Hello.
I’m using Duplicati - 2.0.6.3_beta_2021-06-17
I create backup configuration and working however I found issue in credentials to local folders.
I speak about user, password and check connction button:
Issue no 1.
When I create config with above credentials and next click edit the config then missing this credentials, fields are empty. Not sure credentials is saved or not. Please note in general first step credentials are available but next step no. Maybe this is connected with below more impact issue.
Issue no 2.
Floder d:\duplicati_backup have granted access to user “duplicati_user” only, PL test “zezwalj” = EN “Allow” and there is not inheritance from d:. Owner is local admin “dorotka” however tested also with owner “duplicati_user” and nothing change not work.
Also screen for confirm that this user exist and is enabled:
So when I click check connection appear this error:
Message say folder does not exist, create it? Click yes and next popup window
Access refused for above path.
But when I add my admin user “dorotka” to the dir then dir exist (has been created earlier)
After add my admin user “dorotka” to the path then duplicati working:
Please note there is still credentials for antoher user “duplicati_user” in background.
Summary:
In my opinion credentials is not working correctly here.
Can you please check this?
Best Regards.
Update. There is a bug, I just wrote some fake user and password in credentials and stay the same as last above steps this mean backup folder have admin “dorotka” and “deplicati_user” grant only for backup folder.
After this success
Can someone fix it please?
