Release: 2.1.0.125 (Canary) 2025-07-15
2.1.0.125_canary_2025-07-15
Changes in this versions
This is almost identical to 2.1.0.124, but adds some destination URL parsing fixes.
Detailed list of changes:
  • Fixed wrong SQLite environment variable name
  • Don’t show stack if stopping a backup due to missing sources
  • Update logic for probing for an access method in ServerUtil
  • Fixed ngax not supporting --use-ssl
  • Use template icons on macOS
  • Fixed an error when loading log data
  • Avoid floods of notifications
  • Corrected encode/decode of URLs
  • Fixed issue with recreated index files not reporting deleted blocks
New in 2.1.0.125
  • Fixed parsing of correctly encoded file-based URLs on Windows
ngclient changes
  • Fixed SMB editor handling paths incorrectly
  • Fixed source editor not inserting empty paths
  • Fixed an issue with selecting paths with a space
  • Fixed some dialogs not updating UI after clicking cancelable
  • Removed an extra leading slash for Windows destination paths
  • Recalculate file existing on database move
  • Show correct date and format in logs
New in 2.1.0.125
  • Fixed URL for bugreport in ngclient
  • Fixed incorrect encoding/decoding of Windows file-paths for destination
  • Fixed logic for removing source paths to no create empty entries
  • Added a partial marker for fileset version that are partial
New install on Linux (Fedora) using b2. I had to set read-write-timeout to 5 minutes as the default of 30 seconds kept timing-out. So far 5 minutes is working OK.
I think we have discovered the cause of this, and it is indeed B2 specific.
I have upgraded one of my Linux systems to 2.1.1.100-canary, removed the read-write-timeout option and manually triggered all of its jobs. All ran with no apparent errors.
Will try to upgrade my Windows 10 system later tonight.
EDIT 1
Wasn’t able to upgrade the Windows 10 system until this morning. As with the Linux system mentioned above, removed the read-write-timeout option and manually triggered all of its jobs. All ran with no apparent errors.
