To confirm, rclone is set up for native pCloud, not WebDAV, right? Attempting to bypass the WebDAV error.
Yes right, initial backup, app. 80GB, same data data as WebDAV based job causing problems.
I will try to check the log asap and report.
I found this entry in the log:
Sep 30, 2022 2:49 AM: put duplicati-b536ad8f6b21f498081f1d6835fcd586d.dblock.zip.aes
{"Size":52365517,"Hash":"Jg7iV0zBY1p5UDv5+5VDSsEE097ErAVslqbXCoO4Faw="}
I’ll give DB Browser a try tomorrow.
Your message is just repeating what the slightly more human-friendly message earlier said to check for.
Basically, file’s size is now wrong and (not surprisingly given wrong size) the hash doesn’t match either.
That was my understanding too, not good. Very strange the backups are reported successfully on the first look, but a few of the mass of files shoul be not recoverable - right?
I started a third version of the job with a local destination in the meantime. Ducplicati interface no rclone, configured all new - no errors, no warnings two runs so far.
Does to make sense to look into the Database with DB Browser for SQLite - if yes I’ll try.
No idea what is special about the Webspace, the job, the machine, me? So many people using Duplicati…
What do you mean? There’s no screenshot of successful backup. On the other hand, there’s only a warning, indicated by yellow. If you mean why isn’t it a red error, that was discussed before. Or is this a new concern?
Very likely. You can type the bad dblock name into The AFFECTED command in Commandline to find what. Cleaning things up means deleting the broken dblock, then running a Recovering by purging files procedure.
Mainly if you wish to try to learn things like where in the upload sequence the bad upload was – not that it’s likely anything can immediately be fixed, and if the problem is pCloud, then it would be up to them to solve. Approaching them might get the previously heard answer about WebDAV, or might ask you what you tried.
At https://forum.rclone.org I’m not seeing much in the way of pCloud corruption. Internet search has some. There’s a chance that rclone logging (which I am not familiar with) could tell what rclone thinks it uploaded. That would help rule out the question of whether something went wrong with the Duplicati-rclone operation.
Well, Web interface (see first screenshot) says last successful backup …, despite the “warnings”
Thanks for your hint, “affected” listed some 120 files . Tried to restore one folder listed by “affected” failed because of the damaged file duplicati-b536ad8f6b21f498081f1d6835fcd586d.dblock.zip.aes - no surprise.
O.k. to find out if this is related to the original problem with WebDAV interface in some way I started a restore of that folder from the WebDAV-backup by commandline:
d:\Program Files\Duplicati 2>Duplicati.CommandLine.exe restore "webdavs://ewebdav.pcloud.com/Backups/Duplicati/Privatdaten?auth-username=******&auth-password=*******" "e:\Privatdaten\Sebastian\Schule\Klasse 7\Geo\*" --restore-path="h:\Duplicati-backup_local\restore\"
Restore started at 03.10.2022 18:54:34
Verschlüsselungspassphrase eingeben: C1.........4
Listing remote folder ...
Downloading file (400,78 KB) ...
Downloading file (11,11 MB) ...
Downloading file (11,09 MB) ...
Downloading file (3,62 KB) ...
Downloading file (42,83 KB) ...
Remote file referenced as duplicati-bfca3601c65d7412486eab2b8620a9812.dblock.zip.aes by duplicati-i6324d97e8d7347b8a1cc3ea90d4c465c.dindex.zip.aes, but not found in list, registering a missing remote file
Downloading file (49,40 KB) ...
Downloading file (46,34 KB) ...
Downloading file (52,62 KB) ...
Downloading file (35,54 KB) ...
Downloading file (44,37 KB) ...
Downloading file (38,26 KB) ...
Found 1 missing volumes; attempting to replace blocks from existing volumes
Checking remote backup ...
Checking existing target files ...
Scanning local files for needed data ...
20 files need to be restored (4,34 MB)
Failed to patch file: "h:\Duplicati-backup_local\restore"\330px-Russia_on_the_globe_(+claims_hatched)_(Russia_centered).svg.png" with local data, message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
=> Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\Dok1.docx" with local data, message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\Gaspipelines.jpg" with local data, message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\LIPortal » Russland » Wirtschaft & Entwicklung - Das Länderinformationsportal.pdf" with local data, message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\PPT_Präsentation Russland.pptx" with local data, message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\Rohstoffe+in+Russland.jpg" with local data, message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\Russland (UDSSR) - Referat, Hausaufgabe, Hausarbeit.pdf" with local data, message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\Russland - Anteile der Wirtschaftssektoren am Bruttoinlandsprodukt (BIP) bis 2016 _ Statistik.pdf" with local data, message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\Russland 2.jpg" with local data, message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\Russland Bodenschätze.pdf" with local data, message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\Russland Flagge.png" with local data, message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\Russland Karte Wirtschaft.jpg" with local data, message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\Russland Karte_1.jpg" with local data, message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\Russland Karte_Klima.jpg" with local data, message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\Russland Wappen.png" with local data, message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\Thumbs.db" with local data, message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\Vorkommen_1.jpg" with local data, message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\export.jpg" with local data, message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\images.jpg" with local data, message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\sibirien-vorkommen-01-400.jpg" with local data, message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Downloading file (49,95 MB) ...
Downloading file (49,93 MB) ...
Failed to patch file: "h:\Duplicati-backup_local\restore"\Dok1.docx", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\LIPortal » Russland » Wirtschaft & Entwicklung - Das Länderinformationsportal.pdf", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\PPT_Präsentation Russland.pptx", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\Russland - Anteile der Wirtschaftssektoren am Bruttoinlandsprodukt (BIP) bis 2016 _ Statistik.pdf", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\Russland Bodenschätze.pdf", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\Russland Karte Wirtschaft.jpg", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\Russland Karte_1.jpg", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\Vorkommen_1.jpg", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Downloading file (49,97 MB) ...
Failed to patch file: "h:\Duplicati-backup_local\restore"\Thumbs.db", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\export.jpg", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\images.jpg", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\Gaspipelines.jpg", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\Rohstoffe+in+Russland.jpg", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\Russland (UDSSR) - Referat, Hausaufgabe, Hausarbeit.pdf", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\Russland 2.jpg", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\Russland Karte_Klima.jpg", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\sibirien-vorkommen-01-400.jpg", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\330px-Russia_on_the_globe_(+claims_hatched)_(Russia_centered).svg.png", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\Russland Flagge.png", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to patch file: "h:\Duplicati-backup_local\restore"\Russland Wappen.png", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to apply metadata to file: "h:\Duplicati-backup_local\restore"\Gaspipelines.jpg", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to apply metadata to file: "h:\Duplicati-backup_local\restore"\LIPortal » Russland » Wirtschaft & Entwicklung - Das Länderinformationsportal.pdf", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to apply metadata to file: "h:\Duplicati-backup_local\restore"\Russland Wappen.png", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to apply metadata to file: "h:\Duplicati-backup_local\restore"\Thumbs.db", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to apply metadata to file: "h:\Duplicati-backup_local\restore"\Dok1.docx", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to apply metadata to file: "h:\Duplicati-backup_local\restore"\Rohstoffe+in+Russland.jpg", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to apply metadata to file: "h:\Duplicati-backup_local\restore"\Russland (UDSSR) - Referat, Hausaufgabe, Hausarbeit.pdf", message: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
..... repeats ....
Failed to restore file: "h:\Duplicati-backup_local\restore"\Russland - Anteile der Wirtschaftssektoren am Bruttoinlandsprodukt (BIP) bis 2016 _ Statistik.pdf". Error message was: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to restore file: "h:\Duplicati-backup_local\restore"\Russland 2.jpg". Error message was: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to restore file: "h:\Duplicati-backup_local\restore"\Russland Bodenschätze.pdf". Error message was: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to restore file: "h:\Duplicati-backup_local\restore"\Russland Flagge.png". Error message was: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to restore file: "h:\Duplicati-backup_local\restore"\Russland Karte Wirtschaft.jpg". Error message was: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to restore file: "h:\Duplicati-backup_local\restore"\Russland Karte_1.jpg". Error message was: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to restore file: "h:\Duplicati-backup_local\restore"\Russland Karte_Klima.jpg". Error message was: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to restore file: "h:\Duplicati-backup_local\restore"\Russland Wappen.png". Error message was: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to restore file: "h:\Duplicati-backup_local\restore"\Thumbs.db". Error message was: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to restore file: "h:\Duplicati-backup_local\restore"\Vorkommen_1.jpg". Error message was: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to restore file: "h:\Duplicati-backup_local\restore"\export.jpg". Error message was: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to restore file: "h:\Duplicati-backup_local\restore"\images.jpg". Error message was: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Failed to restore file: "h:\Duplicati-backup_local\restore"\sibirien-vorkommen-01-400.jpg". Error message was: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch.
Restored 0 (0 Bytes) files to h:\Duplicati-backup_local\restore"
Duration of restore: 00:18:46
Again the file duplicati-bfca3601c65d7412486eab2b8620a9812.dblock.zip.aes is involved.
And even Restored 0 (0 Bytes) files to h:\Duplicati-backup_local\restore" are reported the files were downloaded and stored in the new restore-path directory.
Those files belong to my son, files download are not corrupted. The only thing special about them is lenght in combination with blanks for two files. This applies to more files in his directories - he is not aware of problems that might cause.
On the over hand these files are older than the first Duplucati-backup.
h:\Duplicati-backup_local\restore\330px-Russia_on_the_globe_(+claims_hatched)_(Russia_centered).svg.png
h:\Duplicati-backup_local\restore\Dok1.docx
h:\Duplicati-backup_local\restore\LIPortal » Russland » Wirtschaft & Entwicklung - Das Länderinformationsportal.pdf
h:\Duplicati-backup_local\restore\PPT_Präsentation Russland.pptx
h:\Duplicati-backup_local\restore\Russland - Anteile der Wirtschaftssektoren am Bruttoinlandsprodukt (BIP) bis 2016 _ Statistik.pdf
h:\Duplicati-backup_local\restore\Russland (UDSSR) - Referat, Hausaufgabe, Hausarbeit.pdf
h:\Duplicati-backup_local\restore\Russland 2.jpg
h:\Duplicati-backup_local\restore\Russland Bodenschätze.pdf
h:\Duplicati-backup_local\restore\Russland Flagge.png
h:\Duplicati-backup_local\restore\Russland Karte Wirtschaft.jpg
h:\Duplicati-backup_local\restore\Russland Karte_1.jpg
h:\Duplicati-backup_local\restore\Russland Karte_Klima.jpg
h:\Duplicati-backup_local\restore\Russland Wappen.png
h:\Duplicati-backup_local\restore\Thumbs.db
Maybe it wouldn’t do that if the should-this-warning-be-an-error question got solved. Maybe someday.
Why is that noteworthy?
A more accurate restore test would give option no-local-blocks, otherwise this may cover effect of dblock loss until source file changes, disaster clobbers it, etc. at which time its needed blocks are now nowhere.
--no-local-blocks = false
No luck with this option - old command loine also did not work anymore, and finally won’t start at all processs is in use …
I have no glue whats wrong with my duplicati
find complete console-log here
I am at a point I don’t feel like spending more time on this and should think about some other backup strategie. I lost my confidence this is a reliable solution if I depend on it.
I don’t know what you mean. I found one run where you set --no-local-blocks = false, but that’s its default.
It’s probably confusing unless one knows how the manual is written. To disable local blocks, set it true or (from command line) just say it, and its presence implies true. But its effect seems to be misunderstood.
I don’t see such a message in the console log, however if you ever used Control-C, you might have left a background process running. Duplicati uses a child process that runs the latest version autoupdater took.
Interrupting processes is generally a risky idea, but you can either use Task Manager to kill any leftover, or
set AUTOUPDATER_Duplicati_SKIP_UPDATE=true
in your Command Prompt to omit the updated child and just run the Program Files version without a child.
The common factor is pCloud not working with Duplicati WebDAV, and not working with Duplicati + rclone.
The reason that restore is doing what looks like it was doing before is because nothing has been changed.
I can’t view your restore area, but I thought you said it was somehow getting files back despite bad dblock.
The more accurate restore test was to cause a failure to get files back, by preventing a local block search.
If you wanted to sacrifice the broken files, you would follow the purging files procedure, but I doubt you did. After the procedure (which you don’t want to do a lot because it sacrifices files), what’s left should restore.
That’s a demonstration of the workaround. You need to find a storage provider that reliably stores the files. Infrequent glitches might be tolerable, but having to recover from a broken situation often will get annoying.
This combination is seemingly not reliable. Have you considered switching to some other storage provider?
If you wish to try pCloud with another backup program that supports it, it’d be interesting to see if it works…
What pieces here were GUI, and what were command line? Trying to intermix them must be done carefully otherwise you can inadvertently try to recreate the database by reading files such as dindex which I see got
A restore that had a database wouldn’t be reading dindex files, so dindex wouldn’t name its missing dblock.
Every dblock has a dindex, so if a dblock goes bad and is deleted, there will probably be a dindex to delete.
If you’re trying to do a CLI restore for a GUI backup, you can start from an edited Export As Command-line.
More findings, but no miracles – a reliable storage Destination is a requirement, otherwise issues arise.
Answer to GUI and CLI mixing seems to be “yes”, which also leads to the need to type in the password.
Accidents such as extra spaces around = sign (which seems to cause ignoring option) also happened.
Some good news is that --no-local-blocks = false might have been read as --no-local-blocks.
Restoring files from a backup with GUI is easy and nicer, and GUI Options screen is also easier to read.
CLI output is a bit better by default, but still needs to be turned up when a problem situation needs debug.
console-log-level can do that, and now I notice that in its effort to neatly give default, it invites space error.
--console-log-level = Warning
Console information level
Adding --console-log-level=information would probably have shown a database creation such as
The operation Restore has started
No local database, building a temporary database
Backend event: List - Started: ()
Backend event: List - Completed: (3 bytes)
Rebuild database started, downloading 1 filelists
Backend event: Get - Started: duplicati-20221004T115859Z.dlist.zip.aes (1.20 KB)
Downloading file (1.20 KB) ...
Backend event: Get - Completed: duplicati-20221004T115859Z.dlist.zip.aes (1.20 KB)
Filelists restored, downloading 1 index files
Using verbose level is even more informative, for example (and it’s also better during file restore portion):
Processing filelist volume 1 of 1
Backend event: Get - Started: duplicati-i9f4461e10f6246ac94ef9fbcc31068cb.dindex.zip.aes (1.12 KB)
Downloading file (1.12 KB) ...
Backend event: Get - Completed: duplicati-i9f4461e10f6246ac94ef9fbcc31068cb.dindex.zip.aes (1.12 KB)
Processing indexlist volume 1 of 1
Target file is patched with some local data:
Actually it was probably patched entirely with local data, because local data (for me) exists, so just use it.
I was hoping I could kill a dblock (as pCloud did) and get my files back, but database recreate didn’t work.
I cited earlier how pCloud broke recently for someone, around when yours did, using a Duplicacy backup.
This (despite name similarity) is a completely different program. Go to forum.duplicacy.com to search (using box at top) for pcloud to see the other feedback. You can do the same thing on the Duplicati forum.
There’s at least one user on the Duplicacy forum who strongly advises using storage meant for uses that backup programs put them through, although they might be good enough for other (maybe easier) usage.
When looking at pCloud reliability (or corruption, or whatever), please keep this in mind. Or talk with them.
Options to make Duplicati work with pCloud seem exhausted, and I’m not sure Duplicacy is doing better…
Rclone is still a bit mysterious until when/if you can get more information on who seemed to drop the data.
Ok. was too tired last night, my bad.
Ran this command with success:
Duplicati.CommandLine.exe restore "webdavs://ewebdav.pcloud.com/Backups/Duplicati/Privatdaten?auth-username=****%40web.de&auth-password=*******" "e:\Privatdaten\Sebastian\Schule\Klasse 7\Geo\*" --restore-path="h:\Duplicati-backup_local\restore" --no-local-blocks = true
With this result:
21 files need to be restored (4,34 MB)
Downloading file (49,99 MB) ...
Creating missing folder h:\Duplicati-backup_local\restore\thomas\ArduinoProjects\libraries\ArduinoJson\extras\fuzzing\msgpack_seed_corpus for file h:\Duplicati-backup_local\restore\thomas\ArduinoProjects\libraries\ArduinoJson\extras\fuzzing\msgpack_seed_corpus\true
18 files need to be restored (2,41 MB)
11 files need to be restored (881,10 KB)
0 files need to be restored (0 Bytes)
Verifying restored files ...
Restored 21 (4,34 MB) files to h:\Duplicati-backup_local\restore
Duration of restore: 00:18:42
The good news to my understanding the 20 files located in the specified folder were restored to to destination. By using the --no-local-blocks = true extension they should by downloaded from remote.
But - there is one more file restored from annother directory. - well actually this is no restored file. The folder existics and contains files but this one seems Duplicati generated. Weird.
Same result after renaming the folder in the local source directory. And again the extra file.
Please stop adding extra spaces. It’s incorrect, and results might vary. Please read my previous post.
There are a huge number of unanswered questions and ignored suggestions given over posts history.
Is this test just to see if something that should have no affect (still an old backup, right?) has no affect?
If you’re troubleshooting, previous suggestion of adding logging will offer some additional clues for this.
If you can use GUI (another old question), browse Restore for then to see if the file is seen in that view.
The FIND command exists for CLI, but (like most things), it’s more trouble to use compared to the GUI.
There’s also the open question of why you’re maybe still recreating the database. Is that an accident?
Unless testing disaster recovery (which is good), one would usually restore using database. It’s faster.
If all else fails, there’s the dlist file itself, which has a UTC date in its name, and you can open to see if filelist.json has the file. Decrypt the dlist with AES Crypt or Duplicati’s CLI SharpAESCrypt.exe.
How the backup process works has more, but you could just search for surprise file name in notepad.
If you actually ran purge-broken-files (did you?) then dlist file may not be the original, but a purged one.
Checking the timestamp on dlist file should also give a clue on whether dlist file is original or modified.
Note that all this extensive effort is wasted unless pCloud gets reliable, and it’s far from clear that it will.
If you’re determined to use it, and have local drive space, you might be able to backup to a local folder.
pCloud Drive appears able to sync folders, and maybe rclone can too (despite bad initial testing result).
This is more fragile and more prone to something like ransomware on the computer killing all backups.
