I had to do a full restore on a Backup recently. Decided that now would be a god time to try from Duplicati
Turned out it had 2 dblock files missing. I effected roughly 54 files. I was able to restore same files from another source. I have 2 questions.
Rather then run a full repair, If I delete the versions with the missing deblocks will my next backup include the effected files
Is there any quick way to check if all files on remote storage exist
Check out this thread for some info and how to go about recovering:
Regarding this:
Normally Duplicati checks for the presence of all files remote files at the start of every backup operation. Has it been a long time since you ran a backup? Or did you perhaps turn off this check?
--no-backend-verification = false
If this flag is set, the local database is not compared to the remote filelist on startup. The intended usage for this option is to work correctly in cases where the filelisting is broken or unavailable.
What’s that? The REPAIR command has two behaviors. Do you mean recreate entire database?
That’s usually the one that potentially can be painfully slow, especially if some data is hard to find.
This is too vague. If somehow the current version wasn’t affected, the next one is likely fine now.
If files were deleted in the current version, then next backup should backup current view of them.
This isn’t special treatment. Duplicati always backs up what look to it like added or modified files.
@ts678
It was a normal restore. I used what I thought was a consistent Database.
Checked the config file and yes my bad had enabled the --no-backend-verification = false at some point and forgot to remove it. Backup in question has previously given trouble during file upload (ISP is over the Air) and I have removed versions that had failed previously due to incomplete/partial uploads.
Backup Data is mostly Daily additions with very little modification of files.
I want avoid a full database repair but my database is out of sync with the backend.
From reading the link that drwtsn32 provided my best plan of action would be purge-broken-files and run a backup ?
Recovering by purging files probably fits. You check list-broken-files before letting the purge-broken-files run. These tools appear to work best when there are missing (not corrupted) dblock (and not some other type) of files, however your situation sounds all set to go. After the purge, backup and it should backup what it needs.
Once I purged the broken files the following backup failed to run. Got file set errors.
Unexpected difference in fileset version 328: 15/09/2020 09:11:09 (database id: 276), found 105536 entries, but expected 105545
Repair did not resolve. the issue is FilesetEntry Tables from 275 onwards contains 9 FileID’s that are not in the FileLookup Table. Once I removed these FileIDs from the FilesetEntry Table Backup now completes. All broken Files previously listed are in the latest version rather then Version 328.
This error probably goes back to a version delete when running on 2.0.4 that went amiss and the workaround at the time was to disable the file set check.
I do suspect that the backend is probably broken and I may not be able to Recover without a DB.
I plan to archive/retain this backup and with its Database and start another backup from scratch.
