Below is a chunk of profiling log (plus --profile-all-database-queries=true) from this warning yesterday.
Does B2 ever throw you an annoying System.Exception: 500 - internal_error: incident id?
Sounds sort of worrisome. Their support didn’t have much to say though, and a retry seems to solve it.
2019-11-17 21:05:46 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Starting - Uploading a new fileset
2019-11-17 21:05:47 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Common.DatabaseCommon-CommitTransactionAsync]: Starting - CommitUpdateRemoteVolume
2019-11-17 21:05:59 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.Common.DatabaseCommon-CommitTransactionAsync]: CommitUpdateRemoteVolume took 0:00:00:12.054
2019-11-17 21:05:59 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.Backup.UploadRealFilelist-UploadNewFileset]: Uploading a new fileset took 0:00:00:12.432
2019-11-17 21:05:59 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Common.DatabaseCommon-CommitTransactionAsync]: Starting - CommitUpdateRemoteVolume
2019-11-17 21:05:59 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.Common.DatabaseCommon-CommitTransactionAsync]: CommitUpdateRemoteVolume took 0:00:00:00.000
2019-11-17 21:05:59 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-20191118T020418Z.dlist.zip.aes (43.33 KB)
2019-11-17 21:06:29 -05 - [Retry-Duplicati.Library.Main.Operation.Backup.BackendUploader-RetryPut]: Operation Put with file duplicati-20191118T020418Z.dlist.zip.aes attempt 1 of 10 failed with message: 500 - internal_error: incident id 1d72a594a6df-DHeLY3nnQXCaCOz/txS/Fg==
System.Exception: 500 - internal_error: incident id 1d72a594a6df-DHeLY3nnQXCaCOz/txS/Fg==
at Duplicati.Library.Backend.Backblaze.B2AuthHelper.AttemptParseAndThrowException(Exception ex)
at Duplicati.Library.JSONWebHelper.<GetResponseAsync>d__37.MoveNext()
at Duplicati.Library.JSONWebHelper.<ReadJSONResponseAsync>d__27`1.MoveNext()
at Duplicati.Library.JSONWebHelper.<GetJSONDataAsync>d__22`1.MoveNext()
at Duplicati.Library.Backend.Backblaze.B2.<PutAsync>d__28.MoveNext()
at Duplicati.Library.Main.Operation.Backup.BackendUploader.<DoPut>d__21.MoveNext()
at Duplicati.Library.Main.Operation.Backup.BackendUploader.<>c__DisplayClass17_0.<<UploadFileAsync>b__0>d.MoveNext()
at Duplicati.Library.Main.Operation.Backup.BackendUploader.<DoWithRetry>d__18.MoveNext()
2019-11-17 21:06:30 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Retrying: duplicati-20191118T020418Z.dlist.zip.aes (43.33 KB)
2019-11-17 21:06:37 -05 - [Profiling-Duplicati.Library.Main.Operation.Backup.BackendUploader-UploadSpeed]: Uploaded 27.65 MB in 00:00:51.1953085, 553.10 KB/s
2019-11-17 21:06:37 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-b8f6e59b1b6824da7b288adcd0c813d09.dblock.zip.aes (27.65 MB)
2019-11-17 21:06:37 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Common.DatabaseCommon-CommitTransactionAsync]: Starting - CommitAfterUpload
2019-11-17 21:06:37 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.Common.DatabaseCommon-CommitTransactionAsync]: CommitAfterUpload took 0:00:00:00.189
2019-11-17 21:06:37 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: Starting - ExecuteScalarInt64: INSERT INTO "Remotevolume" ("OperationID", "Name", "Type", "State", "Size", "VerificationCount", "DeleteGraceTime") VALUES (16, "duplicati-id6c457eb8e114d6bbb0b4f2fd6c94f26.dindex.zip.aes", "Index", "Temporary", -1, 0, 0); SELECT last_insert_rowid();
2019-11-17 21:06:37 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: ExecuteScalarInt64: INSERT INTO "Remotevolume" ("OperationID", "Name", "Type", "State", "Size", "VerificationCount", "DeleteGraceTime") VALUES (16, "duplicati-id6c457eb8e114d6bbb0b4f2fd6c94f26.dindex.zip.aes", "Index", "Temporary", -1, 0, 0); SELECT last_insert_rowid(); took 0:00:00:00.000
2019-11-17 21:06:37 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-id6c457eb8e114d6bbb0b4f2fd6c94f26.dindex.zip.aes (38.62 KB)
2019-11-17 21:06:39 -05 - [Profiling-Duplicati.Library.Main.Operation.Backup.BackendUploader-UploadSpeed]: Uploaded 38.62 KB in 00:00:01.4411052, 26.80 KB/s
2019-11-17 21:06:39 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-id6c457eb8e114d6bbb0b4f2fd6c94f26.dindex.zip.aes (38.62 KB)
2019-11-17 21:06:39 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Common.DatabaseCommon-CommitTransactionAsync]: Starting - CommitAfterUpload
2019-11-17 21:06:39 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.Common.DatabaseCommon-CommitTransactionAsync]: CommitAfterUpload took 0:00:00:00.372
2019-11-17 21:06:40 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Rename: duplicati-20191118T020418Z.dlist.zip.aes (43.33 KB)
2019-11-17 21:06:40 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Rename: duplicati-20191118T020419Z.dlist.zip.aes (43.33 KB)
2019-11-17 21:06:40 -05 - [Information-Duplicati.Library.Main.Operation.Backup.BackendUploader-RenameRemoteTargetFile]: Renaming "duplicati-20191118T020418Z.dlist.zip.aes" to "duplicati-20191118T020419Z.dlist.zip.aes"
2019-11-17 21:06:40 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: UPDATE "Remotevolume" SET "Name" = "duplicati-20191118T020419Z.dlist.zip.aes" WHERE "Name" = "duplicati-20191118T020418Z.dlist.zip.aes"
2019-11-17 21:06:40 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: UPDATE "Remotevolume" SET "Name" = "duplicati-20191118T020419Z.dlist.zip.aes" WHERE "Name" = "duplicati-20191118T020418Z.dlist.zip.aes" took 0:00:00:00.000
2019-11-17 21:06:40 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalar]: Starting - ExecuteScalar: SELECT "Type" FROM "Remotevolume" WHERE "Name" = "duplicati-20191118T020419Z.dlist.zip.aes"
2019-11-17 21:06:40 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalar]: ExecuteScalar: SELECT "Type" FROM "Remotevolume" WHERE "Name" = "duplicati-20191118T020419Z.dlist.zip.aes" took 0:00:00:00.000
2019-11-17 21:06:40 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: Starting - ExecuteScalarInt64: INSERT INTO "Remotevolume" ("OperationID", "Name", "Type", "State", "Size", "VerificationCount", "DeleteGraceTime") VALUES (16, "duplicati-20191118T020418Z.dlist.zip.aes", "Files", "Deleting", -1, 0, 0); SELECT last_insert_rowid();
2019-11-17 21:06:40 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: ExecuteScalarInt64: INSERT INTO "Remotevolume" ("OperationID", "Name", "Type", "State", "Size", "VerificationCount", "DeleteGraceTime") VALUES (16, "duplicati-20191118T020418Z.dlist.zip.aes", "Files", "Deleting", -1, 0, 0); SELECT last_insert_rowid(); took 0:00:00:00.000
2019-11-17 21:06:40 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-20191118T020419Z.dlist.zip.aes (43.33 KB)
2019-11-17 21:06:43 -05 - [Profiling-Duplicati.Library.Main.Operation.Backup.BackendUploader-UploadSpeed]: Uploaded 43.33 KB in 00:00:03.8674156, 11.20 KB/s
2019-11-17 21:06:43 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-20191118T020419Z.dlist.zip.aes (43.33 KB)
2019-11-17 21:06:43 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Common.DatabaseCommon-CommitTransactionAsync]: Starting - CommitAfterUpload
2019-11-17 21:06:44 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.Common.DatabaseCommon-CommitTransactionAsync]: CommitAfterUpload took 0:00:00:00.327
2019-11-17 21:06:44 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Common.DatabaseCommon-CommitTransactionAsync]: Starting - CommitAfterUpload
2019-11-17 21:06:44 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.Common.DatabaseCommon-CommitTransactionAsync]: CommitAfterUpload took 0:00:00:00.000
2019-11-17 21:06:44 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteReader]: Starting - ExecuteReader: SELECT "ID", "IsFullBackup", "Timestamp" FROM "Fileset" ORDER BY "Timestamp" DESC
2019-11-17 21:06:44 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteReader]: ExecuteReader: SELECT "ID", "IsFullBackup", "Timestamp" FROM "Fileset" ORDER BY "Timestamp" DESC took 0:00:00:00.000
2019-11-17 21:06:44 -05 - [Information-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-StartCheck]: Start checking if backups can be removed
2019-11-17 21:06:44 -05 - [Information-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-FramesAndIntervals]: Time frames and intervals pairs: 1.00:00:00 / Keep all, 7.00:00:00 / 1.00:00:00, 28.00:00:00 / 7.00:00:00, 365.00:00:00 / 31.00:00:00
2019-11-17 21:06:44 -05 - [Information-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-BackupList]: Backups to consider: 11/17/2019 3:52:46 PM, 11/13/2019 6:46:12 AM, 11/7/2019 9:21:06 AM, 10/29/2019 8:41:09 PM, 10/20/2019 2:48:41 PM
2019-11-17 21:06:44 -05 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-NextTimeAndFrame]: Next time frame and interval pair: 1.00:00:00 / Keep all
2019-11-17 21:06:44 -05 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-BackupsInFrame]: Backups in this time frame: 11/17/2019 3:52:46 PM
2019-11-17 21:06:44 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteReader]: Starting - ExecuteReader: SELECT "IsFullBackup" FROM "Fileset" WHERE "Timestamp" = 1574023966
2019-11-17 21:06:44 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteReader]: ExecuteReader: SELECT "IsFullBackup" FROM "Fileset" WHERE "Timestamp" = 1574023966 took 0:00:00:00.000
2019-11-17 21:06:44 -05 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-KeepBackups]: Keeping backup: 11/17/2019 3:52:46 PM
2019-11-17 21:06:44 -05 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-NextTimeAndFrame]: Next time frame and interval pair: 7.00:00:00 / 1.00:00:00
2019-11-17 21:06:44 -05 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-BackupsInFrame]: Backups in this time frame: 11/13/2019 6:46:12 AM
2019-11-17 21:06:44 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteReader]: Starting - ExecuteReader: SELECT "IsFullBackup" FROM "Fileset" WHERE "Timestamp" = 1573645572
2019-11-17 21:06:44 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteReader]: ExecuteReader: SELECT "IsFullBackup" FROM "Fileset" WHERE "Timestamp" = 1573645572 took 0:00:00:00.000
2019-11-17 21:06:44 -05 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-KeepBackups]: Keeping backup: 11/13/2019 6:46:12 AM
2019-11-17 21:06:44 -05 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-NextTimeAndFrame]: Next time frame and interval pair: 28.00:00:00 / 7.00:00:00
2019-11-17 21:06:44 -05 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-BackupsInFrame]: Backups in this time frame: 10/29/2019 8:41:09 PM, 11/7/2019 9:21:06 AM
2019-11-17 21:06:44 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteReader]: Starting - ExecuteReader: SELECT "IsFullBackup" FROM "Fileset" WHERE "Timestamp" = 1572396069
2019-11-17 21:06:44 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteReader]: ExecuteReader: SELECT "IsFullBackup" FROM "Fileset" WHERE "Timestamp" = 1572396069 took 0:00:00:00.000
2019-11-17 21:06:44 -05 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-KeepBackups]: Keeping backup: 10/29/2019 8:41:09 PM
2019-11-17 21:06:44 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteReader]: Starting - ExecuteReader: SELECT "IsFullBackup" FROM "Fileset" WHERE "Timestamp" = 1573136466
2019-11-17 21:06:44 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteReader]: ExecuteReader: SELECT "IsFullBackup" FROM "Fileset" WHERE "Timestamp" = 1573136466 took 0:00:00:00.000
2019-11-17 21:06:44 -05 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-KeepBackups]: Keeping backup: 11/7/2019 9:21:06 AM
2019-11-17 21:06:44 -05 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-NextTimeAndFrame]: Next time frame and interval pair: 365.00:00:00 / 31.00:00:00
2019-11-17 21:06:44 -05 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-BackupsInFrame]: Backups in this time frame: 10/20/2019 2:48:41 PM
2019-11-17 21:06:44 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteReader]: Starting - ExecuteReader: SELECT "IsFullBackup" FROM "Fileset" WHERE "Timestamp" = 1571597321
2019-11-17 21:06:44 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteReader]: ExecuteReader: SELECT "IsFullBackup" FROM "Fileset" WHERE "Timestamp" = 1571597321 took 0:00:00:00.000
2019-11-17 21:06:44 -05 - [Profiling-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-KeepBackups]: Keeping backup: 10/20/2019 2:48:41 PM
2019-11-17 21:06:44 -05 - [Information-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-BackupsToDelete]: Backups outside of all time frames and thus getting deleted:
2019-11-17 21:06:44 -05 - [Information-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-AllBackupsToDelete]: All backups to delete:
2019-11-17 21:06:44 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: DELETE FROM "FilesetEntry" WHERE "FilesetID" NOT IN (SELECT DISTINCT "ID" FROM "Fileset")
2019-11-17 21:06:44 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: DELETE FROM "FilesetEntry" WHERE "FilesetID" NOT IN (SELECT DISTINCT "ID" FROM "Fileset") took 0:00:00:00.000
2019-11-17 21:06:44 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: DELETE FROM "ChangeJournalData" WHERE "FilesetID" NOT IN (SELECT DISTINCT "ID" FROM "Fileset")
2019-11-17 21:06:44 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: DELETE FROM "ChangeJournalData" WHERE "FilesetID" NOT IN (SELECT DISTINCT "ID" FROM "Fileset") took 0:00:00:00.000
2019-11-17 21:06:44 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: DELETE FROM "FileLookup" WHERE "ID" NOT IN (SELECT DISTINCT "FileID" FROM "FilesetEntry")
2019-11-17 21:06:44 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: DELETE FROM "FileLookup" WHERE "ID" NOT IN (SELECT DISTINCT "FileID" FROM "FilesetEntry") took 0:00:00:00.000
2019-11-17 21:06:44 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: DELETE FROM "Metadataset" WHERE "ID" NOT IN (SELECT DISTINCT "MetadataID" FROM "FileLookup")
2019-11-17 21:06:44 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: DELETE FROM "Metadataset" WHERE "ID" NOT IN (SELECT DISTINCT "MetadataID" FROM "FileLookup") took 0:00:00:00.000
2019-11-17 21:06:44 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: DELETE FROM "Blockset" WHERE "ID" NOT IN (SELECT DISTINCT "BlocksetID" FROM "FileLookup" UNION SELECT DISTINCT "BlocksetID" FROM "Metadataset")
2019-11-17 21:06:44 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: DELETE FROM "Blockset" WHERE "ID" NOT IN (SELECT DISTINCT "BlocksetID" FROM "FileLookup" UNION SELECT DISTINCT "BlocksetID" FROM "Metadataset") took 0:00:00:00.000
2019-11-17 21:06:44 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: DELETE FROM "BlocksetEntry" WHERE "BlocksetID" NOT IN (SELECT DISTINCT "ID" FROM "Blockset")
2019-11-17 21:06:44 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: DELETE FROM "BlocksetEntry" WHERE "BlocksetID" NOT IN (SELECT DISTINCT "ID" FROM "Blockset") took 0:00:00:00.002
2019-11-17 21:06:44 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: DELETE FROM "BlocklistHash" WHERE "BlocksetID" NOT IN (SELECT DISTINCT "ID" FROM "Blockset")
2019-11-17 21:06:44 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: DELETE FROM "BlocklistHash" WHERE "BlocksetID" NOT IN (SELECT DISTINCT "ID" FROM "Blockset") took 0:00:00:00.000
2019-11-17 21:06:44 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: INSERT INTO "DeletedBlock" ("Hash", "Size", "VolumeID") SELECT "Hash", "Size", "VolumeID" FROM "Block" WHERE "ID" NOT IN (SELECT DISTINCT "BlockID" AS "BlockID" FROM "BlocksetEntry" UNION SELECT DISTINCT "ID" FROM "Block", "BlocklistHash" WHERE "Block"."Hash" = "BlocklistHash"."Hash")
2019-11-17 21:06:44 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: INSERT INTO "DeletedBlock" ("Hash", "Size", "VolumeID") SELECT "Hash", "Size", "VolumeID" FROM "Block" WHERE "ID" NOT IN (SELECT DISTINCT "BlockID" AS "BlockID" FROM "BlocksetEntry" UNION SELECT DISTINCT "ID" FROM "Block", "BlocklistHash" WHERE "Block"."Hash" = "BlocklistHash"."Hash") took 0:00:00:00.008
2019-11-17 21:06:44 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: DELETE FROM "Block" WHERE "ID" NOT IN (SELECT DISTINCT "BlockID" FROM "BlocksetEntry" UNION SELECT DISTINCT "ID" FROM "Block", "BlocklistHash" WHERE "Block"."Hash" = "BlocklistHash"."Hash")
2019-11-17 21:06:44 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: DELETE FROM "Block" WHERE "ID" NOT IN (SELECT DISTINCT "BlockID" FROM "BlocksetEntry" UNION SELECT DISTINCT "ID" FROM "Block", "BlocklistHash" WHERE "Block"."Hash" = "BlocklistHash"."Hash") took 0:00:00:00.008
2019-11-17 21:06:44 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: Starting - ExecuteNonQuery: UPDATE "RemoteVolume" SET "State" = "Deleting" WHERE "Type" = "Files" AND "State" IN ("Uploaded", "Verified") AND "ID" NOT IN (SELECT "VolumeID" FROM "Fileset")
2019-11-17 21:06:44 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteNonQuery]: ExecuteNonQuery: UPDATE "RemoteVolume" SET "State" = "Deleting" WHERE "Type" = "Files" AND "State" IN ("Uploaded", "Verified") AND "ID" NOT IN (SELECT "VolumeID" FROM "Fileset") took 0:00:00:00.000
2019-11-17 21:06:44 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteReader]: Starting - ExecuteReader: SELECT "Name", "Size" FROM "RemoteVolume" WHERE "Type" = "Files" AND "State" = "Deleting"
2019-11-17 21:06:44 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteReader]: ExecuteReader: SELECT "Name", "Size" FROM "RemoteVolume" WHERE "Type" = "Files" AND "State" = "Deleting" took 0:00:00:00.000
2019-11-17 21:06:44 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.BackendManager-RemoteOperationDelete]: Starting - RemoteOperationDelete
2019-11-17 21:06:44 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Delete - Started: duplicati-20191118T020418Z.dlist.zip.aes ()
2019-11-17 21:06:46 -05 - [Warning-Duplicati.Library.Main.BackendManager-DeleteRemoteFileFailed]: Delete operation failed for duplicati-20191118T020418Z.dlist.zip.aes with FileNotFound, listing contents
Duplicati.Library.Interface.FileMissingException: The requested file does not exist
at Duplicati.Library.Backend.Backblaze.B2.Delete(String remotename)
at Duplicati.Library.Main.BackendManager.DoDelete(FileEntryItem item)
2019-11-17 21:06:46 -05 - [Information-Duplicati.Library.Main.BackendManager-DeleteRemoteFileSuccess]: Listing indicates file duplicati-20191118T020418Z.dlist.zip.aes is deleted correctly
2019-11-17 21:06:46 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.BackendManager-RemoteOperationDelete]: RemoteOperationDelete took 0:00:00:02.276
2019-11-17 21:06:46 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.BackendManager-RemoteOperationNothing]: Starting - RemoteOperationNothing
2019-11-17 21:06:46 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.BackendManager-RemoteOperationNothing]: RemoteOperationNothing took 0:00:00:00.000
2019-11-17 21:06:46 -05 - [Information-Duplicati.Library.Main.Operation.DeleteHandler-DeleteResults]: Deleted 1 remote fileset(s)
2019-11-17 21:06:46 -05 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.BackupHandler-CommitFinalizingBackup]: Starting - CommitFinalizingBackup
2019-11-17 21:06:47 -05 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.BackupHandler-CommitFinalizingBackup]: CommitFinalizingBackup took 0:00:00:00.253
