What the heck is going on here? This is running on Windows Server 2012 R2. It seems to relate to transport security. However I have this exact same S3 setup working on tons of other Duplicati set ups. I double and triple checked the policy on Wasabi. The only differing thing here is Windows Server 2012 R2. I’ve tried FireFox, Edge, and Chrome. None of my other Wasabi S3 backups on other machines are failing like this one.
Can someone confirm this OS and Duplicati 2.0.6.3 work together?
After a backup fails, if I go back in and look at the source folder it has an exclamation mark on it whereas before when I initially set up the backup it didn’t. It’s not a special folder of any kind and the permissions have not changed from defaults. I could create a new folder anywhere on the C:\ or D:\ drive and get the same error.
Duplicati is running as a service and I have moved the data folder like I always do to C:\ProgramData\Duplicati\Data.
Failed: One or more errors occurred.
Details: System.AggregateException: One or more errors occurred. —> System.AggregateException: Unable to read data from the transport connection: The connection was closed. —> System.IO.IOException: Unable to read data from the transport connection: The connection was closed.
at CoCoL.AutomationExtensions.d__101.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Duplicati.Library.Main.Operation.BackupHandler.<FlushBackend>d__19.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__20.MoveNext() --- End of inner exception stack trace --- at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__20.MoveNext() --- End of inner exception stack trace --- at CoCoL.ChannelExtensions.WaitForTaskOrThrow(Task task) at Duplicati.Library.Main.Controller.<>c__DisplayClass14_0.<Backup>b__0(BackupResults result) at Duplicati.Library.Main.Controller.RunAction[T](T result, String[]& paths, IFilter& filter, Action1 method)
—> (Inner Exception #0) System.AggregateException: Unable to read data from the transport connection: The connection was closed. —> System.IO.IOException: Unable to read data from the transport connection: The connection was closed.
at CoCoL.AutomationExtensions.d__101.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Duplicati.Library.Main.Operation.BackupHandler.<FlushBackend>d__19.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__20.MoveNext() --- End of inner exception stack trace --- at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__20.MoveNext() ---> (Inner Exception #0) System.IO.IOException: Unable to read data from the transport connection: The connection was closed. at CoCoL.AutomationExtensions.<RunTask>d__101.MoveNext()
at Duplicati.Library.Main.Operation.BackupHandler.d__19.MoveNext()
at Duplicati.Library.Main.Operation.BackupHandler.d__20.MoveNext()<—
—> (Inner Exception #1) System.AggregateException: One or more errors occurred. —> System.IO.IOException: Unable to read data from the transport connection: The connection was closed.
at CoCoL.AutomationExtensions.d__101.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Duplicati.Library.Main.Operation.BackupHandler.<FlushBackend>d__19.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__20.MoveNext() --- End of inner exception stack trace --- ---> (Inner Exception #0) System.IO.IOException: Unable to read data from the transport connection: The connection was closed. at CoCoL.AutomationExtensions.<RunTask>d__101.MoveNext()
Log data:
2023-02-24 06:06:43 -05 - [Error-Duplicati.Library.Main.Operation.BackupHandler-FatalError]: Fatal error
at CoCoL.AutomationExtensions.d__10`1.MoveNext()
