I’m getting the following warnings on one of my backup jobs. I’m not using authentication, how can I clear this from happening? See warnings below:
2020-11-04 17:30:00 +00 - [Warning-Duplicati.Library.Main.Controller-UnsupportedOption]: The supplied option --auth-username is not supported and will be ignored
2020-11-04 17:30:00 +00 - [Warning-Duplicati.Library.Main.Controller-UnsupportedOption]: The supplied option --auth-password is not supported and will be ignored
First, if you allow your browser to fill username and password for web sites, delete its data for Duplicati, typically at address localhost:8200 but yours may vary. If you don’t do this, it will also break your restore.
