I attempted to restore 350 GB of images in one go. Since I had previously restored my Windows 10 Pro system using Veeam, the database was not completely up to date. What would have been the best option to ensure it pulls the current database from the server?
In any case, I proceeded with the restoration using the exported configuration. Everything went smoothly until only about 160 GB were left, at which point it stopped, and I had no way to get it running again, not even with the pause and resume options.
Here are the last log entries from the process:
- Feb 2025 11:50: CommitBlockMarker took 0:00:00:00.000
- Feb 2025 11:50: Starting - CommitBlockMarker
- Feb 2025 11:50: Recording metadata from remote data: D:\Bilder\mila\Handy A32\Camera\VID_20210824_142513.mp4
Unfortunately, it seems there is no way to resume the restore exactly from that point. I have now downloaded and installed the latest version (duplicati-2.1.0.109_canary_2025-02-11-win-x64-gui.msi) and started the restoration again from the configuration file. However, it did not recognize that there was a previous ongoing action.
There is also a kind of error. During the process, the status shows “no scheduled task,” which was better in the old version. In the previous version, it indicated that something was happening. A look at the log files (ExplicitOnly) reveals that a lot is indeed happening.
Additionally, there is no option during the restore to select that it only backs up missing files, which would save some time.
Is there a way to do this, perhaps through the console? Did I make a mistake in the process?
