Olá, caso eu queira trocar o sistema operacional, mantendo a mesma plataforma Windows, existe a possibilidade de restaurar também a instalação do Duplicati?
Hello and welcome to the forum! I don’t speak Portuguese, but I hope this post will help you out. It shows how to set up Duplicati on a new replacement PC and resume backups:
Hi Everyone,
Thanks for your help! Method 2 worked perfectly.
Below is a step by step summary of how to do in case somebody else needs to do it in the future:
Scenario
After a total data loss, you would like to restore all data from backup and set up again backup job as before the data loss occurred.
Prerequisites
OS + Duplicati installation files (if you also lost your OS).
Encryption password for your backup (obviously!).
Text export of Duplicati “Default options” [alternatively, if you…
ts678
March 23, 2020, 2:07pm
#3
I have read the various posts, but it would be nice if there was a FAQ on migrating to a new PC; best/quickest/most efficient. Hope I didn’t miss one.
In my case, the new PC will be a duplicate of the old as regards users and data locations, and I will have access to all the old Duplicati index files etc. The pc name will change from Sphere to FTS (don’t ask )
I propose to stop Duplicati on the old machine when I’m ready to change over and copy across all of the Duplicati jobs and in…
is another. Maybe one of these will help.
