Release: 2.2.0.1 (Stable) 2025-11-09
2.2.0.1_stable_2025-11-09
This is a minor patch release to fix some issues uncovered with the latest stable release.
Changes from 2.2.0.0 to 2.2.0.1
  • Report remote filenames on failures
  • Fixed issues with timeouts on MSGraph-based backends (OneDrive and others)
  • Fixed base-href placement for better proxy support, thanks @peloyeje
  • Fixed an issue with not parsing enums with multiple values (aka flags)
  • Clear warnings for configuration issues, if the issues are resolved
  • Better detection of valid S3 hostnames
  • Showing assembly version in version number
  • Marked --send-mail-password as a password setting
  • Improved WebDAV parsing logic for more servers
  • Made pCloud options visible
  • Added option to disable remote control while being connected to console
  • Fixed a retry issue with sync-tool
Changes in user interface from 2.2.0.0 to 2.2.0.1
  • Added support for picking power-mode provider
  • Fixed issues with filters
  • Fixed styling of some buttons
  • Fixed issue with “Test connection” not offering to fix know issues
  • Made the export tooltip optional
  • Fixed an issue with parsing the exclude attributes and file size
  • Improved some hint texts
  • Fixed support for showing durations that include days
  • The button to resume from paused state is now called “Resume”
  • Hide usage reporter options if this is disabled via environment variables
  • Show currently installed version on the settings page
  • Set user language on first load to avoid default English page
  • Added check when doing cross-OS restores
  • Prevent clicking on steps that cannot be clicked
  • Added password visibility toggle on main password
  • Added some improved views for emails and files
  • Fixed an issue with allowing uppercase and non-ASCII names in the folder path
  • Commandline UI now loads global settings
  • Very long error messages now introduce scrolling inside the popup
  • Show configured backups for restore first, then direct restore options
  • Added scrolling to source paths, which allows more than 25 sources to be added
  • Filejump is hidden as it is undergoing a migration
  • Sizes are now allowing bytes for precision
  • Incorrect volume size warning fixed
  • Added new console connect flow
Summary of changes from 2.1 to 2.2
  • New user interface
  • New backends: pCloud, Filen and SMB
  • New faster restore flow, use --restore-legacy=true to fall back
  • Installer signing keys are from Duplicat Inc
  • Remote sources: S3, IDrive, SSH, and CIFS
  • AWS and Azure blob storage cold storage support
  • Database downgrade tool is included
  • Local database updated to version 17
  • Settings database updated to version 9
  • Improved throttle calculations
  • Removed Sia backend and marked Mega as unsupported
  • All backends now have individual timeout settings
  • Updated location default location for storage folder
  • Securing the permissions on the storage folder
  • New file and folder enumeration logic
  • Timeout logic on all backend operations
  • Improved database validation and repair logic
  • ServerUtil can output JSON for script integration
  • Improved support for having Duplicati behind a proxy
  • Updated throttle logic, all streams share the throttle
  • Improved repair logic
  • VSS is automatically on if running on Windows with sufficient privileges
  • Improved backend test function
  • Ability to suppress warnings
  • Support for remotely provided reporting url and remotely managed backup configs
  • Added support for Google IAM on Google Drive
unfortunately, this release did not resolve the issue with failed SSL connections. According to that thread, there seem to be at least two other users affected by the problem.
BTW, I can connect to the WebDAV server without problems when using the native openssl s_client command.
Kind regards
Ingolf
I have finally upgraded from 2.1.0.5 to 2.2.0.1, and suddenly, while the service is running, it actively removes my user’s rights to access the duplicati database folder, even when I grant them back to me.
Which means, Dropbox running under my account, cannot access it and back them up.
I rely on having those databases actively uploaded to Dropbox as they change, to always have the recent version there, to be able to restore my computer in case of a crash before the end of the universe.
How can I disable that feature? I accept the risk that if Dropbox goes rogue, they can access the database files.
Probably like this.
Thanks, I will give it a go :slight_smile: Created the file and disabled task that reseted the permissions after duplicati restart.
