I want to verify the integrity of the files of a remote backup. I have the duplicati-verification.json.
There is a Name and the Hash. The hash is a SHA-256 encoded as Base64. How can I verify the checksum for all files? Best a commandline call.
I am on Windows. Any tool sugestions or has Duplicati some command I do not know?
Ok. Answering myself… I have written a C# Program that verifies file size and checks the hash code of all files in a verification file.
Argument not given => look for file in current directory, otherwise give the path of the backup as argument. Just 2 classes. Feel free to use it!
VerifyDuplicati.cs
using System;
using System.Collections;
using System.Collections.Generic;
using System.IO ;
using System.Security.Cryptography;
namespace VerifyDuplicati {
class VerifyDuplicati {
private static SHA256 mySHA256 = SHA256.Create();
static void Main(string[] args) {
string path = ".\\";
if (args.Length == 1) {
path = args[0];
if (args.Length > 1) {
Console.WriteLine("Argument error");
} else {
DirectoryInfo di = new DirectoryInfo(args[0]);
Analyse(di);
private static void Analyse(DirectoryInfo rootPath) {
FileInfo fi = new FileInfo(Path.Combine(rootPath.FullName, "duplicati-verification.json"));
List<DuplicatiFile> files = ReadVerificationFile(fi.FullName);
Console.WriteLine("Processing " + files.Count + " files");
double totalBytes = 0;
foreach (DuplicatiFile duplicatiFile in files) {
totalBytes += duplicatiFile.Size;
Boolean success = false;
double processedBytes = 0;
success = CheckFile(duplicatiFile, rootPath);
if (success) {
processedBytes += duplicatiFile.Size;
long percent = (long) (processedBytes * 100.0d / totalBytes);
Console.WriteLine("Processed " + duplicatiFile.Name + " success , " + percent + "%");
} else {
break;
if (success) {
Console.WriteLine("SUCCESS");
Environment.Exit(0);
} else {
Console.WriteLine("FAILED");
Environment.Exit(1);
private static Boolean CheckFile(DuplicatiFile duplicatiFile, DirectoryInfo rootPath) {
// Create a fileStream for the file.
FileInfo fi = new FileInfo(Path.Combine(rootPath.FullName, duplicatiFile.Name));
try {
if (duplicatiFile.Size != fi.Length) {
Console.WriteLine("Size differs " + fi.Name);
return false;
FileStream fileStream = fi.Open(FileMode.Open);
fileStream.Position = 0;
byte[] hashValue = mySHA256.ComputeHash(fileStream);
fileStream.Close();
byte[] checkValue = Convert.FromBase64String(duplicatiFile.Hash);
if (!StructuralComparisons.StructuralEqualityComparer.Equals(hashValue, checkValue)) {
Console.WriteLine("Hash mismatch " + fi.Name);
return false;
} catch (IOException e) {
Console.WriteLine($"I/O Exception: {e.Message}");
return false;
} catch (UnauthorizedAccessException e) {
Console.WriteLine($"Access Exception: {e.Message}");
return false;
return true;
private static List<DuplicatiFile> ReadVerificationFile(string fullName) {
string json = File.ReadAllText(fullName);
List<DuplicatiFile> files = DuplicatiFile.FromJson(json);
return files;
DuplicatiFile.cs
// generated https://app.quicktype.io/#l=cs&r=json2csharp
using System;
using System.Globalization;
using Newtonsoft.Json;
using Newtonsoft.Json.Converters;
public partial class DuplicatiFile {
[JsonProperty("Name")]
public string Name { get; set; }
[JsonProperty("Hash")]
public string Hash { get; set; }
[JsonProperty("Size")]
public long Size { get; set; }
[JsonProperty("Type")]
public long Type { get; set; }
[JsonProperty("State")]
public long State { get; set; }
[JsonProperty("deleteGracePeriod")]
public DateTimeOffset DeleteGracePeriod { get; set; }
public static List<DuplicatiFile> FromJson(string json) => JsonConvert.DeserializeObject<List<DuplicatiFile>>(json, Converter.Settings);
public static class Serialize {
public static string ToJson(this List<DuplicatiFile> self) => JsonConvert.SerializeObject(self, Converter.Settings);
internal static class Converter {
public static readonly JsonSerializerSettings Settings = new JsonSerializerSettings {
MetadataPropertyHandling = MetadataPropertyHandling.Ignore,
DateParseHandling = DateParseHandling.None,
Converters =
new IsoDateTimeConverter { DateTimeStyles = DateTimeStyles.AssumeUniversal }
Adding to this, there is a PowerShell script for verification here:
#Requires -Version 5.1
param
[Parameter(Mandatory = $true)]
[ValidateNotNullOrEmpty()]
[string]$FileOrDir
Set-StrictMode -Version Latest
$ErrorActionPreference = "Stop"
enum RemoteVolumeState
# Indicates that the remote volume is being created
Temporary
# Indicates that the remote volume is being uploaded
Uploading
# Indicates that the remote volume has been uploaded
Uploaded
# Indicates that the remote volume has been uploaded, and seen by a list operation
This file has been truncated. show original
And a Python script for verification here:
#!/usr/bin/env python
This file is a standalone python script that is tested with python 2.7
If Duplicati is producing a backup with the option --upload-verification-file,
it will produce a *-verification.json file on the backend, which can be verified
by this script. Simply run this script with the path to the backup
folder as input, and it will verify all *-verification.json files in the folder.
import sys
import os
import string
import json
import base64
import codecs
from hashlib import sha256
""" Utility function to return byte chunks from a binary file """
def bytes_from_file(filename, chunksize=8192):
ts678
June 28, 2019, 2:17pm
4
The two DuplicatiVerify scripts are also in the Duplicati installation’s utility-scripts subfolder if that’s easier.
