As long as I add --no-backend-verification=true to the global OR job settings (to get around the “missing files” error) I’m able to do a GUI based restore of files and versions as expected.
That will be my ultimate step, which I believe will resolve the issue. I agree with Pectojin that the main DB isn’t touched (much) in a repair, but I also agree with Wim_Jansen that job specific file lists and such aren’t stored in it so that shouldn’t be a problem.
Since this is a personal machine and Duplicati isn’t my only backup tool at the moment (figured I’d keep CrashPlan around until they turned me off) I thought it might be worth trying to figure out what caused the issue in the first place.
Just to be clear, I suspect this is not a problem with the destination as the Duplicati logs show the files being targeted for deletion then actually being deleted.
General Remote
Mar 1, 2018 8:21 AM: Result
Mar 1, 2018 8:05 AM: Result
Feb 28, 2018 2:00 PM: Message
Fatal error
Duplicati.Library.Interface.UserInformationException: Found 1937 files that are missing from the remote storage, please run repair
at Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList(BackendManager backend, Options options, LocalDatabase database, IBackendWriter log, String protectedfile)
Missing file: duplicati-ia00312535a174edbb6ec08c25f7786dd.dindex.7z.aes
Feb 28, 2018 1:52 PM: Message
Missing file: duplicati-ic0f964d9c6cf434f99c97b1c06cfc542.dindex.zip.aes
Missing file: duplicati-i07b4e403f27f4fbfad6335f8ddfc5478.dindex.zip.aes
*** What (didn't?) happen during this 3 minute log gap? ***
Feb 28, 2018 1:49 PM: Message
removing file listed as Temporary: duplicati-i0e1558f3c2a54f9694b4b59d1583bc79.dindex.7z.aes
removing file listed as Temporary: duplicati-b4bed0436a81d4c5c820d1db22163453c.dblock.7z.aes
removing file listed as Deleting: duplicati-bac08102d4c82443e88d88f6d6cdc897e.dblock.7z.aes
removing file listed as Deleting: duplicati-b3b1233e94f2b41218b9c4b12b37040ec.dblock.7z.aes
Feb 28, 2018 1:41 PM: Message
removing file listed as Deleting: duplicati-b13ad78fdd30e492a8706e30156a1b365.dblock.zip.aes
removing file listed as Deleting: duplicati-b48fb570899404ca4af18bcee968fa028.dblock.zip.aes
Feb 28, 2018 12:15 AM: Message
Compacting because there are 1937 fully deletable volume(s)
Feb 28, 2018 12:09 AM: Message
Deleted 150 remote fileset(s)
Feb 27, 2018 11:34 PM: Message
Deleting 150 remote fileset(s) ...
[Retention Policy]: All backups to delete: 2/20/2018 10:10:48 PM, 2/19/2018 6:44:01 PM, 2/18/2018 1:39:12 PM, 2/17/2018 11:00:02 AM, 2/16/2018 11:00:30 AM, 2/14/2018 5:31:16 PM, 2/12/2018 11:00:01 AM, 2/11/2018 11:40:06 AM, 2/10/2018 11:00:06 AM, 2/9/2018 11:00:03 AM, 2/8/2018 11:00:01 AM, 2/6/2018 7:12:52 PM, 2/5/2018 12:14:59 PM, 2/4/2018 12:57:28 PM, 2/4/2018 8:06:24 AM, 2/3/2018 11:35:01 AM, 2/2/2018 5:49:14 PM, 2/1/2018 11:09:14 AM, 1/30/2018 9:04:07 PM, 1/29/2018 7:04:45 PM, 1/27/2018 11:00:05 AM, 1/26/2018 10:47:13 PM, 1/24/2018 11:00:00 AM, 1/23/2018 11:18:55 AM, 1/22/2018 11:00:07 AM, 1/21/2018 11:00:01 AM, 1/21/2018 12:59:21 AM, 1/20/2018 12:14:26 PM, 1/19/2018 6:57:07 AM, 1/17/2018 11:00:05 AM, 1/16/2018 5:18:56 PM, 1/15/2018 11:00:18 AM, 1/14/2018 11:20:35 AM, 1/13/2018 11:00:04 AM, 1/12/2018 5:36:07 PM, 1/11/2018 2:40:23 PM, 1/10/2018 11:00:01 AM, 1/9/2018 8:52:14 PM, 1/8/2018 11:00:01 AM, 1/7/2018 9:35:49 PM, 1/6/2018 11:00:02 AM, 1/5/2018 11:00:02 AM, 1/4/2018 1:59:37 PM, 1/3/2018 4:47:52 PM, 1/2/2018 12:59:30 PM, 1/1/2018 12:01:59 PM, 12/31/2017 11:03:39 AM, 12/30/2017 12:08:39 PM, 12/30/2017 11:25:20 AM, 12/30/2017 10:16:19 AM, 12/28/2017 3:53:25 PM, 12/26/2017 11:00:04 AM, 12/25/2017 11:00:04 AM, 12/24/2017 11:00:01 AM, 12/23/2017 11:00:01 AM, 12/22/2017 11:00:33 AM, 12/21/2017 11:00:03 AM, 12/20/2017 2:16:39 PM, 12/19/2017 11:00:06 AM, 12/18/2017 11:00:05 AM, 12/17/2017 11:00:01 AM, 12/9/2017 12:00:12 PM, 12/8/2017 11:59:55 PM, 12/7/2017 8:55:55 PM, 12/5/2017 2:35:08 PM, 12/2/2017 12:00:01 PM, 12/2/2017 9:42:16 AM, 11/30/2017 9:20:18 PM, 11/28/2017 8:59:20 PM, 11/27/2017 12:00:01 PM, 11/26/2017 8:20:58 PM, 11/24/2017 8:17:44 PM, 11/22/2017 10:27:53 PM, 11/21/2017 12:00:05 PM, 11/20/2017 10:57:00 PM, 11/19/2017 6:57:51 PM, 11/17/2017 9:54:56 PM, 11/16/2017 4:14:19 PM, 11/14/2017 9:51:50 PM, 11/13/2017 2:29:48 PM, 11/12/2017 5:40:40 PM, 11/11/2017 2:08:28 PM, 11/8/2017 6:39:46 PM, 11/7/2017 7:23:56 PM, 11/6/2017 10:29:48 PM, 11/5/2017 6:17:20 PM, 11/4/2017 7:13:01 PM, 11/3/2017 1:00:00 PM, 11/2/2017 11:21:10 PM, 11/1/2017 10:18:48 PM, 10/31/2017 6:06:48 PM, 10/30/2017 8:28:09 PM, 10/29/2017 10:13:16 PM, 10/27/2017 1:00:00 PM, 10/26/2017 10:21:57 PM, 10/26/2017 9:43:36 PM, 10/26/2017 6:27:54 PM, 10/25/2017 8:32:11 PM, 10/23/2017 1:00:01 PM, 10/22/2017 7:40:59 PM, 10/22/2017 10:06:49 AM, 10/21/2017 10:04:56 PM, 10/18/2017 11:10:22 PM, 10/18/2017 8:58:56 PM, 10/16/2017 1:00:04 PM, 10/15/2017 10:06:05 PM, 10/14/2017 1:00:02 PM, 10/14/2017 10:13:01 AM, 10/13/2017 8:56:59 AM, 10/12/2017 11:22:25 PM, 10/12/2017 1:00:02 PM, 10/11/2017 6:41:59 PM, 10/10/2017 8:24:31 PM, 10/10/2017 7:34:52 PM, 10/9/2017 2:47:18 PM, 10/8/2017 6:37:17 AM, 10/6/2017 1:00:05 PM, 10/5/2017 8:11:44 PM, 10/4/2017 10:03:27 PM, 10/4/2017 9:18:29 PM, 10/4/2017 8:23:00 PM, 10/1/2017 3:18:56 PM, 9/29/2017 1:00:03 PM, 9/28/2017 9:39:38 PM, 9/27/2017 1:16:21 PM, 9/26/2017 10:36:54 PM, 9/24/2017 1:59:17 PM, 9/23/2017 1:00:02 PM, 9/21/2017 7:20:25 PM, 9/18/2017 9:48:23 PM, 9/17/2017 8:17:36 PM, 9/16/2017 10:30:32 AM, 9/15/2017 11:19:12 PM, 9/15/2017 9:40:44 PM, 9/12/2017 8:56:08 PM, 9/11/2017 2:01:26 PM, 9/9/2017 11:04:30 PM, 9/9/2017 9:48:19 PM, 9/6/2017 8:56:13 PM, 9/4/2017 9:47:47 PM, 9/4/2017 7:48:36 PM, 9/2/2017 9:52:11 PM, 9/2/2017 3:35:02 PM, 8/30/2017 8:03:24 PM, 8/30/2017 7:49:25 AM, 8/29/2017 10:33:49 PM, 8/29/2017 5:12:41 PM, 8/22/2017 11:05:18 PM, 8/22/2017 10:45:34 PM, 8/22/2017 10:44:16 PM
[Retention Policy]: Backups outside of all time frames and thus getting deleted:
[Retention Policy]: Backups to consider: 2/26/2018 3:27:07 PM, 2/25/2018 1:00:55 PM, 2/24/2018 3:55:59 PM, 2/23/2018 7:06:41 PM, 2/22/2018 7:57:36 PM, 2/21/2018 7:23:38 PM, 2/20/2018 10:10:48 PM, 2/19/2018 6:44:01 PM, 2/18/2018 1:39:12 PM, 2/17/2018 11:00:02 AM, 2/16/2018 11:00:30 AM, 2/15/2018 11:43:25 PM, 2/14/2018 5:31:16 PM, 2/12/2018 11:00:01 AM, 2/11/2018 11:40:06 AM, 2/10/2018 11:00:06 AM, 2/9/2018 11:00:03 AM, 2/8/2018 11:00:01 AM, 2/7/2018 9:26:04 PM, 2/6/2018 7:12:52 PM, 2/5/2018 12:14:59 PM, 2/4/2018 12:57:28 PM, 2/4/2018 8:06:24 AM, 2/3/2018 11:35:01 AM, 2/2/2018 5:49:14 PM, 2/1/2018 11:09:14 AM, 1/31/2018 11:00:00 AM, 1/30/2018 9:04:07 PM, 1/29/2018 7:04:45 PM, 1/28/2018 11:00:01 AM, 1/27/2018 11:00:05 AM, 1/26/2018 10:47:13 PM, 1/24/2018 11:00:00 AM, 1/23/2018 11:18:55 AM, 1/22/2018 11:00:07 AM, 1/21/2018 11:00:01 AM, 1/21/2018 12:59:21 AM, 1/20/2018 12:14:26 PM, 1/19/2018 6:57:07 AM, 1/17/2018 11:00:05 AM, 1/16/2018 5:18:56 PM, 1/15/2018 11:00:18 AM, 1/14/2018 11:20:35 AM, 1/13/2018 11:00:04 AM, 1/12/2018 5:36:07 PM, 1/11/2018 2:40:23 PM, 1/10/2018 11:00:01 AM, 1/9/2018 8:52:14 PM, 1/8/2018 11:00:01 AM, 1/7/2018 9:35:49 PM, 1/6/2018 11:00:02 AM, 1/5/2018 11:00:02 AM, 1/4/2018 1:59:37 PM, 1/3/2018 4:47:52 PM, 1/2/2018 12:59:30 PM, 1/1/2018 12:01:59 PM, 12/31/2017 11:03:39 AM, 12/30/2017 12:08:39 PM, 12/30/2017 11:25:20 AM, 12/30/2017 10:16:19 AM, 12/28/2017 3:53:25 PM, 12/27/2017 9:15:22 PM, 12/26/2017 11:00:04 AM, 12/25/2017 11:00:04 AM, 12/24/2017 11:00:01 AM, 12/23/2017 11:00:01 AM, 12/22/2017 11:00:33 AM, 12/21/2017 11:00:03 AM, 12/20/2017 2:16:39 PM, 12/19/2017 11:00:06 AM, 12/18/2017 11:00:05 AM, 12/17/2017 11:00:01 AM, 12/9/2017 12:00:12 PM, 12/8/2017 11:59:55 PM, 12/7/2017 8:55:55 PM, 12/5/2017 2:35:08 PM, 12/2/2017 12:00:01 PM, 12/2/2017 9:42:16 AM, 11/30/2017 9:20:18 PM, 11/28/2017 8:59:20 PM, 11/27/2017 12:00:01 PM, 11/26/2017 8:20:58 PM, 11/25/2017 3:54:26 PM, 11/24/2017 8:17:44 PM, 11/22/2017 10:27:53 PM, 11/21/2017 12:00:05 PM, 11/20/2017 10:57:00 PM, 11/19/2017 6:57:51 PM, 11/17/2017 9:54:56 PM, 11/16/2017 4:14:19 PM, 11/14/2017 9:51:50 PM, 11/13/2017 2:29:48 PM, 11/12/2017 5:40:40 PM, 11/11/2017 2:08:28 PM, 11/8/2017 6:39:46 PM, 11/7/2017 7:23:56 PM, 11/6/2017 10:29:48 PM, 11/5/2017 6:17:20 PM, 11/4/2017 7:13:01 PM, 11/3/2017 1:00:00 PM, 11/2/2017 11:21:10 PM, 11/1/2017 10:18:48 PM, 10/31/2017 6:06:48 PM, 10/30/2017 8:28:09 PM, 10/29/2017 10:13:16 PM, 10/27/2017 1:00:00 PM, 10/26/2017 10:21:57 PM, 10/26/2017 9:43:36 PM, 10/26/2017 6:27:54 PM, 10/25/2017 8:32:11 PM, 10/24/2017 10:35:38 PM, 10/23/2017 1:00:01 PM, 10/22/2017 7:40:59 PM, 10/22/2017 10:06:49 AM, 10/21/2017 10:04:56 PM, 10/18/2017 11:10:22 PM, 10/18/2017 8:58:56 PM, 10/16/2017 1:00:04 PM, 10/15/2017 10:06:05 PM, 10/14/2017 1:00:02 PM, 10/14/2017 10:13:01 AM, 10/13/2017 8:56:59 AM, 10/12/2017 11:22:25 PM, 10/12/2017 1:00:02 PM, 10/11/2017 6:41:59 PM, 10/10/2017 8:24:31 PM, 10/10/2017 7:34:52 PM, 10/9/2017 2:47:18 PM, 10/8/2017 6:37:17 AM, 10/6/2017 1:00:05 PM, 10/5/2017 8:11:44 PM, 10/4/2017 10:03:27 PM, 10/4/2017 9:18:29 PM, 10/4/2017 8:23:00 PM, 10/1/2017 3:18:56 PM, 9/29/2017 1:00:03 PM, 9/28/2017 9:39:38 PM, 9/27/2017 1:16:21 PM, 9/26/2017 10:36:54 PM, 9/24/2017 1:59:17 PM, 9/23/2017 1:00:02 PM, 9/23/2017 9:05:36 AM, 9/21/2017 7:20:25 PM, 9/18/2017 9:48:23 PM, 9/17/2017 8:17:36 PM, 9/16/2017 10:30:32 AM, 9/15/2017 11:19:12 PM, 9/15/2017 9:40:44 PM, 9/12/2017 8:56:08 PM, 9/11/2017 2:01:26 PM, 9/9/2017 11:04:30 PM, 9/9/2017 9:48:19 PM, 9/6/2017 8:56:13 PM, 9/4/2017 9:47:47 PM, 9/4/2017 7:48:36 PM, 9/2/2017 9:52:11 PM, 9/2/2017 3:35:02 PM, 8/30/2017 8:03:24 PM, 8/30/2017 7:49:25 AM, 8/29/2017 10:33:49 PM, 8/29/2017 5:12:41 PM, 8/22/2017 11:05:18 PM, 8/22/2017 10:45:34 PM, 8/22/2017 10:44:16 PM, 8/22/2017 9:41:01 PM
[Retention Policy]: Time frames and intervals pairs: 7.00:00:00 / Keep all, 28.00:00:00 / 7.00:00:00, 365.00:00:00 / 31.00:00:00, Unlimited / 365.00:00:00
[Retention Policy]: Start checking if backups can be removed
Feb 26, 2018 11:53 PM: Result
Feb 26, 2018 11:50 PM: Message
Feb 26, 2018 4:17 PM: Message
Feb 25, 2018 1:55 PM: Result
Feb 24, 2018 5:00 PM: Result
