Hello,
shortly prior finalizing the backup the following appears:
I updated to the latest Duplicati version some days ago. Since then, the error appears.
Remaining memory size on receiving NAS is about 1 TB while backup has about 5 GB.
Does anybody has an idea? Thank you!
Below the details incl. log.
Error description:
"2025-01-14 13:33:41 +01 - [Error-Duplicati.Library.Main.Operation.BackupHandler-FatalError]: Fatal error
FtpException: Error while uploading the file to the server. See InnerException for more info."
Log:
“DeletedFiles”: 1,
“DeletedFolders”: 0,
“ModifiedFiles”: 0,
“ExaminedFiles”: 1785,
“OpenedFiles”: 0,
“AddedFiles”: 0,
“SizeOfModifiedFiles”: 0,
“SizeOfAddedFiles”: 0,
“SizeOfExaminedFiles”: 2147556903,
“SizeOfOpenedFiles”: 0,
“NotProcessedFiles”: 0,
“AddedFolders”: 0,
“TooLargeFiles”: 0,
“FilesWithError”: 0,
“ModifiedFolders”: 0,
“ModifiedSymlinks”: 0,
“AddedSymlinks”: 0,
“DeletedSymlinks”: 0,
“PartialBackup”: false,
“Dryrun”: false,
“MainOperation”: “Backup”,
“CompactResults”: null,
“VacuumResults”: null,
“DeleteResults”: null,
“RepairResults”: null,
“TestResults”: null,
“ParsedResult”: “Fatal”,
“Interrupted”: false,
“Version”: “2.1.0.2 (2.1.0.2_beta_2024-11-29)”,
“EndTime”: “2025-01-14T12:33:41.5648582Z”,
“BeginTime”: “2025-01-14T12:32:44.0375563Z”,
“Duration”: “00:00:57.5273019”,
“MessagesActualLength”: 40,
“WarningsActualLength”: 1,
“ErrorsActualLength”: 2,
“Messages”: [
“2025-01-14 13:32:44 +01 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: Die Operation Backup wurde gestartet”,
“2025-01-14 13:32:44 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: ()”,
“2025-01-14 13:32:49 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: (179 Bytes)”,
“2025-01-14 13:32:49 +01 - [Information-Duplicati.Library.Main.Operation.FilelistProcessor-RemoteUnwantedMissingFile]: removing file listed as Temporary: duplicati-20250114T073437Z.dlist.zip”,
“2025-01-14 13:32:49 +01 - [Information-Duplicati.Library.Main.Operation.FilelistProcessor-SchedulingMissingFileForDelete]: scheduling missing file for deletion, currently listed as Uploading: duplicati-20250114T073438Z.dlist.zip”,
“2025-01-14 13:32:49 +01 - [Information-Duplicati.Library.Main.Operation.FilelistProcessor-KeepIncompleteFile]: keeping protected incomplete remote file listed as Uploading: duplicati-20250114T110234Z.dlist.zip”,
“2025-01-14 13:32:49 +01 - [Information-Duplicati.Library.Main.Operation.FilelistProcessor-SchedulingMissingFileForDelete]: scheduling missing file for deletion, currently listed as Uploading: duplicati-b03bee7270a1a4b9d88454f652b71c96b.dblock.zip”,
“2025-01-14 13:32:49 +01 - [Information-Duplicati.Library.Main.Operation.FilelistProcessor-RemoteUnwantedMissingFile]: removing file listed as Deleting: duplicati-baa5178bd1c1b4a32ada57a095642cc9c.dblock.zip”,
“2025-01-14 13:32:49 +01 - [Information-Duplicati.Library.Main.Operation.FilelistProcessor-RemoteUnwantedMissingFile]: removing file listed as Deleting: duplicati-bfd096bd66f7e455db65d8f89bb7332c6.dblock.zip”,
“2025-01-14 13:32:49 +01 - [Information-Duplicati.Library.Main.Operation.FilelistProcessor-RemoteUnwantedMissingFile]: removing file listed as Deleting: duplicati-b764b2b5947bf45c28088bbb6c8320f9d.dblock.zip”,
“2025-01-14 13:32:49 +01 - [Information-Duplicati.Library.Main.Operation.FilelistProcessor-RemoteUnwantedMissingFile]: removing file listed as Deleting: duplicati-b70c3719810a54577b6619483ce01fcc0.dblock.zip”,
“2025-01-14 13:32:49 +01 - [Information-Duplicati.Library.Main.Operation.FilelistProcessor-RemoteUnwantedMissingFile]: removing file listed as Deleting: duplicati-b76e4fc3124fd405ea5baded51b4e39ec.dblock.zip”,
“2025-01-14 13:32:49 +01 - [Information-Duplicati.Library.Main.Operation.Backup.UploadSyntheticFilelist-PreviousBackupFilelistUpload]: Uploading filelist from previous interrupted backup”,
“2025-01-14 13:32:50 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-bbcd73f6e957341729972cc27f383d4e3.dblock.zip (778 Bytes)”,
“2025-01-14 13:32:50 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Retrying: duplicati-bbcd73f6e957341729972cc27f383d4e3.dblock.zip (778 Bytes)”,
“2025-01-14 13:33:00 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Rename: duplicati-bbcd73f6e957341729972cc27f383d4e3.dblock.zip (778 Bytes)”,
“2025-01-14 13:33:00 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Rename: duplicati-b65ead4c70ca34485beece23c4ce62e9f.dblock.zip (778 Bytes)”,
“2025-01-14 13:33:00 +01 - [Information-Duplicati.Library.Main.Operation.Backup.BackendUploader-RenameRemoteTargetFile]: Renaming "duplicati-bbcd73f6e957341729972cc27f383d4e3.dblock.zip" to "duplicati-b65ead4c70ca34485beece23c4ce62e9f.dblock.zip"”,
“2025-01-14 13:33:00 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b65ead4c70ca34485beece23c4ce62e9f.dblock.zip (778 Bytes)”,
“2025-01-14 13:33:00 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Retrying: duplicati-b65ead4c70ca34485beece23c4ce62e9f.dblock.zip (778 Bytes)”
“Warnings”: [
“2025-01-14 13:32:50 +01 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: D:\OneDrive - Kindlein Beratung und Training\35 Jörn Firma\25 Owens Corning\99 Page + time tracking\240103 OC time tracker.xlsx\r\nIOException: The process cannot access the file ‘\\?\D:\OneDrive - Kindlein Beratung und Training\35 Jörn Firma\25 Owens Corning\99 Page + time tracking\240103 OC time tracker.xlsx’ because it is being used by another process.”
“Errors”: [
“2025-01-14 13:33:41 +01 - [Error-Duplicati.Library.Main.Operation.BackupHandler-FatalError]: Fatal error\r\nFtpException: Error while uploading the file to the server. See InnerException for more info.”,
“2025-01-14 13:33:41 +01 - [Error-Duplicati.Library.Main.Controller-FailedOperation]: Die Operation Backup ist mit folgenden Fehler fehlgeschlagen: One or more errors occurred. (Error while uploading the file to the server. See InnerException for more info. (Error while uploading the file to the server. See InnerException for more info.) (One or more errors occurred. (Error while uploading the file to the server. See InnerException for more info.)))\r\nAggregateException: One or more errors occurred. (Error while uploading the file to the server. See InnerException for more info. (Error while uploading the file to the server. See InnerException for more info.) (One or more errors occurred. (Error while uploading the file to the server. See InnerException for more info.)))”
“BackendStatistics”: {
“RemoteCalls”: 7,
“BytesUploaded”: 0,
“BytesDownloaded”: 0,
“FilesUploaded”: 0,
“FilesDownloaded”: 0,
“FilesDeleted”: 0,
“FoldersCreated”: 0,
“RetryAttempts”: 5,
“UnknownFileSize”: 0,
“UnknownFileCount”: 0,
“KnownFileCount”: 179,
“KnownFileSize”: 1923927974,
“LastBackupDate”: “2025-01-11T12:20:55+01:00”,
“BackupListCount”: 54,
“TotalQuotaSpace”: 0,
“FreeQuotaSpace”: 0,
“AssignedQuotaSpace”: -1,
“ReportedQuotaError”: false,
“ParsedResult”: “Success”,
“BeginTime”: “2025-01-14T12:32:44.037568Z”,
“Duration”: “00:00:00”,
“MessagesActualLength”: 0,
“WarningsActualLength”: 0,
“ErrorsActualLength”: 0,
“Messages”: null,
“Warnings”: null,
“Errors”: null
