Hey! I created a seperate thread for my issue with the latest canary cli build ( v2.0.9.107_canary_2024-09-11) since there are multiple discussions running in parallel in the release threat.
So my problem is that after a starting the cli duplicati as a service on Ubuntu 24.04.1 LTS it seems to start normally. I then copy the token URL from syslog and open the URL on my windows machine. (replacing localhost with the server name).
The browser (Brave/Chrome) will show a “Signin failed: error” notification and duplicati asks me to provide a “JWT Signin Token”.
The server shows a quite lengthy error message (see below) each time i try to open the url or click on “sign in”
At the moment i can not open the sign in link on the server itself, as i have only an ssh/cli access and no GUI.
I assume that the connection the duplicati is fine since i see the Login screen in the duplicati design
The token / url is correct, as i copy and pasted it from the syslog - although changing a few characters in the token produces the same error message in the log!
Are there any ideas how i can troubleshoot this issue?
2024-09-30T11:42:30.579290+02:00 mediabox duplicati-server[460591]: fail: Microsoft.AspNetCore.Diagnostics.ExceptionHandlerMiddleware[1]
2024-09-30T11:42:30.579762+02:00 mediabox duplicati-server[460591]: An unhandled exception has occurred while executing the request.
2024-09-30T11:42:30.579781+02:00 mediabox duplicati-server[460591]: System.InvalidOperationException: Headers are read-only, response has already started.
2024-09-30T11:42:30.579801+02:00 mediabox duplicati-server[460591]: at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Http.HttpHeaders.ThrowHeadersReadOnlyException()
2024-09-30T11:42:30.579826+02:00 mediabox duplicati-server[460591]: at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Http.HttpResponseHeaders.Microsoft.AspNetCore.Http.IHeaderDictionary.set_ContentType(StringValues value)
2024-09-30T11:42:30.579849+02:00 mediabox duplicati-server[460591]: at Microsoft.AspNetCore.Http.DefaultHttpResponse.set_ContentType(String value)
2024-09-30T11:42:30.579868+02:00 mediabox duplicati-server[460591]: at Microsoft.AspNetCore.Http.HttpResponseJsonExtensions.WriteAsJsonAsync[TValue](HttpResponse response, TValue value, JsonTypeInfo`1 jsonTypeInfo, String contentType, CancellationToken cancellationToken)
2024-09-30T11:42:30.579889+02:00 mediabox duplicati-server[460591]: at Microsoft.AspNetCore.Internal.ExecuteHandlerHelper.WriteJsonResponseAsync[T](HttpResponse response, T value, JsonTypeInfo`1 jsonTypeInfo)
2024-09-30T11:42:30.579909+02:00 mediabox duplicati-server[460591]: at Microsoft.AspNetCore.Internal.ExecuteHandlerHelper.ExecuteReturnAsync(Object obj, HttpContext httpContext, JsonTypeInfo`1 jsonTypeInfo)
2024-09-30T11:42:30.579946+02:00 mediabox duplicati-server[460591]: at lambda_method186(Closure, Object, HttpContext, Object)
2024-09-30T11:42:30.579973+02:00 mediabox duplicati-server[460591]: at Microsoft.AspNetCore.Http.RequestDelegateFactory.<>c__DisplayClass102_2.<<HandleRequestBodyAndCompileRequestDelegateForJson>b__2>d.MoveNext()
2024-09-30T11:42:30.579996+02:00 mediabox duplicati-server[460591]: --- End of stack trace from previous location ---
2024-09-30T11:42:30.580021+02:00 mediabox duplicati-server[460591]: at Duplicati.WebserverCore.Middlewares.WebsocketExtensions.<>c__DisplayClass0_0.<<UseNotifications>b__0>d.MoveNext()
2024-09-30T11:42:30.580039+02:00 mediabox duplicati-server[460591]: --- End of stack trace from previous location ---
2024-09-30T11:42:30.580059+02:00 mediabox duplicati-server[460591]: at Microsoft.AspNetCore.Diagnostics.ExceptionHandlerMiddlewareImpl.<Invoke>g__Awaited|10_0(ExceptionHandlerMiddlewareImpl middleware, HttpContext context, Task task)
2024-09-30T11:42:30.580086+02:00 mediabox duplicati-server[460591]: warn: Microsoft.AspNetCore.Diagnostics.ExceptionHandlerMiddleware[2]
2024-09-30T11:42:30.580105+02:00 mediabox duplicati-server[460591]: The response has already started, the error handler will not be executed.
2024-09-30T11:42:30.580150+02:00 mediabox duplicati-server[460591]: fail: Microsoft.AspNetCore.Server.Kestrel[13]
2024-09-30T11:42:30.580171+02:00 mediabox duplicati-server[460591]: Connection id "0HN716A0C5DO1", Request id "0HN716A0C5DO1:00000001": An unhandled exception was thrown by the application.
2024-09-30T11:42:30.580274+02:00 mediabox duplicati-server[460591]: System.InvalidOperationException: Headers are read-only, response has already started.
2024-09-30T11:42:30.580292+02:00 mediabox duplicati-server[460591]: at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Http.HttpHeaders.ThrowHeadersReadOnlyException()
2024-09-30T11:42:30.580311+02:00 mediabox duplicati-server[460591]: at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Http.HttpResponseHeaders.Microsoft.AspNetCore.Http.IHeaderDictionary.set_ContentType(StringValues value)
2024-09-30T11:42:30.580330+02:00 mediabox duplicati-server[460591]: at Microsoft.AspNetCore.Http.DefaultHttpResponse.set_ContentType(String value)
2024-09-30T11:42:30.580348+02:00 mediabox duplicati-server[460591]: at Microsoft.AspNetCore.Http.HttpResponseJsonExtensions.WriteAsJsonAsync[TValue](HttpResponse response, TValue value, JsonTypeInfo`1 jsonTypeInfo, String contentType, CancellationToken cancellationToken)
2024-09-30T11:42:30.580366+02:00 mediabox duplicati-server[460591]: at Microsoft.AspNetCore.Internal.ExecuteHandlerHelper.WriteJsonResponseAsync[T](HttpResponse response, T value, JsonTypeInfo`1 jsonTypeInfo)
2024-09-30T11:42:30.580392+02:00 mediabox duplicati-server[460591]: at Microsoft.AspNetCore.Internal.ExecuteHandlerHelper.ExecuteReturnAsync(Object obj, HttpContext httpContext, JsonTypeInfo`1 jsonTypeInfo)
2024-09-30T11:42:30.580411+02:00 mediabox duplicati-server[460591]: at lambda_method186(Closure, Object, HttpContext, Object)
2024-09-30T11:42:30.580429+02:00 mediabox duplicati-server[460591]: at Microsoft.AspNetCore.Http.RequestDelegateFactory.<>c__DisplayClass102_2.<<HandleRequestBodyAndCompileRequestDelegateForJson>b__2>d.MoveNext()
2024-09-30T11:42:30.580446+02:00 mediabox duplicati-server[460591]: --- End of stack trace from previous location ---
2024-09-30T11:42:30.580463+02:00 mediabox duplicati-server[460591]: at Duplicati.WebserverCore.Middlewares.WebsocketExtensions.<>c__DisplayClass0_0.<<UseNotifications>b__0>d.MoveNext()
2024-09-30T11:42:30.580481+02:00 mediabox duplicati-server[460591]: --- End of stack trace from previous location ---
2024-09-30T11:42:30.580500+02:00 mediabox duplicati-server[460591]: at Microsoft.AspNetCore.Diagnostics.ExceptionHandlerMiddlewareImpl.<Invoke>g__Awaited|10_0(ExceptionHandlerMiddlewareImpl middleware, HttpContext context, Task task)
2024-09-30T11:42:30.580519+02:00 mediabox duplicati-server[460591]: at Microsoft.AspNetCore.Diagnostics.ExceptionHandlerMiddlewareImpl.HandleException(HttpContext context, ExceptionDispatchInfo edi)
2024-09-30T11:42:30.580557+02:00 mediabox duplicati-server[460591]: at Microsoft.AspNetCore.Diagnostics.ExceptionHandlerMiddlewareImpl.<Invoke>g__Awaited|10_0(ExceptionHandlerMiddlewareImpl middleware, HttpContext context, Task task)
2024-09-30T11:42:30.580576+02:00 mediabox duplicati-server[460591]: at Microsoft.AspNetCore.Authorization.AuthorizationMiddleware.Invoke(HttpContext context)
2024-09-30T11:42:30.580600+02:00 mediabox duplicati-server[460591]: at Microsoft.AspNetCore.Authentication.AuthenticationMiddleware.Invoke(HttpContext context)
2024-09-30T11:42:30.580618+02:00 mediabox duplicati-server[460591]: at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Http.HttpProtocol.ProcessRequests[TContext](IHttpApplication`1 application)
