I just set up a Truenas on a HP Proliant Microserver and installed the Duplicati-Plugin.
Works fine with the settings form this post:
Thanks for that.
But now I tried to change the password, witch worked fine until you stop duplicati and star it again.
When you do so, the password is set to duplicati again.
Is there a way to keep the changes you made?
Hope someone can help me.
Duplicati.Server.exe shows option third-party plugin you are running is probably using each start.
You can probably use your ps command with the correct options to see the options Duplicati got.
--webservice-password
The password required to access the webserver. This option is saved so you do not need to set it on each run. Setting an empty value disables the password.
If you like to use Settings to change the password (which is the way Duplicati ships it), avoid that.
Other Google search references that may or may not apply:
Note that TrueNAS CORE, being FreeBSD, won’t run a future version of Duplicati. SCALE should.
This won’t be an immediate problem, and possibly .NET will be ported to FreeBSD by that version.
