Attempt to create a report for the devs regarding the Root drive path fatal error bug and found that this fails too:
System.Data.SQLite.SQLiteException (0x80004005): SQL logic error or missing database near “)”: syntax error
at System.Data.SQLite.SQLite3.Prepare(SQLiteConnection cnn, String strSql, SQLiteStatement previous, UInt32 timeoutMS, String& strRemain)
at System.Data.SQLite.SQLiteCommand.BuildNextCommand() at System.Data.SQLite.SQLiteDataReader.NextResult()
at System.Data.SQLite.SQLiteDataReader…ctor(SQLiteCommand cmd, CommandBehavior behave)
at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery(CommandBehavior behavior)
at Duplicati.Library.Main.Database.ExtensionMethods.ExecuteNonQuery(IDbCommand self, Boolean writeLog, String cmd, Object values)
at Duplicati.Library.Main.Database.LocalBugReportDatabase.Fix() at Duplicati.Library.Main.Operation.CreateBugReportHandler.Run()
at Duplicati.Library.Main.Controller.CreateLogDatabase(String targetpath)
I tried to create a report both from the Web GUI and from the command line. Same result each time.
Tried again after reverting back to v2.0.4.12 (futzing with the files under %LOCALAPPDATA%\Duplicati\updates) but then got this error message:
The database has version 9 but the largest supported version is 8. This is likely caused by upgrading to a newer version and then downgrading. If this is the case, there is likely a backup file of the previous database version in the folder C:\Users<xxxxxxxx>\AppData\Local\Temp.
No such backup appears to exist.
At this point, I’ll see if I can restore the database from a previous backup (though, I’ll keep the current one).
