Introducing secrets with 10 different providers
Being a trust-no-one backup solution, a key problem is to guard the different secrets, in particular the backup passphrase. Until now, Duplicati has supported injecting secrets either via the command line interface or by running a script that obtains the passphrase and injects it.
With the latest canary build, Duplicati now supports “secret providers” that offer different ways to inject sensitive parameters into the process. And the initial version supports no less than 10 different providers!
How does it work?
To ensure full backwards compatibility, nothing changes until a secret provider is enabled. The easiest way to enable a secret provider is to supply one as arguments to the initial process, either TrayIcon, Server, or Agent. Configuration is done with a single argument:
--secret-provider=<provider-url>
This will enable the secret provider which means that any values starting with a $ symbol will be treated as a placeholder for a secret. Any option value that starts with a $ symbol will then be retrieved from the secret provider and replace the placeholder value. To ensure that placeholders are not used as passphrases, any secret that is not found will cause an error.
Local providers
For single-machine use there are a few providers that support various ways to retrieve the secrets:
  • file-secret:// - Reads secrets from a file (optionally encrypted)
  • env:// - Reads secrets from environment variables
  • wincred:// - Reads secrets from Windows Credential Manager (Windows only)
  • libsecret:// - Reads secrets from libsecret (Linux only)
  • pass:// - Reads secrets from the pass tool (Linux only)
  • keychain:// - Reads secrets from the MacOS KeyChain (MacOS only)
Cloud providers
If you have a larger set of machines to manage, it can be easier to manage secrets in a central vault. With the Duplicati secret providers, it is possible to update the vaults and have the updated credentials applied across a set of machines. The secrets are only kept in memory until they are no longer needed.
The following cloud providers are supported:
  • awssm:// - Reads secrets from AWS Secrets Manager
  • hcv:// - Reads secrets from HashiCorp Vault (cloud + self-hosted)
  • gcsm:// - Reads secrets from Google Cloud Secret Manager
  • azkv:// - Reads secrets from Azure KeyVault
For cloud providers, an encrypted on-disk cache can be enabled, which makes backups run with cached credentials, in the event that the provider is down. Enable the cache with either:
--secret-provider-cache=inmemory
--secret-provider-cache=persistent
Using shared providers
If you start either the TrayIcon, Server, or Agent with a secret provider, it will apply to that instance, so you can get the encryption key for the settings database from a secret provider. For example:
--secret-provider=gcsm://?project-id=<projectid>
--require-db-encryption-key
--settings-encryption-key=$server-01-settings-key
This will look up the secret server-01-settings-key in the secret provider and replace the encryption key with the returned value. Since the secret provider is enabled for the Server, it will automatically be available for each of the backups configured. This allows a single configuration of the secret provider to be shared across multiple backups.
Should you want to use a different secret provider for one of the backups, you can also set the secret provider in the backup advanced options, and this provider will then override the shared one for that backup.
Try it out!
The secret providers are available in the latest canary build and you can try it out today:
Release: 2.0.9.109 (Canary) 2024-11-06
If you have questions, leave a comment below.
@kenkendk This post (and the docs) mention using file:// for a JSON file, but It appears it should actually be file-secret://.
I had the following docker-compose file
services:
  duplicati:
    image: lscr.io/linuxserver/duplicati:latest
    container_name: duplicati
    environment:
      - "DUPLICATI__SECRET_PROVIDER=file:///run/secrets/duplicati-secrets-file"
      - "DUPLICATI__WEBSERVICE_PASSWORD=$$ui-password"
      - "SETTINGS_ENCRYPTION_KEY=$$settings-key"
    volumes:
      - $CONFIG_PATH/duplicati/config:/config
      - $CONFIG_PATH:/source
    restart: unless-stopped
    secrets:
      - duplicati-secrets-file
secrets:
  duplicati-secrets-file:
    file: $CONFIG_PATH/secrets/duplicati-secrets-file.json
(some irrelevant stuff removed)
and when starting the container I got the error “No secret provider found for key file” which crashed the container on startup.
I went digging and it looks like the correct key for the file provider is file-secret duplicati/Duplicati/Library/SecretProvider/FileSecretProvider.cs at v2.1.0.2_beta_2024-11-29 · duplicati/duplicati · GitHub
Additionally, I had trouble with the compose snippet in the docs Using Duplicati from Docker | Duplicati. I believe doing just "$settings-key" will result in Docker Compose trying to interpolate the variable. Instead it should be $$settings-key to set it to the correct literal value.
Yes, you are correct, thanks for reporting.
I have updated the post and will update the documentation asap.
The provider was originally called file:// but it clashed a bit with the storage destination file:// so I changed it late in the process and this did not make it to the documentation.
Hm, I’m still have some trouble getting it to actually use the file. It appears the UI password is still the literal $ui-password. Entering that into the duplicati login lets me through, rather than the secret value.
If I run docker inspect duplicati everything looks good to me…
            "Env": [
                "TZ=Etc/UTC",
                "CLI_ARGS=",
                "DUPLICATI__SECRET_PROVIDER=file-secret:///run/secrets/duplicati-secrets-file",
                "DUPLICATI__WEBSERVICE_PASSWORD=$ui-password",
                "SETTINGS_ENCRYPTION_KEY=$settings-key",
                "PUID=501",
                "PGID=20",
                "PATH=/lsiopy/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin",
                "HOME=/config",
                "LANGUAGE=en_US.UTF-8",
                "LANG=en_US.UTF-8",
                "TERM=xterm",
                "S6_CMD_WAIT_FOR_SERVICES_MAXTIME=0",
                "S6_VERBOSITY=1",
                "S6_STAGE2_HOOK=/docker-mods",
                "VIRTUAL_ENV=/lsiopy",
                "LSIO_FIRST_PARTY=true",
                "TMPDIR=/run/duplicati-temp",
                "DUPLICATI__REQUIRE_DB_ENCRYPTION_KEY=true",
                "DUPLICATI__SERVER_DATAFOLDER=/config",
                "DUPLICATI__WEBSERVICE_PORT=8200",
                "DUPLICATI__WEBSERVICE_INTERFACE=any",
                "DUPLICATI__WEBSERVICE_ALLOWED_HOSTNAMES=*"
I’m not too fussed about this now, but still a bit mysterious.
Agree. It looks like the DUPLICATI__SECRET_PROVIDER environment variable is not picked up at all?
Beware that this likely means that your database is encrypted with the literal string $settings-key and not the value you intended to use.
This is hinted in the docs, but you can use Duplicati.CommandLine.SharpAESCrypt.exe / duplicati-aescrypt to encrypt the file.
I have updated the docs to include an example:
Duplicati.CommandLine.SharpAESCrypt.exe e my-password source.json destination.json.aes
That warning is because Duplicati does not know that the two passwords are resolved to the same. It just notices that the password has changed, and that is not supported.
If you run the backup with a new password, it will fail to read any files.
In your case, the setup is that you just want to use a placeholder that resolves to the same password, so in this case you can ignore the warning (assuming you are 100% sure it is the same password).
