I have a job that runs every 30 minutes. Right now it always throws a warning when it completes.
So after a few days if I log in to the interface, I’ve got a vertical column of 4 big warning messages:
I can tell using the dev console that there are over 900 of these queued up.
There are two problems here:
- Clicking Dismiss on a warning appears to the user to do nothing at all. But what’s really happening is that notification is being dismissed and an identical one takes its place, with not a single pixel on the screen changing. There needs to be user feedback here that something is happening.
- The Dismiss All button doesn’t work. Clicking on it makes Duplicati go totally unresponsive for a few seconds, after which I can use the dev tools to see that only removed 50 or so of them. Here’s what I get after clicking the button:
Because of #2, the Duplicati interface is unusable until I click that Dismiss All button 18 times, waiting 15 times in between. And if I had waited 2 months since the last time I opened in the interface, it’d be hopeless
I am running 2.0.5.1_beta_2020-01-18
