Note that this build has a redesigned restore flow
Should issues arise, the previous restore engine can be enabled with --restore-legacy=true.
Detailed list of changes:
Added server status and wait to ServerUtil
Fixed an issue where index files would contain replicated blocklists
Fixed an issue with duplicate blocks preventing repair
Size strings are now formatted as kikibytes
Fixed some issues with CIFS/SMB backend
kenkendk:
kikibytes
Funny typo, but it’s good to use SI units for consistency.
Sami_Lehtinen:
Funny typo
It is actually not a typo, but I agree it is a non-intuitive name:
kenkendk:
kiki
Yeah, kik i vs kib i… I like kibibytes due to binary options being preferred.
But, to the actual point why I’m here. I found still something, doesn’t really matter but is just minor annoyance. Now I did dig the info from logs.
2025-01-14 11.07.02 +02 - [Warning-Duplicati.Library.Main.Operation.Restore.FileProcessor-CreateMissingFolder]: Creating missing folder “d:\path” for file “d:\path\configuration.ini”
Version: - 2.1.0.106_canary_2025-01-11
Still seems to be there. → If I start restore, create that directory quickly and then it exists with Code: 0, but if I don’t manually create that directory, it exists with 2. Now I got the exact warning from log, so it should be possible to locate it.
Otherwise everything is now pretty great.
ts678
January 14, 2025, 1:30pm
5
Sami_Lehtinen:
opened 11:43AM - 07 Jan 25 UTC
If restoring a subset of files, Duplicati will make a minimal folder structure t… o support the files.
However, since the folders are created and not restored, the folders do not retain the metadata on the folders (modification time, permissions, etc), and for this, Duplicati emits a warning.
We should update the logic to check if the folder was requested to be restored, and if so give a warning. In the case the folder is not matching the list of items to restore, the folder creation is expected, and no warning should be given.
is still open. Because I got confused by the plan, I asked a question. You can review it as well.
Taomyn
January 15, 2025, 8:11am
6
I updated all my machines to .106 and so far so good. The new CIFS/SMB connector is now working well on my Linux machines and I’ve been able to remove the SMB mounts I was using before.
After upgrading for 2.1.0.104 (beta) I see the message that --use-block-cache is not supported. Is it OK? I think it was very useful parameter.
ts678
January 16, 2025, 2:29pm
8
It hasn’t done anything since removal six years ago . This is just now causing notification .
