Backups fail with "The SSL connection could not be established"
since I upgraded to 2.2.0.0 (on Ubuntu), all of my backups fail with “The SSL connection could not be established”. I use WebDAV to sd2dav.1und1.de which shows “Grade A+” in the SSL Report. Before the upgrade, my previous version (2.1.0.5_stable, I believe) worked without problems.
This is the log:
System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception.
 ---> System.Security.Authentication.AuthenticationException: The remote certificate was rejected by the provided RemoteCertificateValidationCallback.
   at System.Net.Security.SslStream.SendAuthResetSignal(ReadOnlySpan`1 alert, ExceptionDispatchInfo exception)
   at System.Net.Security.SslStream.CompleteHandshake(SslAuthenticationOptions sslAuthenticationOptions)
   at System.Net.Security.SslStream.ForceAuthenticationAsync[TIOAdapter](Boolean receiveFirst, Byte[] reAuthenticationData, CancellationToken cancellationToken)
   at System.Net.Http.ConnectHelper.EstablishSslConnectionAsync(SslClientAuthenticationOptions sslOptions, HttpRequestMessage request, Boolean async, Stream stream, CancellationToken cancellationToken)
   at System.Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
   at System.Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
   at System.Net.Http.HttpConnectionPool.AddHttp11ConnectionAsync(QueueItem queueItem)
   at System.Threading.Tasks.TaskCompletionSourceWithCancellation`1.WaitWithCancellationAsync(CancellationToken cancellationToken)
   at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken)
   at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
   at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
   at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken)
   at Duplicati.Library.Utility.Utility.WithTimeout[T](TimeSpan timeout, CancellationToken token, Func`2 func)
   at Duplicati.Library.Backend.WEBDAV.ListAsync(CancellationToken cancelToken)+MoveNext()
   at Duplicati.Library.Backend.WEBDAV.ListAsync(CancellationToken cancelToken)+System.Threading.Tasks.Sources.IValueTaskSource<System.Boolean>.GetResult()
   at System.Linq.AsyncEnumerable.<ToListAsync>g__Core|424_0[TSource](IAsyncEnumerable`1 source, CancellationToken cancellationToken) in /_/Ix.NET/Source/System.Linq.Async/System/Linq/Operators/ToList.cs:line 36
   at Duplicati.Library.Main.Backend.BackendManager.ListOperation.ExecuteAsync(IBackend backend, CancellationToken cancelToken)
   at Duplicati.Library.Main.Backend.BackendManager.ListAsync(CancellationToken cancelToken)
   at Duplicati.Library.Main.Operation.FilelistProcessor.RemoteListAnalysis(IBackendManager backendManager, Options options, LocalDatabase database, IDbTransaction transaction, IBackendWriter log, IEnumerable`1 protectedFiles, IEnumerable`1 strictExcemptFiles, VerifyMode verifyMode)
   at Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList(IBackendManager backend, Options options, LocalDatabase database, IDbTransaction transaction, IBackendWriter log, IEnumerable`1 protectedFiles, IEnumerable`1 strictExcemptFiles, Boolean logErrors, VerifyMode verifyMode)
   at Duplicati.Library.Main.Operation.BackupHandler.PreBackupVerify(Options options, BackupResults result, IBackendManager backendManager)
   at Duplicati.WebserverCore.Services.QueueRunnerService.RunTask(IQueuedTask task)
I have been trying several times yesterday and today – always without success.
Any hints welcome. Feel free to ask for more details.
Kind regards
Ingolf
Hi, I’m also having the same problem. In version duplicati-2.1.0.5_stable_2025-03-04 the WebDAV authentication feature is working normally, but after updating, my backup routines stopped. Since I couldn’t solve the problem, I downgraded the installed version.
I have a similar issue (SSL error, but seems to be for a different reason - see below)
This error started only today, though (and I’ve upgraded to 2.2.0 a week ago). I have B2-Backblaze and Google Cloud backups - this SSL error is happening only with B2 (even at the “Test Connection” stage).
System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception. —> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure: RemoteCertificateNameMismatch, RemoteCertificateChainErrors at System.Net.Security.SslStream.SendAuthResetSignal(ReadOnlySpan`1 alert, ExceptionDispatchInfo exception) at System.Net.Security.SslStream.CompleteHandshake(SslAuthenticationOptions sslAuthenticationOptions) at System.Net.Security.SslStream.ForceAuthenticationAsync[TIOAdapter](Boolean receiveFirst, Byte reAuthenticationData, CancellationToken cancellationToken) at System.Net.Http.ConnectHelper.EstablishSslConnectionAsync(SslClientAuthenticationOptions sslOptions, HttpRequestMessage request, Boolean async, Stream stream, CancellationToken cancellationToken) — End of inner exception stack trace — at System.Net.Http.ConnectHelper.EstablishSslConnectionAsync(SslClientAuthenticationOptions sslOptions, HttpRequestMessage request, Boolean async, Stream stream, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.AddHttp11ConnectionAsync(QueueItem queueItem) at System.Threading.Tasks.TaskCompletionSourceWithCancellation`1.WaitWithCancellationAsync(CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at Microsoft.Extensions.Http.Logging.LoggingHttpMessageHandler.g__Core|5_0(HttpRequestMessage request, Boolean useAsync, CancellationToken cancellationToken) at Microsoft.Extensions.Http.Logging.LoggingScopeHttpMessageHandler.g__Core|5_0(HttpRequestMessage request, Boolean useAsync, CancellationToken cancellationToken) at System.Net.Http.HttpClient.g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) at Duplicati.Library.Utility.Utility.WithTimeout[T](TimeSpan timeout, CancellationToken token, Func`2 func) at Duplicati.Library.Backend.Backblaze.B2.GetAsync(String remotename, Stream stream, CancellationToken cancellationToken) at Duplicati.Library.Backend.Backblaze.B2.GetAsync(String remotename, Stream stream, CancellationToken cancellationToken) at Duplicati.Library.Main.Backend.BackendManager.GetOperation.DoGetFileAsync(IBackend backend, CancellationToken cancelToken) at Duplicati.Library.Main.Backend.BackendManager.GetOperation.ExecuteAsync(IBackend backend, CancellationToken cancelToken) at Duplicati.Library.Main.Backend.BackendManager.Handler.Execute[TResult](PendingOperation`1 op, CancellationToken cancellationToken) at Duplicati.Library.Main.Backend.BackendManager.Handler.Execute(PendingOperationBase op, CancellationToken cancellationToken) at Duplicati.Library.Main.Backend.BackendManager.Handler.ExecuteWithRetry(PendingOperationBase op, CancellationToken cancellationToken) at Duplicati.Library.Main.Backend.BackendManager.GetWithInfoAsync(String remotename, String hash, Int64 size, CancellationToken cancelToken) at Duplicati.Library.Main.Backend.BackendManager.GetFilesOverlappedAsync(IEnumerable`1 volumes, CancellationToken cancelToken)+MoveNext() at Duplicati.Library.Main.Backend.BackendManager.GetFilesOverlappedAsync(IEnumerable`1 volumes, CancellationToken cancelToken)+System.Threading.Tasks.Sources.IValueTaskSource<System.Boolean>.GetResult() at Duplicati.Library.Main.Operation.TestHandler.DoRunAsync(Int64 samples, LocalTestDatabase db, ReusableTransaction rtr, IBackendManager backend) at Duplicati.Library.Main.Operation.TestHandler.DoRunAsync(Int64 samples, LocalTestDatabase db, ReusableTransaction rtr, IBackendManager backend) at Duplicati.Library.Main.Operation.BackupHandler.PostBackupVerification(String currentFilelistVolume, String previousTemporaryFilelist, IBackendManager backendManager, ReusableTransaction rtr) at Duplicati.Library.Main.Operation.BackupHandler.RunAsync(String sources, IBackendManager backendManager, IFilter filter) at Duplicati.Library.Main.Controller.<>c__DisplayClass22_0.<b__0>d.MoveNext() — End of stack trace from previous location — at Duplicati.Library.Utility.Utility.Await(Task task) at Duplicati.Library.Main.Controller.RunAction[T](T result, String& paths, IFilter& filter, Func`3 method) at Duplicati.Library.Main.Controller.Backup(String inputsources, IFilter filter) at Duplicati.Server.Runner.RunInternal(Connection databaseConnection, EventPollNotify eventPollNotify, INotificationUpdateService notificationUpdateService, IProgressStateProviderService progressStateProviderService, IApplicationSettings applicationSettings, IRunnerData data, Boolean fromQueue)
Hi @ingolf and @luwill, welcome to the forum :waving_hand:
Is this related to running on a 32bit Linux?
If so, this is a related report: SSL connection could not be established (32 bit client, Debian Trixie, caused by change of libssl3 to libssl3t64.) · Issue #6554 · duplicati/duplicati · GitHub
The problem is the way .NET8 loads the libssl library on 32bit operating systems so we cannot fix it without upgrading to .NET10 (which we should do anyway)/
That would surprise me, as that is also based on .NET8. If you were on 2.0.8.1, that would be on Mono which had other SSL issues, but likely worked on 32bit.
Hi, @kenkendk.
Thanks for the welcome.
No, it’s x86_64.
/var/log/dpkg.log confirms that indeed, I was running 2.1.0.5 before:
2025-03-18 20:57:01 upgrade duplicati:amd64 2.1.0.3 2.1.0.5
2025-10-27 18:49:31 upgrade duplicati:amd64 2.1.0.5 2.2.0.0
2.1.0.5 had worked without problems since 2025-03-18. The upgrade to 2.2.0.0 on 2025-10-27 introduced the failure.
Kind regards
Ingolf
For the record, I downgraded to 2.1.0.5 an can now successfully back up my folders again.
Ingolf
The same here: Upgrade to 2.2.0.x introduced the problem on win_x64.
Same (ISH) problem here that began on 23 Oct.
System.Security.Authentication.AuthenticationException: The remote certificate is invalid because of errors in the certificate chain: NotTimeValid
Is there anything I can do to fix this?
Today, I gave the upgrade a new chance and upgraded from 2.1.0.5 directly to 2.2.0.1 (rather than going via 2.2.0.0 – I don’t know whether this is important). And guess what… backups work.
This is what I did:
  • download duplicati-2.2.0.1_stable_2025-11-09-linux-x64-gui.deb
  • sudo service duplicati stop
  • check that duplicati is indeed inactive: sudo service duplicati status
  • sudo gdebi duplicati-2.2.0.1_stable_2025-11-09-linux-x64-gui.deb
  • sudo service duplicati start
  • log in via the web GUI and start a backup
  • watch the backup process succeed
Kind regards
Ingolf
Same on my side. After upgrading from
2.1.0.5_stable_2025-03-04-win-x64-gui2.2.0.1_stable_2025-11-09-win-x64-gui
my WebDAV backup over HTTPS started failing with:
Backend is WebDAV over HTTPS with a Let’s Encrypt certificate.
The same URL works fine in a browser and via PowerShell (Invoke-WebRequest with TLS 1.2 enabled).
In Duplicati 2.2 it only works if I set the advanced option:
–accept-specified-ssl-hash=
With the same backend configuration, 2.1.0.5 ran without any SSL/TLS issues.
