Release: 2.0.5.100 (canary) 2020-01-18
2.0.5.100-2.0.5.100_canary_2020-01-18
  • Fixed issue with restoring permissions with inheritance, thanks @drwtsn32x
  • Improved tests, thanks @warwickmm
  • Fixed an issue that could be triggered by force stopping a backup, thanks @seantempleton
Build system broke for this one, so some installers/packages are missing. I will fix the build system and make a new release.
Credit for this should go to @seantempleton. @kenkendk, I edited the first post if that’s ok with you.
Any luck fixing this build?
I managed to get it building the installers, but I opted for just making a new build (101) instead. Do you need a particular installer from this release?
No, the new build is perfect - thanks
