I’ve received this error a few times now.
I can repair the database successfully, and have completed at least one manual backup after a successful repair. But this error is occurring with most backup runs …
System.ArgumentNullException: Value cannot be null.
Parameter name: path
at Duplicati.Library.Main.BackendManager.WaitForEmpty (Duplicati.Library.Main.Database.LocalDatabase db, System.Data.IDbTransaction transation) [0x00067] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Operation.CompactHandler.DoDelete (Duplicati.Library.Main.Database.LocalDeleteDatabase db, Duplicati.Library.Main.BackendManager backend, System.Collections.Generic.IEnumerable`1[T] deleteableVolumes, System.Data.IDbTransaction& transaction) [0x00040] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Operation.CompactHandler.DoCompact (Duplicati.Library.Main.Database.LocalDeleteDatabase db, System.Boolean hasVerifiedBackend, System.Data.IDbTransaction& transaction, Duplicati.Library.Main.BackendManager sharedBackend) [0x004a2] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Operation.DeleteHandler.DoRun (Duplicati.Library.Main.Database.LocalDeleteDatabase db, System.Data.IDbTransaction& transaction, System.Boolean hasVerifiedBacked, System.Boolean forceCompact, Duplicati.Library.Main.BackendManager sharedManager) [0x00397] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Operation.BackupHandler.CompactIfRequired (Duplicati.Library.Main.BackendManager backend, System.Int64 lastVolumeSize) [0x000a5] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x01033] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00009] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Controller+<>c__DisplayClass14_0.<Backup>b__0 (Duplicati.Library.Main.BackupResults result) [0x0004b] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action`1[T] method) [0x0026f] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Controller.Backup (System.String[] inputsources, Duplicati.Library.Utility.IFilter filter) [0x00074] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Server.Runner.Run (Duplicati.Server.Runner+IRunnerData data, System.Boolean fromQueue) [0x00349] in <c5f097a49c0a4f1fb0f93cf3f5f218b1>:0
This additional error occurs when/if a manual run is attempted after the above error, before a repair …
Duplicati.Library.Interface.UserInformationException: Found 1 remote files that are not recorded in local storage, please run repair
at Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList (Duplicati.Library.Main.BackendManager backend, Duplicati.Library.Main.Options options, Duplicati.Library.Main.Database.LocalDatabase database, Duplicati.Library.Main.IBackendWriter log, System.String protectedfile) [0x00103] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Operation.BackupHandler.PreBackupVerify (Duplicati.Library.Main.BackendManager backend, System.String protectedfile) [0x0010b] in <8f1de655bd1240739a78684d845cecc8>:0
There have been no recent changes to the backup settings, and weeks of successful backups until now. I’m unsure how to further track down the issue and repair it.
Any suggestions?
Thanks, in advance, for the attention.
