While I’m stuck setting up a backup task from one NAS to another (see here) I thought I’d try a USB-drive as backup destination, hooked to the source-NAS (Synology DS220+). On the NAS I installed Duplicati in a docker-container. Container runs OK and I can access Duplicati’s config page via http://MyNas1:8200/ngax/index.html.
In Step2 however (setting up destination), I am stuck: After selecting “Local folder or drive” as storage type I don’t find my drive in the browser below. The browser displays the usual Linux-like system folders on my NAS, but nothing after /var. On the DS220+ the drive appears to be correctly mounted and is accessible in Filemananger. I also find it (with Putty) in the filesystem under /volumeUSB1/usbshare. But I have no clue what I need to do to get this usbshare to appear in duplicati’s browser.
I created a folder //volumeUSB1/usbshare/Duplicati with Putty, but when I directly enter this path in duplicati and ‘try connection’ it claims that this doesn’t exist. When I confirm to create it I get access denied.
Any clues how I get to my USB-drive, anyone?
EDIT: Sam question if I want to backup local data to any destination with duplicati. How do I specify source files under /volume1/…?
