Hey Guys,
I installed Duplicati on my FreeNAS system. I then launched it by going to http://192.168.42.209:8200. I was asked for a passowrd and the default password “duplicati” worked. Once logged in I change some settings, including my password. The settings changed BUT…
After I re-start the Jail (or re-start the whole NAS) the settings are re-set to default. This includes the password, which is changed back to the default password of “duplicati”.
How can I make my settings save?
I notice there is something in the post install notes which says:
“To change settings until the UI is fixed use the command line. Example: iocage get -P port PLUGIN
Configurable settings are port and webpass.”
However I can’t really figure out what this means, and was hoping someone is able to help me?
