Release: 2.4.0.103 (Canary) 2026-10-02
2.4.0.103_canary_2026-10-02
Reduced reporting mode
A new reduced reporting mode limits everything that is sent outside the machine to log message ids, counters, dates and stack traces. No message text, error message or file name is transmitted, and the bug report feature is disabled. The mode is enabled with --reduced-reporting, overrides the regular path redaction, also applies to the data handed to run-scripts, and cannot be undone by a backup configuration. Local log data is still available in full.
Recreate with defective filelists
A failed transfer can leave a partially written filelist on the remote storage. The backup would then fail because of the unknown file, and recreating the database failed because the partial file could not be read. The database recreate now probes the filelists and continues without the defective ones. The next backup will then ask for a repair, which removes the offending files.
Restore fixes
A number of problems in the restore flow were fixed, thanks @JamBalaya56562:
  • A file that cannot be created or written no longer stops the restore of the files after it.
  • A restore that finishes with errors is now reported as failed in the UI and in the HTTP status report, instead of showing as successful.
  • Skipped files, including files where a copy already exists, no longer cause BlockCountError and VolumeCountError messages.
  • A missing destination folder is reported before the restore starts instead of after the full retry delay.
  • More cases where a failing restore stage could leave the restore waiting forever are now released.
  • The restore tree no longer hides a source whose path extends the name of another source file, and a backup with multiple drives no longer takes 30 seconds per drive to list.
Stopping a backup no longer hangs (or at least less often)
Using “Stop now” could leave the backup waiting forever if a source file read was stuck, such as on a network share that stopped answering, or if a block processor was stopped while holding a block. Both cases now return as cancelled, thanks @JamBalaya56562.
Windows sleep, resume and port fixes
Three Windows related problems were fixed, thanks @JamBalaya56562:
  • With --allow-sleep disabled, Windows was kept awake after the operation had finished. The sleep prevention is now withdrawn when the operation ends.
  • If the machine was suspended before the pause was fully handled, the server could stay paused after waking up.
  • The server now tries the next port when Windows refuses the port, such as when port 8200 is in a range reserved for Hyper-V, WSL or Docker.
MSI installer remembers the install location
A custom install location chosen in the MSI installer is now remembered for later upgrades. Older packages did not record the location, so this takes effect from the next upgrade. The location can also be set with msiexec /i package.msi INSTALLLOCATION=C:\OtherLocation, which works for silent installs. The browse button for picking the path was also fixed.
Queued commands keep their version
A command sent from the command line page in the UI waits in the task queue. If a backup ran before the command, the --version numbers had shifted, so a delete could remove the wrong version. The versions are now resolved when the command is sent, and the command is not run if a named version no longer exists, thanks @JamBalaya56562.
Synchronization improvements
Sync jobs now keep their own metadata and only update it when the operation succeeds, instead of writing the last backup values even on failures. The remote operation log is no longer kept in memory during a sync, and uploading a zero-byte file to Google Cloud Storage or Google Drive no longer fails with a 400 error.
Detailed list of changes
  • Fixed generated remote filenames using the casing supplied by the user for the compression and encryption module
  • Added support for remembering the install location in the MSI installer and pinned the order of the install actions
  • Fixed an aborted backup waiting forever for a stuck source file read, thanks @JamBalaya56562
  • Fixed an aborted backup waiting forever when a block processor stopped while holding a block, thanks @JamBalaya56562
  • Fixed the largest-prefix listing taking 30 seconds per drive and returning an extra empty root for multi-drive backups, thanks @JamBalaya56562
  • Fixed an ObjectDisposedException logged during server shutdown, thanks @JamBalaya56562
  • Fixed skipped files in a restore being reported as BlockCountError and VolumeCountError, thanks @JamBalaya56562
  • Fixed a missing destination folder only being reported after all retries when restoring, thanks @JamBalaya56562
  • Fixed the repeated and unclear warning when the Windows modules cannot be loaded, thanks @JamBalaya56562
  • Fixed the database connection staying open when the setup of a backup or delete database fails, thanks @JamBalaya56562
  • Fixed the server stopping instead of trying the next port when the system refuses the port, thanks @JamBalaya56562
  • Fixed the server staying paused after a sleep if the suspend was still being handled, thanks @JamBalaya56562
  • Fixed the path browse button in the MSI installer
  • Fixed an aborted repair setting aside a healthy local database and recreating it, thanks @JamBalaya56562
  • Fixed the HTTP status report showing an operation that finished with errors as successful, and redacted paths in the reported error, thanks @JamBalaya56562
  • Fixed Windows being kept awake after an operation has ended, thanks @JamBalaya56562
  • Fixed the help text for search to say that all versions are searched when none is given, thanks @JamBalaya56562
  • Fixed the live log skipping entries when more than a page arrived between two polls, thanks @JamBalaya56562
  • Fixed the old UI grouping restore versions under the wrong month, thanks @JamBalaya56562
  • Added handling of defective filelists when recreating the database
  • Changed the remote filename parsing so the encryption module name cannot contain a .
  • Fixed the old UI not showing the saved local folder when editing a backup, thanks @JamBalaya56562
  • Fixed the old UI not being able to select a restore root before it was expanded, thanks @JamBalaya56562
  • Fixed the old UI replacing the saved S3 client with aws when opening a destination, thanks @JamBalaya56562
  • Fixed the old UI not saving a custom S3 storage class, thanks @JamBalaya56562
  • Added the stored configuration type (backup or sync) to the API
  • Reduced memory usage for sync operations by not collecting remote operation log data
  • Fixed uploading zero-byte files to Google Cloud Storage and Google Drive
  • Changed sync operations to use their own metadata and only update it on success
  • Fixed a task that finished with errors being reported as successful, thanks @JamBalaya56562
  • Fixed a restore stopping when a single file fails to restore, thanks @JamBalaya56562
  • Fixed a queued command acting on the wrong version when a backup ran before it, thanks @JamBalaya56562
  • Fixed more cases where a failing restore stage could leave the restore waiting forever, thanks @JamBalaya56562
  • Fixed a source being dropped from the root listing when its path extends the name of another source file, thanks @JamBalaya56562
  • Added the reduced reporting mode and the --reduced-reporting option
  • Changed the SMB write error detection and logging to show the actual failure
  • Added RelAix to the list of S3 providers, thanks @mygrexit
  • Fixed empty and whitespace-only arguments being lost when wrapping a command line, thanks @JamBalaya56562
  • Fixed the database connection staying open when a local database fails to open, thanks @JamBalaya56562
  • Updated translations from Transifex, thanks to all Translators!
Updates to ngclient
  • Fixed the context menu being hidden for console managed backups
  • Added support for showing sync jobs when restoring configurations from remote
  • Improved the display of sync operations
  • Added RelAix to the known public hosts
  • Added support for reduced reporting
  • Fixed errors in a completed restore database repair not being handled, thanks @JamBalaya56562
  • Fixed the schedule date picker not preserving the local date, thanks @JamBalaya56562
  • Fixed stopped WebSockets and long polls reconnecting, thanks @JamBalaya56562
  • Updated localization
ngclient fix for schedule coming up a day late seems fixed, at least during a configuration import.
The reconnecting fix PRs didn’t claim to fix all issues, so I still get prior reported countdown loop.
2026-10-03 08:46:12 -04 - [Information-Duplicati.Library.Main.Controller-CompletedOperation]: The operation Backup has completed
2026-10-03 11:50:24 -04 - [Verbose-Duplicati.WebserverCore.Notifications.WebsocketAuthenticator-WebsocketInvalidToken]: WebSocket connection with invalid token
Microsoft.IdentityModel.Tokens.SecurityTokenExpiredException: IDX10223: Lifetime validation failed. The token is expired. ValidTo (UTC): '10/3/2026 2:36:22 AM', Current time (UTC): '10/3/2026 3:50:24 PM'.
   at Microsoft.IdentityModel.Tokens.ValidatorUtilities.ValidateLifetime(Nullable`1 notBefore, Nullable`1 expires, SecurityToken securityToken, TokenValidationParameters validationParameters)
   at System.IdentityModel.Tokens.Jwt.JwtSecurityTokenHandler.ValidateTokenPayload(JwtSecurityToken jwtToken, TokenValidationParameters validationParameters, BaseConfiguration configuration)
   at System.IdentityModel.Tokens.Jwt.JwtSecurityTokenHandler.ValidateJWS(String token, TokenValidationParameters validationParameters, BaseConfiguration currentConfiguration, SecurityToken& signatureValidatedToken, ExceptionDispatchInfo& exceptionThrown)
   at System.IdentityModel.Tokens.Jwt.JwtSecurityTokenHandler.ValidateToken(String token, JwtSecurityToken outerToken, TokenValidationParameters validationParameters, SecurityToken& signatureValidatedToken)
   at Duplicati.WebserverCore.Middlewares.JWTTokenProvider.ParseAndValidateToken(String token, TokenType tokenType)
   at Duplicati.WebserverCore.Middlewares.JWTTokenProvider.ReadAccessToken(String token)
   at Duplicati.WebserverCore.Notifications.WebsocketAuthenticator.HandleClientMessageAsync(WebSocket socket, String messagestr)
2026-10-03 11:50:25 -04 - [Verbose-Duplicati.WebserverCore.Notifications.WebsocketAuthenticator-WebsocketInvalidToken]: WebSocket connection with invalid token
Microsoft.IdentityModel.Tokens.SecurityTokenExpiredException: IDX10223: Lifetime validation failed. The token is expired. ValidTo (UTC): '10/3/2026 2:36:22 AM', Current time (UTC): '10/3/2026 3:50:25 PM'.
2026-10-03 11:50:25 -04 - [Verbose-Duplicati.WebserverCore.Notifications.WebsocketAuthenticator-WebsocketAuthenticated]: WebSocket connection authenticated with token
2026-10-03 11:53:27 -04 - [Verbose-Duplicati.WebserverCore.Notifications.WebsocketAuthenticator-WebsocketAuthenticated]: WebSocket connection authenticated with token
2026-10-03 11:53:40 -04 - [Verbose-Duplicati.Library.SQLiteHelper.SQLiteLoader-CustomSQLiteOption]: Setting custom SQLite option 'synchronous=NORMAL'.
2026-10-03 11:53:40 -04 - [Verbose-Duplicati.Library.SQLiteHelper.SQLiteLoader-CustomSQLiteOption]: Setting custom SQLite option 'temp_store=MEMORY'.
2026-10-03 11:53:40 -04 - [Verbose-Duplicati.Library.SQLiteHelper.SQLiteLoader-CustomSQLiteOption]: Setting custom SQLite option 'journal_mode=WAL'.
2026-10-03 11:53:40 -04 - [Verbose-Duplicati.Library.SQLiteHelper.SQLiteLoader-CustomSQLiteOption]: Setting custom SQLite option 'cache_size=-65536'.
2026-10-03 11:53:40 -04 - [Verbose-Duplicati.Library.SQLiteHelper.SQLiteLoader-CustomSQLiteOption]: Setting custom SQLite option 'mmap_size=67108864'.
2026-10-03 11:53:40 -04 - [Verbose-Duplicati.Library.SQLiteHelper.SQLiteLoader-CustomSQLiteOption]: Setting custom SQLite option 'threads=8'.
2026-10-03 11:53:40 -04 - [Verbose-Duplicati.Library.SQLiteHelper.SQLiteLoader-CustomSQLiteOption]: Setting custom SQLite option 'shared_cache=true'.
2026-10-03 12:24:21 -04 - [Verbose-Duplicati.WebserverCore.Notifications.WebsocketAuthenticator-WebsocketInvalidToken]: WebSocket connection with invalid token
Microsoft.IdentityModel.Tokens.SecurityTokenExpiredException: IDX10223: Lifetime validation failed. The token is expired. ValidTo (UTC): '10/3/2026 4:05:25 PM', Current time (UTC): '10/3/2026 4:24:21 PM'.
2026-10-03 12:24:21 -04 - [Warning-Duplicati.WebserverCore.Services.LoginProvider-TokenFamilyReuse]: Invalid refresh token counter: 309 != 308
2026-10-03 12:24:21 -04 - [Error-Duplicati.WebserverCore.Endpoints.V1.Auth-RefreshTokenError]: Failed to refresh token
Duplicati.WebserverCore.Exceptions.UnauthorizedException: Token family re-use detected
   at Duplicati.WebserverCore.Services.LoginProvider.PerformLoginWithRefreshTokenAsync(String refreshTokenString, String nonce, CancellationToken ct)
   at Duplicati.WebserverCore.Endpoints.V1.Auth.<>c.<<Map>b__3_0>d.MoveNext()
The general issue (still opened) might be this:
The 12:24 action was me clicking Edge tab, which woke it and got a “Reconnecting…” loop.
This new release was installed yesterday. PC was asleep overnight, then woke, did backup.
Normal backups on Windows with 2.4.0.0 stable regularly take 8+ hours. One recent run took 8h26m to upload just 271 MB.
On 6 October I tested 2.4.0.103 canary using a copied database and backup --dry-run. The database is approximately 28 GB with 432 versions. I retained CUSTOMSQLITEOPTIONS_DUPLICATI=temp_store=FILE and redirected Windows and SQLite temporary storage to E:, with ample free space.
Initial database checking took approximately 1h27m before the first remote listing. Source scanning subsequently finished, but a later consistency check reported this query still running after 1,182.9 seconds:
SELECT COUNT(*)
FROM "FilesetEntry"
WHERE "FileID" NOT IN (
    SELECT "ID" FROM "FileLookup"
I stopped the test after approximately 9 hours 45 minutes, as it was still taking longer than I could reasonably leave it running. Unfortunately, I haven’t been able to confirm a performance improvement with this test.
Given the recent consistency-check and database performance improvements, what diagnostics or query plans would help identify the remaining bottleneck? I have the copied database and logs available.
This part explains the issue. What happens is that the UI somehow tries to get a new access token two times in parallel, or cancels one request. The issuing code issues the first token, increments the counter, but the browser never sees the response. When the second request hits, it has the old counter so it is deemed stale and all tokens related to that login are cancelled. The UI is then confused because it has an access token, but cannot get a new one.
Yes, that issue has been neglected a bit.
The ngax UI did a real timer-then-check. For ngclient it just shows the counter, but it is not tied to the actual reconnect attempts because we can get a reconnect in various ways.
Thanks for reporting this and spending the time to lock down some of the numbers.
Ideally, if you could run the backup (dry-run is fine) with 2.4.0.0 and --log-file-log-level=Profiling + --log-file=<path>.txt, then run 2.4.0.103 with the same setup so we have traces from both versions.
We can then compare these two files to see where the time increases.
If that is not an option, any logs you have are much appreciated, but for this the log level needs to be Profiling for it to capture the timing on the individual queries.
I found 4 places where that query is in the codebase, and the most-recent edit was 10 months ago, so maybe it is an artifact of another problem? Could also be that I did not find the right call spot, but the call itself is just trying to find files that are orphaned so it should not change performance across versions.
That is also a significant time spent just checking the internal integrity, if you can share the logs with profiling turned on, maybe we can optimize this.
Thanks Kenneth. The normal backup on 2.4.0.0 stable has now completed with profiling enabled. It took 22h34m and finished with 20 warnings and no errors.
The log is about 83 GB uncompressed, or 5.16 GB compressed, and is now uploaded to a restricted Google Drive folder. I’ll need to run the matching 2.4.0.103 canary comparison next week, using the same sources, filters and backup settings.
What’s the best way to send you the logs privately? I can grant restricted Drive access if you send me the appropriate address by PM, or use another method if you prefer. The log includes local paths and filenames, so I’ll keep its link off the public forum.
