I have multiple servers, each backing up using OneDrivev2
Last night all failed with an Oauth error. The concern is that each server uses a different Onedrive account. I have tried getting a new AuthID token which is successful but when I click ‘test’ it fails:-
Failed to connect: Failed to authorize using the OAuth service: Server error. If the problem persists, try generating a new authid token from: Duplicati OAuth Handler
Ditto. Getting the OAuth failure for box.com
Regenerated authid and still no go. 500 server error showing. Box.com login via web is fine, and shows files - so looks like something has gone bang in the middleware oauth handler :\
