I did an initial backup of many of my computer folders. Around 300GB was backed-up to some cloud storage, which took a long time (slow upload speed).
I have now deleted some those folders (about 50GB) on my computer and would like the backups to reflect this (data to be deleted too, to save some space), without having to do a full backup again?
Do I just run my backup again, but only keep 1 last version of the backup? Currently, the setting is smart backup. Or do I need to use the purge command specifying specific folders?
Thanks
Welcome to the forums @TedTomato
Other than your retention settings, yes just run the backup again. Due to your retention settings the original backup containing that extra 50GB of data will not be removed until a year passes.
To make it flush out sooner adjust your retention settings to either “Delete backups that are older than” and give it a value greater than when the last backup occurred or set it to “Keep a specific number of backups” with a value of 1. Once the backup runs a second time it will clean up that 50GBs and use that backup as the base, next return the retention setting to “Smart backup retention” and proceed from there.
This backup shouldn’t take as long as the first backup did but it will have some heavy lifting to do while it figures out where that 50GBs of data is located and how many dblock files need to be re-written. Once you get to a steady state where big deletions or file system changes are not huge (less than a few GB), subsequent backups will be much quicker.
Thanks, @JimboJones
I tried the purge command but that didn’t work.
I then changed the retention to only retain the last backup, and that did remove about 50GB of the backup and the relevant files. It took a long time, but that worked.
