i get some Errors while BackUp with Duplicati 2:
Missing file: duplicati-b7859f53e51c94110a1703cee8e56b642.dblock.zip
Found 1 files that are missing from the remote storage, please run repair
Fatal error
Duplicati.Library.Interface.UserInformationException: Found 1 files that are missing from the remote storage, please run repair
bei Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList(BackendManager backend, Options options, LocalDatabase database, IBackendWriter log, String protectedfile)
bei Duplicati.Library.Main.Operation.BackupHandler.PreBackupVerify(BackendManager backend, String protectedfile)
bei Duplicati.Library.Main.Operation.BackupHandler.Run(String sources, IFilter filter)
I had run the repair, the small “repair” and the big “delete and repair”. The Error still stands on.
i had also tryed the command-line-tool with “LIST-BROKEN-FILES”-command, but there is also an Error:
c:\Program Files\Duplicati 2>Duplicati.CommandLine.exe list-broken-files \omv.fritz.box\Backup\Automatic\HTPC\Duplicati
Verschlüsselungspassphrase eingeben:
System.InvalidOperationException: Schlüssel können nicht gelesen werden, wenn keine der Anwendungen eine Konsole besitzt, oder wenn die Konsoleneingabe aus einer Datei umgeleitet wurde. Verwenden Sie Console.Read.
bei System.Console.ReadKey(Boolean intercept)
bei Duplicati.Library.Modules.Builtin.ConsolePasswordInput.ReadPassphraseFromConsole(Boolean confirm)
bei Duplicati.Library.Modules.Builtin.ConsolePasswordInput.Configure(IDictionary`2 commandlineOptions)
bei Duplicati.Library.Main.Controller.SetupCommonOptions(ISetCommonOptions result, String[]& paths, IFilter& filter)
bei Duplicati.Library.Main.Controller.RunAction[T](T result, String[]& paths, IFilter& filter, Action`1 method)
bei Duplicati.Library.Main.Controller.ListBrokenFiles(IFilter filter, Func`6 callbackhandler)
bei Duplicati.CommandLine.Commands.ListBrokenFiles(TextWriter outwriter, Action`1 setup, List`1 args, Dictionary`2 options, IFilter filter)
bei Duplicati.CommandLine.Program.RunCommandLine(TextWriter outwriter, TextWriter errwriter, Action`1 setup, String[] args)
how i can get my Duplicati back to work?
