I have an external hard drive that crashed and am trying to restore the data from a cloud backup that is about 3 months old - S3 Compatible storage.
Apparently Duplicati stopped running after one of my OS upgrades. I found out a way to get it started up in the newer versions of MacOS thanks to a post on a forum. I am running 2.0.6.3_beta on MacOS Ventura currently.
I (think) I have an intact database, but when I tried to just test restoring a single file, it said successful in the UI, but the file did not restore. There is an error logged “Found 3462 remote files that are not recorded in local storage, please run repair” I started a repair but it was taking forever. I tried to run another backup to see if I could get the data insync, but it failed because the drive (that failed) was missing. I set the options to allow missing source, but then the backup still failed because of the same error about remote files not recorded in local storage.
I thought I would try just doing a restore directly, so I connected to the storage, it ran for a little bit, but alowed me to select the folders I wanted to restore, which is basically everything, and now it is running a “Recreate database”. It is probably 35% done on the progress bar, but it has been about 5 hours. I wouldn’t normally be concerned, but there are a ton of errors logged “Operation Get with file duplicati-xxxx.dIndex.zip.aes attempt 1 of 5 failed with message: The specified key does not exist.” The expanded error is “Amazon.SE.AmazonSeException”,“Message”:“The specified key does not exist.”,“Data”:null,“InnerException” blah blah “The remote server returned an error: (404) Not Found” After the 5 tries I end up with Failed to process Index file X
I would normally think I didn’t set something correct on the Bucket, but every so often I see one showing up as Operation Get - Completed:
I searched for one of the retry files in the bucket, and it is present. Not sure what to do at this point. Will the rebuild complete even with these errors? It seems to keep moving on to the next files and saying processing index list volume x of x
I have considered maybe it’s taking longer because the files are in cloud? Should I download my whole bucket files locally and try to run it then? At this point I don’t care about the backup, I just want to get my files back
