Restore error: "Index was outside the bounds of the array"
Hello,
I am attempting to run a restore and consistently get the error “Index was outside the bounds of the array.” I am running Duplicati 2.2.0.3 - 2.2.0.3_stable_2026-01-06 in docker on Unraid.
I am trying to restore from an Unraid NAS to a Win 11 machine via an SMG share.
The errors in the log are:
"2026-01-22 12:16:25 -05 - [Error-Duplicati.Library.Main.Operation.Restore.VolumeDownloader-DownloadError]: Error during download\nIndexOutOfRangeException: Index was outside the bounds of the array.""2026-01-22 12:16:25 -05 - [Error-Duplicati.Library.Main.Operation.Restore.BlockManager-BlockCountError]: Block count in SleepableDictionarys block table is not zero: 2\nFirst 10 blocks: 2992075, 3000315""2026-01-22 12:16:25 -05 - [Error-Duplicati.Library.Main.Operation.Restore.BlockManager-VolumeCountError]: Volume count in SleepableDictionarys volume table is not zero: 2\nFirst 10 volumes: 43040, 43134""2026-01-22 12:16:25 -05 - [Error-Duplicati.Library.Main.Controller-FailedOperation]: The operation Restore has failed\nIndexOutOfRangeException: Index was outside the bounds of the array."
I have run a database repair and it did not help.
The restore job restores the files to the target but they are size of 0Bytes.
I have selected earlier version of the backup and it did not help.
Please help.
…Steve
I got this exact problem when I was trying to restore to a RAM disk folder (/dev/shm) in Linux. It worked for me restoring to an SSD drive on that machine. See this, for example:
https://forum.duplicati.com/t/restore-failing-on-every-attempt/21786
Can you try it to a folder on the same machine as duplicati, and then copy it over manually?
Danny,
I forgot to reply to this. I did try this method to restore to another share on my unRAID NAS and it did not work. My apologies for forgetting to let you know.
…Steve
Please don’t worry,
Dan
I’m having the same problem. Did you ever figure out the solution?
I’m definitely not an expert. I believe the solution is using the –legacy-restore option during restore or using the new beta version or waiting for the new stable version to come out (see The restore fails immediately with the following error: Index was outside the bounds of the array - #11 by kenkendk ). My restore turned messy from my own stupidity.
What were your mistakes so I don’t repeat them. :thinking: I did a complete database rebuild but that didn’t work. I’ll try enabling that option now and see how it goes. I’m not seeing the ability to add “advanced options” to a restore job. I see it in the “Options” section but it doesn’t seem to be saving the settings. When I exit and go back to options, the entry is gone. I’m trying in the legacy interface now.
I spoke too soon. seems to have saved in the new interface. Maybe it just needed a refresh. The legacy interface is so painfully slow when selecting files so I’m glad. Here goes nothing…
Success! Thanks for pointing me in the right direction.
