What is the syntax of addressing a save location is setting up a backup?
I am trying to set up a backup using Dropbox. When I enter a destination, the system accepts it but then uses its own default (I believe) to save the data and the dB. What is the correct syntax to use so the system will accept the location I choose for the data storage?
Welcome to the forum @rsberg01
This needs clarification. Is it GUI (which is a form) or CLI (which has more syntax)?
Why do you believe that?
This is completely separate from Destination. In GUI, the Database has its own page.
Are you asking about Destination path? Type a folder or slash-separated folders.
From another forum post, viewing from Dropbox might see your folder under its own.
Dropbox Destination is the CLI URL version of what I said. GUI’s form simplifies that.
