Any idea what this means? It happens when I I try to backup, although this message was during a repair - I had actually done a delete+repair just before that worked fine. I rebooted the machine and then ran another repair as a check.
2020-08-22 11:59:13 +02 - [Warning-Duplicati.Library.Main.Operation.FilelistProcessor-BackendQuotaNear]: Backend quota is close to being exceeded: Using 107.40 GB of 19.99 GB (3.17 GB available)
It’s been happening ever since I had to rebuild my Windows NAS. The message is on my Fedora Server 32 machine, and connects to an NFS share on the NAS - I have 2 other identical NFS shares being used by Duplicati on 2 other Raspberry-Pi machines and they are fine. Same version of Duplicati and I do not have any “quotas” set anywhere that I am aware of, especially not on the NAS, and there are terabytes of space available.
Seems it was a warning about the root volume being close to full - after scarily increasing its size as it including recreating the swap partition and almost losing the entire server, the job has gone on to reveal another issue which I will post as a new thread.
I have other monitoring in place for disk storage without Duplicati flagging successful backups as “Warning”.
I meant to also add, and the maths of the warning also makes no sense:
2020-09-17 08:30:23 +02 - [Warning-Duplicati.Library.Main.Operation.FilelistProcessor-BackendQuotaNear]: Backend quota is close to being exceeded: Using 116.50 GB of 42.79 GB (10.85 GB available)
116.50GB of 42.79GB ??? 10.85GB available ???
It’s an NFS mount and has over 1TB free - it’s nowhere near right.
I ran the code example, but the mount at /srv/nfs is not shown in isolation:
Drive /
Drive type: Fixed
Volume label: /
File system: xfs
Available space to current user: 14268207104 bytes
Total available space: 14268207104 bytes
Total size of drive: 45946503168 bytes
Drive /boot
Drive type: Fixed
Volume label: /boot
File system: ext
Available space to current user: 710668288 bytes
Total available space: 781131776 bytes
Total size of drive: 1023303680 bytes
Drive /boot/efi
Drive type: Fixed
Volume label: /boot/efi
File system: msdos
Available space to current user: 200556544 bytes
Total available space: 200556544 bytes
Total size of drive: 209489920 bytes
Drive /srv/nextcloud
Drive type: Fixed
Volume label: /srv/nextcloud
File system: xfs
Available space to current user: 145629810688 bytes
Total available space: 145629810688 bytes
Total size of drive: 214643507200 bytes
Drive /var/lib/containers/storage/overlay
Drive type: Fixed
Volume label: /var/lib/containers/storage/overlay
File system: xfs
Drive /var/lib/containers/storage/overlay/7866de17de97b9f75977d10941f18c0c2b47fd677241816113fb435c153f4f94/merged
Drive type: Unknown
Volume label: /var/lib/containers/storage/overlay/7866de17de97b9f75977d10941f18c0c2b47fd677241816113fb435c153f4f94/merged
File system:
Drive /var/lib/containers/storage/overlay/7e0bd118f72c626a8309f1ed0f18ba35b1b45f1f09e6c28103a61f67e7971c0b/merged
Drive type: Unknown
Volume label: /var/lib/containers/storage/overlay/7e0bd118f72c626a8309f1ed0f18ba35b1b45f1f09e6c28103a61f67e7971c0b/merged
File system:
Drive /var/lib/containers/storage/overlay/14d31c65674bc839225eb316b4a3b9395e21bd2ef3f206faaa57f866be6d9fc0/merged
Drive type: Unknown
Volume label: /var/lib/containers/storage/overlay/14d31c65674bc839225eb316b4a3b9395e21bd2ef3f206faaa57f866be6d9fc0/merged
File system:
Drive /var/lib/containers/storage/overlay/b2e4f3684b368a24cbd837919bfc86d669d1e25ea7dc9c1cad65a17fcf2d88fc/merged
Drive type: Unknown
Volume label: /var/lib/containers/storage/overlay/b2e4f3684b368a24cbd837919bfc86d669d1e25ea7dc9c1cad65a17fcf2d88fc/merged
File system:
Drive /var/lib/containers/storage/overlay/d1c4a18bb9ed6fd40530b6186d7676d6e45eab003e3e53fc29f2d3c91db36e2a/merged
Drive type: Unknown
Volume label: /var/lib/containers/storage/overlay/d1c4a18bb9ed6fd40530b6186d7676d6e45eab003e3e53fc29f2d3c91db36e2a/merged
File system:
The mount is shown as:
192.168.1.30:/MAGGIE on /srv/nfs type nfs4 (rw,relatime,vers=4.1,rsize=1048576,wsize=1048576,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.1.70,lo
cal_lock=none,addr=192.168.1.30,_netdev)
I’ll try the threshold setting if it happens again as I was able to clear a few GB of space and the message went away.
