility.IFilter sourcefilter, Duplicati.Library.Utility.IFilter filter, Duplicati.Library.Main.BackupResults result, Duplicati.Library.Main.Operation.Common.ITaskReader taskreader, System.Int64 lastfilesetid) [0x00349] in <e2da9713f0974e76879d9f9aa7ce0e36>:0 at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter) [0x01031] in <e2da9713f0974e76879d9f9aa7ce0e36>:0 at CoCoL.ChannelExtensions.WaitForTaskOrThrow (System.Threading.Tasks.Task task) [0x00050] in <6973ce2780de4b28aaa2c5ffc59993b1>:0 at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String[] sources, Duplicati.Library.Utility.IFilter filter) [0x00008] in <e2da9713f0974e76879d9f9aa7ce0e36>:0 at Duplicati.Library.Main.Controller+<>c__DisplayClass13_0.<Backup>b__0 (Duplicati.Library.Main.BackupResults result) [0x00035] in <e2da9713f0974e76879d9f9aa7ce0e36>:0 at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action1[T] method) [0x00271] in :0
at Duplicati.Library.Main.Controller.Backup (System.String inputsources, Duplicati.Library.Utility.IFilter filter) [0x00068] in :0
at Duplicati.Server.Runner.Run (Duplicati.Server.Runner+IRunnerData data, System.Boolean fromQueue) [0x00307] in :0
System Properties:
System properties
  • APIVersion : 1
  • BaseVersionName : 2.0.4.23_beta_2019-07-14
  • ServerTime : 2019-12-12T08:21:57.411754+00:00
  • OSType : Linux
  • PathSeparator : :
  • MonoVersion : 5.20.1.34
  • MachineName : 2434e6b59ae9
  • UserName : root
  • NewLine :
  • CLROSInfo : {“Platform”:“Unix”,“ServicePack”:"",“Version”:“4.4.0.170”,“VersionString”:“Unix 4.4.0.170”}
  • ServerModules :
  • SpecialFolders : [{“ID”:"%MY_DOCUMENTS%",“Path”:"/config"},{“ID”:"%HOME%",“Path”:"/config"}]
  • BrowserLocale : {“Code”:“en-GB”,“EnglishName”:“English (United Kingdom)”,“DisplayName”:“English (United Kingdom)”}
  • SupportedLocales : [{“Code”:“bn”,“EnglishName”:“Bangla”,“DisplayName”:“বাংলা”},{“Code”:“ca”,“EnglishName”:“Catalan”,“DisplayName”:“català”},{“Code”:“cs”,“EnglishName”:“Czech”,“DisplayName”:“čeština”},{“Code”:“da”,“EnglishName”:“Danish”,“DisplayName”:“dansk”},{“Code”:“de”,“EnglishName”:“German”,“DisplayName”:“Deutsch”},{“Code”:“en”,“EnglishName”:“English”,“DisplayName”:“English”},{“Code”:“es”,“EnglishName”:“Spanish”,“DisplayName”:“español”},{“Code”:“fi”,“EnglishName”:“Finnish”,“DisplayName”:“suomi”},{“Code”:“fr”,“EnglishName”:“French”,“DisplayName”:“français”},{“Code”:“hu”,“EnglishName”:“Hungarian”,“DisplayName”:“magyar”},{“Code”:“it”,“EnglishName”:“Italian”,“DisplayName”:“italiano”},{“Code”:“ja-JP”,“EnglishName”:“Japanese (Japan)”,“DisplayName”:“日本語 (日本)”},{“Code”:“ko”,“EnglishName”:“Korean”,“DisplayName”:“한국어”},{“Code”:“lt”,“EnglishName”:“Lithuanian”,“DisplayName”:“lietuvių”},{“Code”:“lv”,“EnglishName”:“Latvian”,“DisplayName”:“latviešu”},{“Code”:“nl-NL”,“EnglishName”:“Dutch (Netherlands)”,“DisplayName”:“Nederlands (Nederland)”},{“Code”:“pl”,“EnglishName”:“Polish”,“DisplayName”:“polski”},{“Code”:“pt”,“EnglishName”:“Portuguese”,“DisplayName”:“português”},{“Code”:“pt-BR”,“EnglishName”:“Portuguese (Brazil)”,“DisplayName”:“português (Brasil)”},{“Code”:“ro”,“EnglishName”:“Romanian”,“DisplayName”:“română”},{“Code”:“ru”,“EnglishName”:“Russian”,“DisplayName”:“русский”},{“Code”:“sk”,“EnglishName”:“Slovak”,“DisplayName”:“slovenčina”},{“Code”:“sk-SK”,“EnglishName”:“Slovak (Slovakia)”,“DisplayName”:“slovenčina (Slovensko)”},{“Code”:“sv-SE”,“EnglishName”:“Swedish (Sweden)”,“DisplayName”:“svenska (Sverige)”},{“Code”:“th”,“EnglishName”:“Thai”,“DisplayName”:“ไทย”},{“Code”:“zh-CN”,“EnglishName”:“Chinese (Simplified)”,“DisplayName”:“中文 (中国)”},{“Code”:“zh-HK”,“EnglishName”:“Chinese (Traditional, Hong Kong SAR China)”,“DisplayName”:“中文 (中国香港特别行政区)”},{“Code”:“zh-TW”,“EnglishName”:“Chinese (Traditional)”,“DisplayName”:“中文 (台湾)”}]
Server State Properties
Server state properties
  • lastEventId : 474
  • lastDataUpdateId : 50
  • lastNotificationUpdateId : 16
  • estimatedPauseEnd : 0001-01-01T00:00:00
  • activeTask :
  • programState : Running
  • lastErrorMessage :
  • connectionState : connected
  • xsfrerror : false
  • connectionAttemptTimer : 0
  • failedConnectionAttempts : 0
  • lastPgEvent :
  • updaterState : Waiting
  • updatedVersion :
  • updateReady : false
  • updateDownloadProgress : 0
  • proposedSchedule : [{“Item1”:“6”,“Item2”:“2019-12-12T13:00:00Z”},{“Item1”:“5”,“Item2”:“2019-12-13T02:00:00Z”},{“Item1”:“1”,“Item2”:“2019-12-13T03:00:00Z”}]
  • schedulerQueueIds :
  • pauseTimeRemain : 0
Seems we are not alone… here are 3 other related posts I found, with no responses as yet:
I’ve noticed that if I start with a small backup set, that I don’t get this error. If I grow the size of the backup set by adding files/folders into the configuration, then I don’t get this error. However if I add too many files, or too much data to the backup set then I start getting this error again.
I’m not clear on whether the problem comes when I add too many files, or too much in terms of the volume of data, or if its time elapsed sending the data to OneDrive, but I felt it important to post my findings.
So I think i’ll be able to grow to the full size of the data that I need backed up, but its a problem that I have to manually grow the backup set (200 Gig in chunks is likely to be a lot of chunks!)
Please let me know if there is any other information you would like me to test for, or logs I can post.
As i wrote, i am trying to upload 16GB of several folders. I tested same way - manually increased backup set by adding folders- only difference to greg.ewing is that it collapsed everytime. I tested changed order of uploaded folder, still same.
On Onedrive Bussines in company it works nice, also tested with recovery from backup.
Just onedrive personal it doesnt work as expected
I started looking into this yesterday, but didn’t have a comment until today’s similar ending. I suggest:
OneDrive also has a somewhat short timeout of 100 seconds, and I wonder if the work link runs faster.
–http-operation-timeout can increase it, if that turns out to be the problem (the logs above may reveal).
So I gave it a few months and I tried this again and it has been working flawlessly for the past couple of weeks.
I’m mystified as to what changed, I’m only sorry that I didn’t see the reply above until now as I may have been able to provide some interesting diagnostics.
