OS: Windows 10 Pro
Duplicati v2.0.4.23_beta_2019-07-14
I have a rather large (1.2TB) backup set. I’m trying to update the backup but it’s spending a LOT of time at the “Backup Started at [time]” message. It takes at about 30 minutes before it moves on to the “Checking remote backup …”. Once it gets to “Checking remote backup …” the backup proceeds very quickly, even with the large number and size of the files.
I’ve tried adding several options (in bold below) to see if I could speed things up but it doesn’t help.
I’ve noticed an odd thing. Once the backup has completed and I try running it again, it’s very fast (a few minutes). It’s like something is getting cached in RAM. If I reboot the PC (Windows 10) and try again, it’s back to the 30+ minute wait.
For this backup “local” is a shared network drive (\Pippin\Media\Video\Television) and “remote” is a USB drive connected to the local computer (F:\Television\Backup\Files). I would suspect the network as being the culprit but I see the same performance issue when “local” is an internal SSD and “remote” is a USB drive on the same machine.
What’s going on between “Backup Started at…” and “Checking remote backup …” and is there anything I can do to speed it up or eliminate it?
First run after booting computer:
F:\Television>\sauron\System\UtilitySoftware\Duplicati\Duplicati.CommandLine.exe BACKUP Backup\Files \PIPPIN\Media\Video\Television --backup-name=Television --dbpath=“Backup\DB\Television.sqlite” –skip-file-hash-checks=true --no-backend-verification=true --check-filetime-only=true --encryption-module=aes --compression-module=zip --dblock-size=1GB --keep-time=2M --disable-module=console-password-input --no-encryption=true --exclude=“System Volume Information” --exclude="$RECYCLE.BIN" --exclude=“lrdata” --exclude="[!]" --exclude=“Backup\DB”
Backup started at 1/12/2020 11:00:42 AM
Scanning local files …
8182 files need to be examined (1.16 TB)
8127 files need to be examined (1.16 TB)
Duration of backup: 00:32:06
Remote files: 2496
Remote size: 1.22 TB
Total remote quota: 3.64 TB
Available remote quota: 1.67 TB
Files added: 0
Files deleted: 0
Files changed: 0
Data uploaded: 0 bytes
Data downloaded: 0 bytes
Second run after waiting 30+ minutes for the first run:
F:\Television>\sauron\System\UtilitySoftware\Duplicati\Duplicati.CommandLine.exe BACKUP Backup\Files \PIPPIN\Media\Video\Television --backup-name=Television --dbpath=“Backup\DB\Television.sqlite” --skip-file-hash-checks=true --no-backend-verification=true --check-filetime-only=true --encryption-module=aes --compression-module=zip --dblock-size=1GB --keep-time=2M --disable-module=console-password-input --no-encryption=true --exclude=“System Volume Information” --exclude="$RECYCLE.BIN" --exclude=“lrdata” --exclude="[!]" --exclude=“Backup\DB”
Backup started at 1/12/2020 11:38:32 AM
Duration of backup: 00:00:52
Remote files: 2496
Files added: 0
Files deleted: 0
Files changed: 0
