Release: 2.0.4.34 (canary) 2019-11-05
2.0.4.34-2.0.4.34_canary_2019-11-05
  • Stapling macOS notarization to bundles, thanks @kenkendk
  • Removed option to store fileset in memory, thanks @tygill
  • Fixed failure on password-protected servers introduced in 2.0.4.32, thanks @warwickmm
  • Improved progress reporting, thanks @ltfish
If anyone wants to try the improved macOS Catalina support, you need to install the new version, as the change is in the launcher, and the launcher is not part of the auto-update process.
