I’m on Linux Mint Debian Edition (LMDE) 6 “Faye”.
Duplicati works from http://localhost:8200/ngax/index.html#/ and I can successfully backup and restore. However, there is no tray icon at login.
I can get the icon by starting duplicati from terminal or gui (just having to stop the service first to avoid the icon launching a second instance at http://localhost:8300/ngax/index.html#/). When the icon is present, right-clicking will instantly crash duplicati (no error message or terminal output).
When installing I deviated slightly from the install instructions at Installation - Duplicati 2 User's Manual. Instead of following the steps given for Debian 10 I downloaded from Download Duplicati application and then ran sudo gdebi duplicati_2.0.8.1-1_all.deb, meaning I’m likely on a newer version of mono.
sudo nano /etc/systemd/system/duplicati.service and sudo nano /etc/default/duplicati I did as per instructions.
Searching the forums I found several similar topics, but none of them describes exactly my problem:
- tray-icon-and-automatic-backups-not-happening-after-restart/
- duplicati-tray-icon-when-running-as-linux-service
- tray-icon-wont-load-when-i-run-duplicati-as-a-systemd-service
- how-to-get-debian-duplicati-tray-icon
- debian-trixie-dependency-problems
I tried disabling the systemctl service. While duplicati still crashes on right-click, the new instance opens without access to my backups, even though the web adress is the same (http://localhost:8200/ngax/index.html#/). I guess that might mean the installation runs as root, while I would want it to run per user. This might call for a separate topic, though.
Help needed to continue!
(Edited to fix typo)
