Hi there,
my backup fails with apparent systems issue. Connection to onedrive works, some uploads as well. Any suggestions?
pls let me know which other information is required.
Tried complete reinstall, windows checks / updates, .net reinstallation…
Best Timmo
System.NullReferenceException: Object reference not set to an instance of an object.
at Duplicati.Library.Main.Volumes.BlockVolumeWriter.AddBlock(String hash, Byte data, Int32 offset, Int32 size, CompressionHint hint)
at Duplicati.Library.Main.Operation.Backup.SpillCollectorProcess.<>c__DisplayClass0_0.<b__0>d.MoveNext()
at CoCoL.AutomationExtensions.d__10`1.MoveNext()
at Duplicati.Library.Main.Operation.BackupHandler.d__12.MoveNext()
at Duplicati.Library.Main.Operation.BackupHandler.d__19.MoveNext()
at Duplicati.Library.Main.Controller.<>c__DisplayClass13_0.b__0(BackupResults result)
at Duplicati.Library.Main.Controller.Backup(String inputsources, IFilter filter)
Version: 2.0.4.5_beta_2018-11-28, Win 10
- CLRVersion : 4.0.30319.42000
 - CLROSInfo : {“Platform”:“Win32NT”,“ServicePack”:"",“Version”:“10.0.17134.0”,“VersionString”:“Microsoft Windows NT 10.0.17134.0”}
