So, while doing some server clean up, I noticed the .config/Duplicati folder was 20GB, seemed pretty large for some local database files. I figured that the DB needed compacting or something, then I stumbled on this previous post Orphan sqlite files?, sure enough I have files in there going back to when I started using Duplicati. Based on the information, these look like backups from the time the upgrade required a new DB. We can cleanup, right?
Yep, you guessed it, I made a mistake and cleaned up before verifying that I had copies of the files in that folder first. There were several named <backupid>.backup*, several named, backup <backupid> <timestamp>.sqlite, so I figured I’d remove anything that was older than last year. What I didn’t spot was that there was one named <backupid>.sqlite so when I did rm <backupid>.* I deleted the most recent file.
No worries, right? Right?! There is a magical button that should rebuild this file. Under “backup” > Advanced > Database, there are maintenance options that allow you to rebuild the database when the local and remote files are out of sync, this seems like the option we’d want. When I execute, it fails with “The operation Test has failed with error: The requested folder does not exist. FolderMissingException: The requested folder does not exist”, but doesn’t list what folder doesn’t exist, so I’m not sure what it’s looking for.
"MainOperation": "Test",
"VerificationsActualLength": 0,
"Verifications": [],
"ParsedResult": "Fatal",
"Interrupted": false,
"Version": "2.0.7.103 (2.0.7.103_canary_2024-04-19)",
"EndTime": "2024-09-10T15:19:35.213793Z",
"BeginTime": "2024-09-10T15:18:54.605038Z",
"Duration": "00:00:40.6087550",
"MessagesActualLength": 11,
"ErrorsActualLength": 1,
"2024-09-10 08:18:54 -07 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Test has started",
"2024-09-10 08:18:54 -07 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: ()",
"2024-09-10 08:18:54 -07 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Retrying: ()",
"2024-09-10 08:19:04 -07 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: ()",
"2024-09-10 08:19:04 -07 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Retrying: ()",
"2024-09-10 08:19:14 -07 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: ()",
"2024-09-10 08:19:15 -07 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Retrying: ()",
"2024-09-10 08:19:25 -07 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: ()",
"2024-09-10 08:19:25 -07 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Retrying: ()",
"2024-09-10 08:19:35 -07 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: ()",
"2024-09-10 08:19:35 -07 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Failed: ()"
"Warnings": [],
"2024-09-10 08:19:35 -07 - [Error-Duplicati.Library.Main.Controller-FailedOperation]: The operation Test has failed with error: The requested folder does not exist\nFolderMissingException: The requested folder does not exist"
"RemoteCalls": 5,
"BytesUploaded": 0,
"BytesDownloaded": 0,
"FilesUploaded": 0,
"FilesDownloaded": 0,
"FilesDeleted": 0,
"RetryAttempts": 4,
"UnknownFileSize": 0,
"UnknownFileCount": 0,
"KnownFileCount": 0,
"KnownFileSize": 0,
"BackupListCount": 0,
"TotalQuotaSpace": 0,
"FreeQuotaSpace": 0,
"AssignedQuotaSpace": 0,
"BeginTime": "2024-09-10T15:18:54.605042Z",
"Errors": null
Any idea what folder it is looking for? Any idea how to regenerate the sqlite database so it can correctly list the backups?
