Duplicati and OneDrive: "Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt"
Hello,
after setting up a backup job on my Windows 10 client with destination “Microsoft OneDrive v2” the job terminates with the error:
“Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt”
Any help very much appreciated.
Kind regards
tsch
Have you tried restarting?
Can you please post a screenshot of your settings under “Target”?
Hello ollibraun,
thanks a lot for your quick reply.
I restartet many times but never got a complete backup.
Here are my target settings:
grafik
Does “Test connection” work? Please try “BACKUP/FOTOS” and “/BACKUP/FOTOS/”. With / instead of \ please.
“Test connection” works but Backups unfortunately not.
So please provide a log.
If my German is anything to go by, i’m having much the same problem. I’ve already posted logs in another thread.
Link to other thread where i’ve been contributing logs and observations:
I am seeing the same problem since I switched from Windows 7 to Windows 10. First it worked, but after moving files to the new computer, the amount of data to backup grew to 50 GB and now I keep getting this error message. When I retry it comes again, though always at different times.
Thanks a lot if someone could have a look at this!
Here is one of my error logs:
    System.NullReferenceException: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
   bei Duplicati.Library.Main.Volumes.BlockVolumeWriter.AddBlock(String hash, Byte[] data, Int32 offset, Int32 size, CompressionHint hint)
   bei Duplicati.Library.Main.Operation.Backup.SpillCollectorProcess.<>c__DisplayClass0_0.<<Run>b__0>d.MoveNext()
--- Ende der Stapelüberwachung vom vorhergehenden Ort, an dem die Ausnahme ausgelöst wurde ---
   bei System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
   bei System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   bei CoCoL.AutomationExtensions.<RunTask>d__10`1.MoveNext()
   bei Duplicati.Library.Main.Operation.BackupHandler.<RunMainOperation>d__12.MoveNext()
   bei Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__19.MoveNext()
   bei CoCoL.ChannelExtensions.WaitForTaskOrThrow(Task task)
   bei Duplicati.Library.Main.Controller.<>c__DisplayClass13_0.<Backup>b__0(BackupResults result)
   bei Duplicati.Library.Main.Controller.RunAction[T](T result, String[]& paths, IFilter& filter, Action`1 method)
   bei Duplicati.Library.Main.Controller.Backup(String[] inputsources, IFilter filter)
   bei Duplicati.Server.Runner.Run(IRunnerData data, Boolean fromQueue)
The Live Log (mode retry) contains
{"ClassName":"CoCoL.RetiredException","Message":"The channel is retired","Data":null,"InnerException":null,"HelpURL":null,"StackTraceString":"   bei System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n   bei System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n   bei CoCoL.Channel`1.<WriteAsync>d__30.MoveNext()\r\n--- Ende der Stapelüberwachung vom vorhergehenden Ort, an dem die Ausnahme ausgelöst wurde ---\r\n   bei System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n   bei Duplicati.Library.Main.Operation.Backup.MetadataPreProcess.<>c__DisplayClass2_0.<<Run>b__0>d.MoveNext()","RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":"8\nThrow\nmscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\nSystem.Runtime.ExceptionServices.ExceptionDispatchInfo\nVoid Throw()","HResult":-2146233088,"Source":"mscorlib","WatsonBuckets":null}
Welcome to the forum @gerhardg
Onedrive vs Object reference not set to an instanc from the other thread (parallel threads are messy) has my request (with no response so far) to see if anyone can find the original error by doing logging.
This is the correct stack trace. For some reason, it attempts to save a null block during spill pickup. It is likely not related to OneDrive, but maybe it happens because the backend fails early.
@ts678
@kenkendk
Thanks for your warm welcome and quick replies.
I have now created a log file with level retry. Here are some excerpts from it:
For about 15 Minutes (times vary) everthing works fine and the log shows succesful PUT operations (Backup event: Put - …) only. Then the following appears:
2019-12-25 13:17:27 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-id3c95ac2aae44390baf7e48a6d441c53.dindex.zip.aes (40,11 KB)
2019-12-25 13:17:27 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b6ec39fe6c3c94fc3b387e022b3aac90b.dblock.zip.aes (49,97 MB)
2019-12-25 13:19:10 +01 - [Retry-Duplicati.Library.Main.Operation.Common.BackendHandler-RetryPut]: Operation Put with file duplicati-b6ec39fe6c3c94fc3b387e022b3aac90b.dblock.zip.aes attempt 1 of 5 failed with message: Eine Aufgabe wurde abgebrochen.
System.Threading.Tasks.TaskCanceledException: Eine Aufgabe wurde abgebrochen.
   bei System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
   bei Duplicati.Library.OAuthHttpClient.<SendAsync>d__4.MoveNext()
   bei Duplicati.Library.Backend.MicrosoftGraphBackend.Put(String remotename, Stream stream)
   bei Duplicati.Library.Main.Operation.Common.BackendHandler.<DoPut>d__23.MoveNext()
   bei Duplicati.Library.Main.Operation.Common.BackendHandler.<>c__DisplayClass13_0.<<UploadFileAsync>b__2>d.MoveNext()
   bei Duplicati.Library.Main.Operation.Common.BackendHandler.<DoWithRetry>d__21`1.MoveNext()
2019-12-25 13:19:10 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b3276a2d3ede647adb7c0375751230454.dblock.zip.aes (49,94 MB)
2019-12-25 13:19:10 +01 - [Warning-Duplicati.Library.Main.Operation.Backup.MetadataPreProcess.FileEntry-ProcessingMetadataFailed]: Failed to process entry, path: C:\Users\Gerhard\Pictures\Ma&Pa\Archiv Mama\DSC00867.JPG
CoCoL.RetiredException: The channel is retired
2019-12-25 13:19:10 +01 - [Warning-Duplicati.Library.Main.Operation.Backup.MetadataPreProcess.FileEntry-ProcessingMetadataFailed]: Failed to process entry, path: C:\Users\Gerhard\Pictures\Ma&Pa\Archiv Mama\DSC00868.JPG
The long delay of 103 seconds is also visible in the UI (nothing happens anymore, only the displayed upload speed becomes smaller and smaller). Following in the log is a very long sequence of CoCoL.RetiredExceptions each with a different source file name:
2019-12-25 13:19:10 +01 - [Warning-Duplicati.Library.Main.Operation.Backup.MetadataPreProcess.FileEntry-ProcessingMetadataFailed]: Failed to process entry, path: C:\Users\Gerhard\Pictures\Ma&Pa\Archiv Mama\DSC00871.JPG
After that the log ends with:
2019-12-25 13:19:10 +01 - [Warning-Duplicati.Library.Main.Operation.Backup.MetadataPreProcess.FileEntry-ProcessingMetadataFailed]: Failed to process entry, path: C:\Users\Gerhard\Pictures\Ma&Pa\Archiv Mama\DSC02274.JPG
2019-12-25 13:19:10 +01 - [Retry-Duplicati.Library.Main.Operation.Common.BackendHandler-RetryPut]: Operation Put with file duplicati-b3276a2d3ede647adb7c0375751230454.dblock.zip.aes attempt 1 of 5 failed with message: Eine Aufgabe wurde abgebrochen.
2019-12-25 13:19:10 +01 - [Error-Duplicati.Library.Main.Operation.BackupHandler-FatalError]: Fatal error
As a side note: Meanwhile I have created an almost identical backup configuration that backs up the same file set to my local NAS using WebDAV. This backup worked without any problems. Of course the NAS is connected with a fast Gigabit ethernet line, whereas for OneDrive I have “only” about 100 MBit upload speed.
Some of the few that I got look suspiciously like I was accidentally or intentionally getting backend failures, which is why I was hoping that looking just above the final failure would show some more:
2019-07-05 16:09:23 -04 - [Retry-Duplicati.Library.Main.Operation.Backup.BackendUploader-RetryPut]: Operation Put with file duplicati-be67ded3f892f4fe2ac997063ef01fb13.dblock.zip attempt 6 of 5 failed with message: An established connection was aborted by the server.
Renci.SshNet.Common.SshConnectionException: An established connection was aborted by the server.
   at Renci.SshNet.Session.WaitOnHandle(WaitHandle waitHandle, TimeSpan timeout)
   at Renci.SshNet.PasswordAuthenticationMethod.Authenticate(Session session)
   at Renci.SshNet.ClientAuthentication.TryAuthenticate(ISession session, AuthenticationState authenticationState, String[] allowedAuthenticationMethods, SshAuthenticationException& authenticationException)
   at Renci.SshNet.ClientAuthentication.Authenticate(IConnectionInfoInternal connectionInfo, ISession session)
   at Renci.SshNet.ConnectionInfo.Authenticate(ISession session, IServiceFactory serviceFactory)
   at Renci.SshNet.Session.Connect()
   at Renci.SshNet.BaseClient.Connect()
   at Duplicati.Library.Backend.SSHv2.CreateConnection()
   at Duplicati.Library.Backend.SSHv2.PutAsync(String remotename, Stream stream, CancellationToken cancelToken)
   at Duplicati.Library.Main.Operation.Backup.BackendUploader.<DoPut>d__21.MoveNext()
   at Duplicati.Library.Main.Operation.Backup.BackendUploader.<>c__DisplayClass17_0.<<UploadFileAsync>b__0>d.MoveNext()
   at Duplicati.Library.Main.Operation.Backup.BackendUploader.<DoWithRetry>d__18.MoveNext()
2019-07-05 16:09:23 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Failed: duplicati-be67ded3f892f4fe2ac997063ef01fb13.dblock.zip (1,001.98 KB)
2019-07-05 16:09:45 -04 - [Profiling-Duplicati.Library.Main.Operation.Backup.BackendUploader-UploadSpeed]: Uploaded 1,001.98 KB in 00:00:33.6460128, 29.78 KB/s
2019-07-05 16:09:45 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-bdccd554485ce4c14a98f00ec262891bb.dblock.zip (1,001.98 KB)
2019-07-05 16:09:45 -04 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Common.DatabaseCommon-CommitTransactionAsync]: Starting - CommitAfterUpload
2019-07-05 16:09:45 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.Common.DatabaseCommon-CommitTransactionAsync]: CommitAfterUpload took 0:00:00:00.111
2019-07-05 16:09:45 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.BackupHandler-BackupMainOperation]: BackupMainOperation took 0:00:01:56.725
2019-07-05 16:09:45 -04 - [Error-Duplicati.Library.Main.Operation.BackupHandler-FatalError]: Fatal error
System.NullReferenceException: Object reference not set to an instance of an object.
   at Duplicati.Library.Main.Volumes.BlockVolumeWriter.AddBlock(String hash, Byte[] data, Int32 offset, Int32 size, CompressionHint hint)
   at Duplicati.Library.Main.Operation.Backup.SpillCollectorProcess.<>c__DisplayClass0_0.<<Run>b__0>d.MoveNext()
2019-05-07 09:55:28 -04 - [Retry-Duplicati.Library.Main.Operation.Backup.BackendUploader-RetryPut]: Operation Put with file duplicati-b15b7caf5848f41d5a99fd2f62b1ea45c.dblock.zip attempt 6 of 5 failed with message: Unable to connect to the remote server
System.Net.WebException: Unable to connect to the remote server
   at Duplicati.Library.Utility.AsyncHttpRequest.AsyncWrapper.GetResponseOrStream()
   at Duplicati.Library.Utility.AsyncHttpRequest.GetRequestStream(Int64 contentlength)
   at Duplicati.Library.Backend.FTP.<PutAsync>d__21.MoveNext()
2019-05-07 09:55:28 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Failed: duplicati-b15b7caf5848f41d5a99fd2f62b1ea45c.dblock.zip (49.94 MB)
2019-05-07 09:55:28 -04 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.BackupHandler-BackupMainOperation]: BackupMainOperation took 0:00:02:41.685
2019-05-07 09:55:28 -04 - [Error-Duplicati.Library.Main.Operation.BackupHandler-FatalError]: Fatal error
That is not correct, it is trying to use m_compression after it has been closed.
I have not figured out why it does that just yet, but it still looks unrelated to the actual backend.
What version of Duplicati? Some potential null reference exceptions have been fixed since the last beta (2.0.4.5).
In my case its 2.0.4.23_beta_2019-07-14
2.0.4.23 is the same as 2.0.4.5 except for a warning for Amazon Cloud Drive users. There’s a possibility that this null reference exception has been fixed since then.
A user reported a similar issue below with version 2.0.4.23 and OneDrive. Upgrading to 2.0.4.38 appears to have resolved the issue.
