I just tried setting up a backup to box.com and while the Test worked (created the folders on the destination) when running the actual backup I’m getting the errors below in the global log and no files are actually being written.
Any thoughts on what’s going on?
Note that this is current a TEST secondary backup so there’s no critical timeframe involved here.
Job Remote log
Jun 9, 2018 3:39 PM: put duplicati-b895ff227c2a94a3596ef38161137d92a.dblock.zip.aes
{"Size":52418413,"Hash":"DuORNnUmhtutErN7f6EAeEO7I9OxKnirwQBM9PLV+r8="}
Jun 9, 2018 3:39 PM: put duplicati-bf08b1974f10d4055b68697b5e71fa648.dblock.zip.aes
{"Size":52376589,"Hash":"d927d38JcbbtMHJFV3mya1AGB/DCyJBq+PJ1cgIvXD4="}
Jun 9, 2018 3:38 PM: put duplicati-bb700b801bb104853b73712338009d697.dblock.zip.aes
Jun 9, 2018 3:38 PM: put duplicati-bbb80d4da426b4b13bbd2053e4fe3a9b6.dblock.zip.aes
Jun 9, 2018 3:38 PM: put duplicati-b4da0c28f9657427bbc74af0e653dc0ee.dblock.zip.aes
Jun 9, 2018 3:38 PM: put duplicati-b3251ccd2fdd14c00bd29d0dd8d567e63.dblock.zip.aes
Jun 9, 2018 3:38 PM: list
Global log
Details: System.AggregateException: One or more errors occurred. ---> System.AggregateException: The channel is retired ---> CoCoL.RetiredException: The channel is retired
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <a6f810169ec746eeb2789b925e2858c0>:0
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <a6f810169ec746eeb2789b925e2858c0>:0
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <a6f810169ec746eeb2789b925e2858c0>:0
at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <a6f810169ec746eeb2789b925e2858c0>:0
at System.Runtime.CompilerServices.TaskAwaiter`1[TResult].GetResult () [0x00000] in <a6f810169ec746eeb2789b925e2858c0>:0
at CoCoL.Channel`1+<WriteAsync>d__30[T].MoveNext () [0x00196] in <6973ce2780de4b28aaa2c5ffc59993b1>:0
at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <a6f810169ec746eeb2789b925e2858c0>:0
at Duplicati.Library.Main.Operation.BackupHandler+<FlushBackend>d__17.MoveNext () [0x000a1] in <40779f99a9ca4af297e4fb6724fb75c9>:0
at Duplicati.Library.Main.Operation.BackupHandler+<RunAsync>d__18.MoveNext () [0x00c68] in <40779f99a9ca4af297e4fb6724fb75c9>:0
at Duplicati.Library.Main.Operation.BackupHandler+<RunAsync>d__18.MoveNext () [0x00fdb] in <40779f99a9ca4af297e4fb6724fb75c9>:0
at CoCoL.ChannelExtensions.WaitForTaskOrThrow (System.Threading.Tasks.Task task) [0x0005d] in <6973ce2780de4b28aaa2c5ffc59993b1>:0
at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String[] sources, Duplicati.Library.Utility.IFilter filter) [0x00008] in <40779f99a9ca4af297e4fb6724fb75c9>:0
at Duplicati.Library.Main.Controller+<>c__DisplayClass15_0.<Backup>b__0 (Duplicati.Library.Main.BackupResults result) [0x00035] in <40779f99a9ca4af297e4fb6724fb75c9>:0
at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action`1[T] method) [0x0011d] in <40779f99a9ca4af297e4fb6724fb75c9>:0
---> (Inner Exception #0) System.AggregateException: The channel is retired ---> CoCoL.RetiredException: The channel is retired
---> (Inner Exception #0) CoCoL.RetiredException: The channel is retired
at Duplicati.Library.Main.Operation.BackupHandler+<RunAsync>d__18.MoveNext () [0x00c68] in <40779f99a9ca4af297e4fb6724fb75c9>:0 <---
---> (Inner Exception #1) System.AggregateException: One or more errors occurred. ---> System.NullReferenceException: Object reference not set to an instance of an object
at Duplicati.Library.Backend.Box.BoxBackend.Put (System.String remotename, System.IO.Stream stream) [0x0003a] in <5a0199835c96441c90f8648b7cc6e561>:0
at Duplicati.Library.Main.Operation.Common.BackendHandler+<DoPut>d__23.MoveNext () [0x00447] in <40779f99a9ca4af297e4fb6724fb75c9>:0
at Duplicati.Library.Main.Operation.Common.BackendHandler+<>c__DisplayClass13_0+<<UploadFileAsync>b__2>d.MoveNext () [0x00152] in <40779f99a9ca4af297e4fb6724fb75c9>:0
at Duplicati.Library.Main.Operation.Common.BackendHandler+<DoWithRetry>d__21`1[T].MoveNext () [0x0060f] in <40779f99a9ca4af297e4fb6724fb75c9>:0
at Duplicati.Library.Main.Operation.Common.BackendHandler+<>c__DisplayClass13_0+<<UploadFileAsync>b__1>d.MoveNext () [0x000a7] in <40779f99a9ca4af297e4fb6724fb75c9>:0
at Duplicati.Library.Main.Operation.Common.BackendHandler+<UploadFileAsync>d__13.MoveNext () [0x00172] in <40779f99a9ca4af297e4fb6724fb75c9>:0
at System.Runtime.CompilerServices.TaskAwaiter.GetResult () [0x00000] in <a6f810169ec746eeb2789b925e2858c0>:0
at Duplicati.Library.Main.Operation.Backup.BackendUploader+<>c__DisplayClass0_0+<<Run>b__0>d.MoveNext () [0x004d6] in <40779f99a9ca4af297e4fb6724fb75c9>:0
at CoCoL.AutomationExtensions+<RunTask>d__10`1[T].MoveNext () [0x000cc] in <6973ce2780de4b28aaa2c5ffc59993b1>:0
---> (Inner Exception #0) System.NullReferenceException: Object reference not set to an instance of an object
at CoCoL.AutomationExtensions+<RunTask>d__10`1[T].MoveNext () [0x000cc] in <6973ce2780de4b28aaa2c5ffc59993b1>:0 <---
---> (Inner Exception #2) System.AggregateException: One or more errors occurred. ---> System.Exception: Unable to find log in lookup table, this may be caused by attempting to transport call contexts between AppDomains (eg. with remoting calls)
at Duplicati.Library.Logging.Log.get_CurrentScope () [0x0005d] in <057e33272c83418ab237a78073cd3fbb>:0
at Duplicati.Library.Logging.Log.WriteMessage (Duplicati.Library.Logging.LogMessageType type, System.String tag, System.String id, System.Exception ex, System.String message, System.Object[] arguments) [0x0001e] in <057e33272c83418ab237a78073cd3fbb>:0
at Duplicati.Library.Logging.Log.WriteWarningMessage (System.String tag, System.String id, System.Exception ex, System.String message, System.Object[] arguments) [0x00000] in <057e33272c83418ab237a78073cd3fbb>:0
at Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess+<>c.<Run>b__1_3 (System.String rootpath, System.String path, System.Exception ex) [0x00000] in <40779f99a9ca4af297e4fb6724fb75c9>:0
at Duplicati.Library.Utility.Utility+<EnumerateFileSystemEntries>d__23.MoveNext () [0x0030e] in <812a40995e6d42b19698755830d83d9b>:0
at System.Linq.Enumerable+SelectManySingleSelectorIterator`2[TSource,TResult].MoveNext () [0x0006f] in <abeb153532fb46718501a600866a8d76>:0
at Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess+<>c__DisplayClass1_0+<<Run>b__0>d.MoveNext () [0x002e6] in <40779f99a9ca4af297e4fb6724fb75c9>:0
---> (Inner Exception #0) System.Exception: Unable to find log in lookup table, this may be caused by attempting to transport call contexts between AppDomains (eg. with remoting calls)
Log data:
2018-06-09 15:38:04 -05 - [Warning-Duplicati.Library.Main.Operation.Backup.UploadSyntheticFilelist-MissingTemporaryFilelist]: Expected there to be a temporary fileset for synthetic filelist (1, duplicati-20180609T200240Z.dlist.zip.aes), but none was found?
2018-06-09 15:39:05 -05 - [Warning-Duplicati.Library.Main.Operation.Backup.MetadataPreProcess.FileEntry-ProcessingMetadataFailed]: Failed to process entry, path: /source/eBooks & manuals/HP Hub 24R Management Module Manual (j3210001).pdf
at CoCoL.Channel`1+<WriteAsync>d__30[T].MoveNext () [0x0072d] in <6973ce2780de4b28aaa2c5ffc59993b1>:0
at Duplicati.Library.Main.Operation.Backup.MetadataPreProcess+<>c__DisplayClass2_0+<<Run>b__0>d.MoveNext () [0x004de] in <40779f99a9ca4af297e4fb6724fb75c9>:0
2018-06-09 15:39:05 -05 - [Warning-Duplicati.Library.Main.Operation.Backup.MetadataPreProcess.FileEntry-ProcessingMetadataFailed]: Failed to process entry, path: /source/eBooks & manuals/HP Hub-24R Manual (j3212001).pdf
2018-06-09 15:39:05 -05 - [Warning-Duplicati.Library.Main.Operation.Backup.MetadataPreProcess.FileEntry-ProcessingMetadataFailed]: Failed to process entry, path: /source/eBooks & manuals/LTZoom110sellsheet.pdf
I have the the Live ‘Profiling’ log JSON version available as well if it would be useful.
