Hello! I have been trying to setup duplicati in Docker on my Synology NAS for the past couple weeks but i keep running into different problems. Right now im stumbling upon a continuous FileNotFoundException every time i start a backup of my “video” folder, which is about 2.7TB total. It will go for a night and actually start backing up, then the next morning i wake up to a FileNotFoundException with the backup stopped.
This is the entire exception:
Aug 24, 2020 12:12 AM: The operation Backup has failed with error: Could not find file “/tmp/dup-17f1cea6-2579-4f0c-becc-06835d74fc7c”
{“ClassName”:“System.IO.FileNotFoundException”,“Message”:“Could not find file "/tmp/dup-17f1cea6-2579-4f0c-becc-06835d74fc7c"”,“Data”:null,“InnerException”:null,“HelpURL”:null,“StackTraceString”:" at System.IO.FileStream…ctor (System.String path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share, System.Int32 bufferSize, System.Boolean anonymous, System.IO.FileOptions options) [0x0019e] in <254335e8c4aa42e3923a8ba0d5ce8650>:0 \n at System.IO.FileStream…ctor (System.String path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share) [0x00000] in <254335e8c4aa42e3923a8ba0d5ce8650>:0 \n at (wrapper remoting-invoke-with-check) System.IO.FileStream…ctor(string,System.IO.FileMode,System.IO.FileAccess,System.IO.FileShare)\n at Duplicati.Library.Main.Volumes.VolumeReaderBase.LoadCompressor (System.String compressor, System.String file, Duplicati.Library.Main.Options options, System.IO.Stream& stream) [0x00000] in <8f1de655bd1240739a78684d845cecc8>:0 \n at Duplicati.Library.Main.Volumes.VolumeReaderBase…ctor (System.String compressor, System.String file, Duplicati.Library.Main.Options options) [0x00007] in <8f1de655bd1240739a78684d845cecc8>:0 \n at Duplicati.Library.Main.Volumes.BlockVolumeReader…ctor (System.String compressor, System.String file, Duplicati.Library.Main.Options options) [0x00010] in <8f1de655bd1240739a78684d845cecc8>:0 \n at Duplicati.Library.Main.Operation.Backup.SpillCollectorProcess+<>c__DisplayClass0_0.b__0 (<>f__AnonymousType112[<Input>j__TPar,<Output>j__TPar] self) [0x0023c] in <8f1de655bd1240739a78684d845cecc8>:0 \n at CoCoL.AutomationExtensions.RunTask[T] (T channels, System.Func2[T,TResult] method, System.Boolean catchRetiredExceptions) [0x000d5] in <9a758ff4db6c48d6b3d4d0e5c2adf6d1>:0 \n at Duplicati.Library.Main.Operation.BackupHandler.RunMainOperation (System.Collections.Generic.IEnumerable1[T] sources, Duplicati.Library.Snapshots.ISnapshotService snapshot, Duplicati.Library.Snapshots.UsnJournalService journalService, Duplicati.Library.Main.Operation.Backup.BackupDatabase database, Duplicati.Library.Main.Operation.Backup.BackupStatsCollector stats, Duplicati.Library.Main.Options options, Duplicati.Library.Utility.IFilter sourcefilter, Duplicati.Library.Utility.IFilter filter, Duplicati.Library.Main.BackupResults result, Duplicati.Library.Main.Operation.Common.ITaskReader taskreader, System.Int64 filesetid, System.Int64 lastfilesetid, System.Threading.CancellationToken token) [0x0035f] in <8f1de655bd1240739a78684d845cecc8>:0 \n at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x01033] in <8f1de655bd1240739a78684d845cecc8>:0 \n at CoCoL.ChannelExtensions.WaitForTaskOrThrow (System.Threading.Tasks.Task task) [0x00050] in <9a758ff4db6c48d6b3d4d0e5c2adf6d1>:0 \n at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00009] in <8f1de655bd1240739a78684d845cecc8>:0 \n at Duplicati.Library.Main.Controller+<>c__DisplayClass14_0.<Backup>b__0 (Duplicati.Library.Main.BackupResults result) [0x0004b] in <8f1de655bd1240739a78684d845cecc8>:0 \n at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action1[T] method) [0x0026f] in <8f1de655bd1240739a78684d845cecc8>:0 \n at Duplicati.Library.Main.Controller.Backup (System.String inputsources, Duplicati.Library.Utility.IFilter filter) [0x00074] in <8f1de655bd1240739a78684d845cecc8>:0 \n at Duplicati.Server.Runner.Run (Duplicati.Server.Runner+IRunnerData data, System.Boolean fromQueue) [0x00349] in :0 “,“RemoteStackTraceString”:null,“RemoteStackIndex”:0,“ExceptionMethod”:null,“HResult”:-2147024894,“Source”:“mscorlib”,“FileNotFound_FileName”:”/tmp/dup-17f1cea6-2579-4f0c-becc-06835d74fc7c",“FileNotFound_FusionLog”:null}
I do not understand where to start to solve this problem. Any help would be greatly appreciated. Every time i restart the backup, it will go for a bit, and then eventually end up with this error. I also wonder if it happens on a specific file, but as far as i’m aware i can’t see that with the above error.
Thank you.
Edit: To add a bit more information. In the Synology Docker app the Duplicati container does run with “High privilege” enabled and i have variabled PGID = 0 and PUID = 0, i think i read somewhere that has something to do with privileges, i thought i’d at least mention it.
