Trying to backup ~2 dozen users’ machines (all MacOS 10.12 or higher; for most users just backing up their home directories) to an Ubuntu 18.04.3 LTS server with more than enough processing power and storage capacity for this particular project (different user accounts/directories for each backup). All Backups have been configured through Duplicati in the same way, and worked on all but one machine for reasons I can’t understand from log output. Any assistance would be greatly appreciated
Below are the partially redacted configuration file contents, and the log error traceback.
Configuration (IP address, user/pass, id_rsa redacted, all else intact):
“CreatedByVersion”: “2.0.4.23”,
“Schedule”: {
“ID”: 1,
“Tags”: [
“ID=5”
“Time”: “2019-08-23T17:00:00Z”,
“Repeat”: “1D”,
“LastRun”: “0001-01-01T04:57:00Z”,
“Rule”: “AllowedWeekDays=Monday,Tuesday,Wednesday,Thursday,Friday,Saturday,Sunday”,
“AllowedDays”: [
“mon”,
“tue”,
“wed”,
“thu”,
“fri”,
“sat”,
“sun”
“Backup”: {
“ID”: “5”,
“Name”: “’s iMac",
“Description”: “”,
“Tags”: [],
“TargetURL”: "ssh://...:22//home//backups?auth-username=&auth-password=&ssh-keyfile=%2FUsers%2F******%2F.ssh%2Fid_rsa&ssh-fingerprint=ssh-rsa**************************************************************************”,
“DBPath”: “/Users//.config/Duplicati/78808986806884888671.sqlite",
“Sources”: [
"/Users//Desktop/”,
“/Users//Documents/",
"/Users//Dropbox/”,
“/Users//Downloads/",
"/Users//Zotero/”
“Settings”: [
“Filter”: “”,
“Name”: “encryption-module”,
“Value”: “aes”,
“Argument”: null
“Filter”: “”,
“Name”: “compression-module”,
“Value”: “zip”,
“Argument”: null
“Filter”: “”,
“Name”: “dblock-size”,
“Value”: “50mb”,
“Argument”: null
“Filter”: “”,
“Name”: “keep-time”,
“Value”: “1Y”,
“Argument”: null
“Filter”: “”,
“Name”: “passphrase”,
“Value”: “",
“Argument”: null
“Filters”: [],
“Metadata”: {
“LastErrorDate”: “20190822T172244Z”,
“LastErrorMessage”: “One or more errors occurred. (Object reference not set to an instance of an object (Object reference not set to an instance of an object) (One or more errors occurred. (Permission denied)))”
“IsTemporary”: false
“DisplayNames”: {
"/Users//Desktop/": “Desktop”,
"/Users//Documents/": “Documents”,
"/Users//Dropbox/": “Dropbox”,
"/Users//Downloads/": “Downloads”,
"/Users/******/Zotero/”: “Zotero”
Log output:
{“ClassName”:“System.AggregateException”,“Message”:“One or more errors occurred.”,“Data”:null,“InnerException”:{“ClassName”:“System.AggregateException”,“Message”:“Object reference not set to an instance of an object”,“Data”:null,“InnerException”:{“ClassName”:“System.NullReferenceException”,“Message”:“Object reference not set to an instance of an object”,“Data”:null,“InnerException”:null,“HelpURL”:null,“StackTraceString”:" at Duplicati.Library.Main.Volumes.BlockVolumeWriter.AddBlock (System.String hash, System.Byte data, System.Int32 offset, System.Int32 size, Duplicati.Library.Interface.CompressionHint hint) [0x00032] in :0 \n at Duplicati.Library.Main.Operation.Backup.SpillCollectorProcess+<>c__DisplayClass0_0.b__0 (<>f__AnonymousType92[<Input>j__TPar,<Output>j__TPar] self) [0x003df] in <e2da9713f0974e76879d9f9aa7ce0e36>:0 \n at CoCoL.AutomationExtensions.RunTask[T] (T channels, System.Func
2[T,TResult] method, System.Boolean catchRetiredExceptions) [0x000cc] in <6973ce2780de4b28aaa2c5ffc59993b1>:0 \n at Duplicati.Library.Main.Operation.BackupHandler.RunMainOperation (System.Collections.Generic.IEnumerable1[T] sources, Duplicati.Library.Snapshots.ISnapshotService snapshot, Duplicati.Library.Snapshots.UsnJournalService journalService, Duplicati.Library.Main.Operation.Backup.BackupDatabase database, Duplicati.Library.Main.Operation.Backup.BackupStatsCollector stats, Duplicati.Library.Main.Options options, Duplicati.Library.Utility.IFilter sourcefilter, Duplicati.Library.Utility.IFilter filter, Duplicati.Library.Main.BackupResults result, Duplicati.Library.Main.Operation.Common.ITaskReader taskreader, System.Int64 lastfilesetid) [0x00349] in <e2da9713f0974e76879d9f9aa7ce0e36>:0 \n at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter) [0x00a43] in <e2da9713f0974e76879d9f9aa7ce0e36>:0 ","RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":null,"HResult":-2147467261,"Source":"mscorlib"},"HelpURL":null,"StackTraceString":" at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter) [0x01033] in <e2da9713f0974e76879d9f9aa7ce0e36>:0 ","RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":null,"HResult":-2146233088,"Source":"Duplicati.Library.Main","InnerExceptions":[{"ClassName":"System.NullReferenceException","Message":"Object reference not set to an instance of an object","Data":null,"InnerException":null,"HelpURL":null,"StackTraceString":" at Duplicati.Library.Main.Volumes.BlockVolumeWriter.AddBlock (System.String hash, System.Byte[] data, System.Int32 offset, System.Int32 size, Duplicati.Library.Interface.CompressionHint hint) [0x00032] in <e2da9713f0974e76879d9f9aa7ce0e36>:0 \n at Duplicati.Library.Main.Operation.Backup.SpillCollectorProcess+<>c__DisplayClass0_0.<Run>b__0 (<>f__AnonymousType9
2[j__TPar,j__TPar] self) [0x003df] in :0 \n at CoCoL.AutomationExtensions.RunTask[T] (T channels, System.Func2[T,TResult] method, System.Boolean catchRetiredExceptions) [0x000cc] in <6973ce2780de4b28aaa2c5ffc59993b1>:0 \n at Duplicati.Library.Main.Operation.BackupHandler.RunMainOperation (System.Collections.Generic.IEnumerable
1[T] sources, Duplicati.Library.Snapshots.ISnapshotService snapshot, Duplicati.Library.Snapshots.UsnJournalService journalService, Duplicati.Library.Main.Operation.Backup.BackupDatabase database, Duplicati.Library.Main.Operation.Backup.BackupStatsCollector stats, Duplicati.Library.Main.Options options, Duplicati.Library.Utility.IFilter sourcefilter, Duplicati.Library.Utility.IFilter filter, Duplicati.Library.Main.BackupResults result, Duplicati.Library.Main.Operation.Common.ITaskReader taskreader, System.Int64 lastfilesetid) [0x00349] in :0 \n at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String sources, Duplicati.Library.Utility.IFilter filter) [0x00a43] in :0 “,“RemoteStackTraceString”:null,“RemoteStackIndex”:0,“ExceptionMethod”:null,“HResult”:-2147467261,“Source”:“mscorlib”},{“ClassName”:“System.AggregateException”,“Message”:“One or more errors occurred.”,“Data”:null,“InnerException”:{“ClassName”:“Renci.SshNet.Common.SftpPermissionDeniedException”,“Message”:“Permission denied”,“Data”:null,“InnerException”:null,“HelpURL”:null,“StackTraceString”:” at Renci.SshNet.Sftp.SftpSession.RequestOpen (System.String path, Renci.SshNet.Sftp.Flags flags, System.Boolean nullOnError) [0x00099] in <502177f7126d48e4be01a83c8cdb4c79>:0 \n at Renci.SshNet.SftpClient.InternalUploadFile (System.IO.Stream input, System.String path, Renci.SshNet.Sftp.Flags flags, Renci.SshNet.Sftp.SftpUploadAsyncResult asyncResult, System.Action1[T] uploadCallback) [0x0004f] in <502177f7126d48e4be01a83c8cdb4c79>:0 \n at Renci.SshNet.SftpClient.UploadFile (System.IO.Stream input, System.String path, System.Boolean canOverride, System.Action
1[T] uploadCallback) [0x00017] in <502177f7126d48e4be01a83c8cdb4c79>:0 \n at Renci.SshNet.SftpClient.UploadFile (System.IO.Stream input, System.String path, System.Action1[T] uploadCallback) [0x00000] in <502177f7126d48e4be01a83c8cdb4c79>:0 \n at Duplicati.Library.Backend.SSHv2.Put (System.String remotename, System.IO.Stream stream) [0x00012] in <3bb874d28f9e4f4ba0342a049f16319d>:0 \n at Duplicati.Library.Main.Operation.Common.BackendHandler.DoPut (Duplicati.Library.Main.Operation.Common.BackendHandler+FileEntryItem item, System.Boolean updatedHash) [0x0037c] in <e2da9713f0974e76879d9f9aa7ce0e36>:0 \n at Duplicati.Library.Main.Operation.Common.BackendHandler+<>c__DisplayClass13_0.<UploadFileAsync>b__2 () [0x00170] in <e2da9713f0974e76879d9f9aa7ce0e36>:0 \n at Duplicati.Library.Main.Operation.Common.BackendHandler.DoWithRetry[T] (Duplicati.Library.Main.Operation.Common.BackendHandler+FileEntryItem item, System.Func
1[TResult] method) [0x004c0] in :0 \n at Duplicati.Library.Main.Operation.Common.BackendHandler+<>c__DisplayClass13_0.b__1 () [0x000b1] in :0 \n at Duplicati.Library.Main.Operation.Common.BackendHandler.UploadFileAsync (Duplicati.Library.Main.Volumes.VolumeWriterBase item, System.Func2[T,TResult] createIndexFile) [0x00181] in <e2da9713f0974e76879d9f9aa7ce0e36>:0 \n at Duplicati.Library.Main.Operation.Backup.BackendUploader+<>c__DisplayClass0_0.<Run>b__0 (<>f__AnonymousType11
1[j__TPar] self) [0x00519] in :0 \n at CoCoL.AutomationExtensions.RunTask[T] (T channels, System.Func2[T,TResult] method, System.Boolean catchRetiredExceptions) [0x000cc] in <6973ce2780de4b28aaa2c5ffc59993b1>:0 ","RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":null,"HResult":-2146233088,"Source":"mscorlib"},"HelpURL":null,"StackTraceString":null,"RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":null,"HResult":-2146233088,"Source":null,"InnerExceptions":[{"ClassName":"Renci.SshNet.Common.SftpPermissionDeniedException","Message":"Permission denied","Data":null,"InnerException":null,"HelpURL":null,"StackTraceString":" at Renci.SshNet.Sftp.SftpSession.RequestOpen (System.String path, Renci.SshNet.Sftp.Flags flags, System.Boolean nullOnError) [0x00099] in <502177f7126d48e4be01a83c8cdb4c79>:0 \n at Renci.SshNet.SftpClient.InternalUploadFile (System.IO.Stream input, System.String path, Renci.SshNet.Sftp.Flags flags, Renci.SshNet.Sftp.SftpUploadAsyncResult asyncResult, System.Action
1[T] uploadCallback) [0x0004f] in <502177f7126d48e4be01a83c8cdb4c79>:0 \n at Renci.SshNet.SftpClient.UploadFile (System.IO.Stream input, System.String path, System.Boolean canOverride, System.Action1[T] uploadCallback) [0x00017] in <502177f7126d48e4be01a83c8cdb4c79>:0 \n at Renci.SshNet.SftpClient.UploadFile (System.IO.Stream input, System.String path, System.Action
1[T] uploadCallback) [0x00000] in <502177f7126d48e4be01a83c8cdb4c79>:0 \n at Duplicati.Library.Backend.SSHv2.Put (System.String remotename, System.IO.Stream stream) [0x00012] in <3bb874d28f9e4f4ba0342a049f16319d>:0 \n at Duplicati.Library.Main.Operation.Common.BackendHandler.DoPut (Duplicati.Library.Main.Operation.Common.BackendHandler+FileEntryItem item, System.Boolean updatedHash) [0x0037c] in :0 \n at Duplicati.Library.Main.Operation.Common.BackendHandler+<>c__DisplayClass13_0.b__2 () [0x00170] in :0 \n at Duplicati.Library.Main.Operation.Common.BackendHandler.DoWithRetry[T] (Duplicati.Library.Main.Operation.Common.BackendHandler+FileEntryItem item, System.Func1[TResult] method) [0x004c0] in <e2da9713f0974e76879d9f9aa7ce0e36>:0 \n at Duplicati.Library.Main.Operation.Common.BackendHandler+<>c__DisplayClass13_0.<UploadFileAsync>b__1 () [0x000b1] in <e2da9713f0974e76879d9f9aa7ce0e36>:0 \n at Duplicati.Library.Main.Operation.Common.BackendHandler.UploadFileAsync (Duplicati.Library.Main.Volumes.VolumeWriterBase item, System.Func
2[T,TResult] createIndexFile) [0x00181] in :0 \n at Duplicati.Library.Main.Operation.Backup.BackendUploader+<>c__DisplayClass0_0.b__0 (<>f__AnonymousType111[<Input>j__TPar] self) [0x00519] in <e2da9713f0974e76879d9f9aa7ce0e36>:0 \n at CoCoL.AutomationExtensions.RunTask[T] (T channels, System.Func
2[T,TResult] method, System.Boolean catchRetiredExceptions) [0x000cc] in <6973ce2780de4b28aaa2c5ffc59993b1>:0 “,“RemoteStackTraceString”:null,“RemoteStackIndex”:0,“ExceptionMethod”:null,“HResult”:-2146233088,“Source”:“mscorlib”}]}]},“HelpURL”:null,“StackTraceString”:” at CoCoL.ChannelExtensions.WaitForTaskOrThrow (System.Threading.Tasks.Task task) [0x0005d] in <6973ce2780de4b28aaa2c5ffc59993b1>:0 \n at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String sources, Duplicati.Library.Utility.IFilter filter) [0x00008] in :0 \n at Duplicati.Library.Main.Controller+<>c__DisplayClass13_0.b__0 (Duplicati.Library.Main.BackupResults result) [0x00035] in :0 \n at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String& paths, Duplicati.Library.Utility.IFilter& filter, System.Action1[T] method) [0x00271] in <e2da9713f0974e76879d9f9aa7ce0e36>:0 \n at Duplicati.Library.Main.Controller.Backup (System.String[] inputsources, Duplicati.Library.Utility.IFilter filter) [0x00068] in <e2da9713f0974e76879d9f9aa7ce0e36>:0 \n at Duplicati.Server.Runner.Run (Duplicati.Server.Runner+IRunnerData data, System.Boolean fromQueue) [0x00307] in <be73c239d77d4180b5147067144fc237>:0 ","RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":null,"HResult":-2146233088,"Source":"CoCoL","InnerExceptions":[{"ClassName":"System.AggregateException","Message":"Object reference not set to an instance of an object","Data":null,"InnerException":{"ClassName":"System.NullReferenceException","Message":"Object reference not set to an instance of an object","Data":null,"InnerException":null,"HelpURL":null,"StackTraceString":" at Duplicati.Library.Main.Volumes.BlockVolumeWriter.AddBlock (System.String hash, System.Byte[] data, System.Int32 offset, System.Int32 size, Duplicati.Library.Interface.CompressionHint hint) [0x00032] in <e2da9713f0974e76879d9f9aa7ce0e36>:0 \n at Duplicati.Library.Main.Operation.Backup.SpillCollectorProcess+<>c__DisplayClass0_0.<Run>b__0 (<>f__AnonymousType9
1[T] sources, Duplicati.Library.Snapshots.ISnapshotService snapshot, Duplicati.Library.Snapshots.UsnJournalService journalService, Duplicati.Library.Main.Operation.Backup.BackupDatabase database, Duplicati.Library.Main.Operation.Backup.BackupStatsCollector stats, Duplicati.Library.Main.Options options, Duplicati.Library.Utility.IFilter sourcefilter, Duplicati.Library.Utility.IFilter filter, Duplicati.Library.Main.BackupResults result, Duplicati.Library.Main.Operation.Common.ITaskReader taskreader, System.Int64 lastfilesetid) [0x00349] in :0 \n at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String sources, Duplicati.Library.Utility.IFilter filter) [0x00a43] in :0 “,“RemoteStackTraceString”:null,“RemoteStackIndex”:0,“ExceptionMethod”:null,“HResult”:-2147467261,“Source”:“mscorlib”},“HelpURL”:null,“StackTraceString”:” at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String sources, Duplicati.Library.Utility.IFilter filter) [0x01033] in :0 “,“RemoteStackTraceString”:null,“RemoteStackIndex”:0,“ExceptionMethod”:null,“HResult”:-2146233088,“Source”:“Duplicati.Library.Main”,“InnerExceptions”:[{“ClassName”:“System.NullReferenceException”,“Message”:“Object reference not set to an instance of an object”,“Data”:null,“InnerException”:null,“HelpURL”:null,“StackTraceString”:” at Duplicati.Library.Main.Volumes.BlockVolumeWriter.AddBlock (System.String hash, System.Byte data, System.Int32 offset, System.Int32 size, Duplicati.Library.Interface.CompressionHint hint) [0x00032] in :0 \n at Duplicati.Library.Main.Operation.Backup.SpillCollectorProcess+<>c__DisplayClass0_0.b__0 (<>f__AnonymousType92[<Input>j__TPar,<Output>j__TPar] self) [0x003df] in <e2da9713f0974e76879d9f9aa7ce0e36>:0 \n at CoCoL.AutomationExtensions.RunTask[T] (T channels, System.Func
2[T,TResult] method, System.Boolean catchRetiredExceptions) [0x000cc] in <6973ce2780de4b28aaa2c5ffc59993b1>:0 \n at Duplicati.Library.Main.Operation.BackupHandler.RunMainOperation (System.Collections.Generic.IEnumerable1[T] sources, Duplicati.Library.Snapshots.ISnapshotService snapshot, Duplicati.Library.Snapshots.UsnJournalService journalService, Duplicati.Library.Main.Operation.Backup.BackupDatabase database, Duplicati.Library.Main.Operation.Backup.BackupStatsCollector stats, Duplicati.Library.Main.Options options, Duplicati.Library.Utility.IFilter sourcefilter, Duplicati.Library.Utility.IFilter filter, Duplicati.Library.Main.BackupResults result, Duplicati.Library.Main.Operation.Common.ITaskReader taskreader, System.Int64 lastfilesetid) [0x00349] in <e2da9713f0974e76879d9f9aa7ce0e36>:0 \n at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter) [0x00a43] in <e2da9713f0974e76879d9f9aa7ce0e36>:0 ","RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":null,"HResult":-2147467261,"Source":"mscorlib"},{"ClassName":"System.AggregateException","Message":"One or more errors occurred.","Data":null,"InnerException":{"ClassName":"Renci.SshNet.Common.SftpPermissionDeniedException","Message":"Permission denied","Data":null,"InnerException":null,"HelpURL":null,"StackTraceString":" at Renci.SshNet.Sftp.SftpSession.RequestOpen (System.String path, Renci.SshNet.Sftp.Flags flags, System.Boolean nullOnError) [0x00099] in <502177f7126d48e4be01a83c8cdb4c79>:0 \n at Renci.SshNet.SftpClient.InternalUploadFile (System.IO.Stream input, System.String path, Renci.SshNet.Sftp.Flags flags, Renci.SshNet.Sftp.SftpUploadAsyncResult asyncResult, System.Action
2[T,TResult] method, System.Boolean catchRetiredExceptions) [0x000cc] in <6973ce2780de4b28aaa2c5ffc59993b1>:0 “,“RemoteStackTraceString”:null,“RemoteStackIndex”:0,“ExceptionMethod”:null,“HResult”:-2146233088,“Source”:“mscorlib”},“HelpURL”:null,“StackTraceString”:null,“RemoteStackTraceString”:null,“RemoteStackIndex”:0,“ExceptionMethod”:null,“HResult”:-2146233088,“Source”:null,“InnerExceptions”:[{“ClassName”:“Renci.SshNet.Common.SftpPermissionDeniedException”,“Message”:“Permission denied”,“Data”:null,“InnerException”:null,“HelpURL”:null,“StackTraceString”:” at Renci.SshNet.Sftp.SftpSession.RequestOpen (System.String path, Renci.SshNet.Sftp.Flags flags, System.Boolean nullOnError) [0x00099] in <502177f7126d48e4be01a83c8cdb4c79>:0 \n at Renci.SshNet.SftpClient.InternalUploadFile (System.IO.Stream input, System.String path, Renci.SshNet.Sftp.Flags flags, Renci.SshNet.Sftp.SftpUploadAsyncResult asyncResult, System.Action1[T] uploadCallback) [0x0004f] in <502177f7126d48e4be01a83c8cdb4c79>:0 \n at Renci.SshNet.SftpClient.UploadFile (System.IO.Stream input, System.String path, System.Boolean canOverride, System.Action
1[j__TPar] self) [0x00519] in :0 \n at CoCoL.AutomationExtensions.RunTask[T] (T channels, System.Func`2[T,TResult] method, System.Boolean catchRetiredExceptions) [0x000cc] in <6973ce2780de4b28aaa2c5ffc59993b1>:0 ",“RemoteStackTraceString”:null,“RemoteStackIndex”:0,“ExceptionMethod”:null,“HResult”:-2146233088,“Source”:“mscorlib”}]}]}]}
