Hi, I know that the canary versions are not tested fully, hence this isn’t a complain… however, having just installed 2.0.3.9 I can immediately see that the status bar is different and displays bytes to go (in a negative number ??).
any chance of having the Kb/s or Mb/s back?
Did you tried to search?
Still seeing the negative bytes sometimes in 2.0.4.22. Any thoughts?
I believe this pull request will fix the issue:
